Solved NEED HELP - BOT STOPS WHEN I CLOSE PUTTY
TheXeno
Hi!
I start the bot with ./sinusbot.
But I cant detach it or close Putty without killing the sinusbotsession.
Pls Help me ;=)
Patrick15a
Debian/Ubuntu:
As root user:
apt install screen
as sinusbot user:
screen -dmS Sinusbot ./sinusbot
when you will open the console use on your sinusbot user:
screen -r Sinusbot
and go back with STRG + A + D
