PhP "Method Not Allowed" trotz POST
<?php
[CODE]
class Bot {
    public $botHost = '127.0.0.1';
    public $botPort = 8087;
    public $botId = NULL;
    public $token = NULL;
    public $uuid = NULL;
    public function __construct($botHost = '127.0.0.1', $botPort = 8087, $botId = NULL) {
        $this->botHost = $botHost;
        $this->botPort = $botPort;
        if ($botId == NULL) {
            $botId = $this->DefaultBot();
        $this->botId = $botId;
    public function DefaultBot() {
        $ch = curl_init();
        curl_setopt_array($ch, array(
            CURLOPT_URL => 'http://'.$this->botHost.':'.$this->botPort.'/api/v1/botId',
            CURLOPT_RETURNTRANSFER => 1
        $data = curl_exec($ch);
        curl_close($ch);
        $json = json_decode($data, TRUE);
        return $json['defaultBotId'];
    public function Login($username, $password) {
        $ch = curl_init();
            CURLOPT_URL => 'http://'.$this->botHost.':'.$this->botPort.'/api/v1/bot/login',
            CURLOPT_RETURNTRANSFER => 1,
            CURLOPT_POSTFIELDS => json_encode(array('username' => $username, 'password' => $password, 'botId' => $this->botId)),
            CURLOPT_HTTPHEADER => array('Content-Type: application/json')
        $code = curl_getinfo($ch, CURLINFO_HTTP_CODE);
        #echo "data: ".$data."<br>Code: ".$code."<br>";
        curl_close($ch);
        if ($code != 200) return NULL;
        $token=json_decode($data, TRUE);
        $this -> token =$token["token"];
    public function GetInstances() {
        $ch = curl_init();
            CURLOPT_URL => 'http://'.$this->botHost.':'.$this->botPort.'/api/v1/bot/instances',
            CURLOPT_HTTPHEADER => array('Authorization: bearer '.$this->token)
        #echo $data;
        #echo $code;
        curl_close($ch);
        return $json;
    public function GetInstanceStatus($instanceId) {
        $ch = curl_init();
            CURLOPT_URL => 'http://'.$this->botHost.':'.$this->botPort.'/api/v1/bot/i/'.$instanceId.'/status',
        curl_close($ch);
	return $json;
    public function KillInstance($uid) {
        $ch = curl_init();
            CURLOPT_URL => 'http://'.$this->botHost.':'.$this->botPort.'/api/v1/bot/i/'.$uid.'/kill',
	echo $data."->".$code;
        curl_close($ch);
	return $json;
    public function SpawnInstance($instanceId) {
        echo $instanceId;
        $ch = curl_init();
            CURLOPT_URL => 'http://'.$this->botHost.':'.$this->botPort.'/api/v1/bot/i/'.$instanceId.'/spawn',
        #printr($ch);
        curl_close($ch);
	return $json;
$bot = new Bot('127.0.0.1', 8087);
$bot->Login('admin', 'foobar');
if (isset($_POST['submit']))
    echo"Post da<br>";
  $uuid=$_POST['uid'];
  $value1=$_POST['submit'];
  $bot->KillInstance($uuid);
  #echo $bot;
  echo $uuid."->".$value1;
    unset($_POST['submit']);
    #header('Loacatio
else
echo "Kei Post";
$instances = $bot->GetInstances();
#printf($instances);
#echo '<link href="css location" rel="stylesheet" type="text/css" />';
#echo "Wassustfalsch";
echo "<table border=1 width=100%>";
echo "<tr><td colspan=4>Musikbot Control</td></tr>";
echo "<tr><td>Botname</td><td>Sender</td><td>Titel</td><td>Actio</td></tr>";
#echo "</table>";
for ($i = 0; $i < count($instances); $i++) {
    $info = $bot->GetInstanceStatus($instances[$i]['uuid']);
    if ($info['currentTrack'] != NULL && $info['playing']) {
        echo '';
  #printf("%s is playing %s by %s\n", $instances[$i]['nick'], $info['currentTrack']['title'], $info['currentTrack']['artist']);
  echo "<tr><td>".$instances[$i]['nick']."</td><td>".$info['currentTrack']['title']."</td><td>".$info['currentTrack']['artist'];
  echo '</td><td>';
  # actioplacedhere</td></tr>
    echo'<form action="botctl.php" method="post"><input type="hidden" name="uid" value="'.$instances[$i]['uuid'].'"><button type="submit" name="submit" value="kill">Kill</button></form>';
    echo"</td></tr>";
    } else {
        echo '<div class="output'.$i.'">';
  printf("%s is not playing anything right now\n", $instances[$i]['nick']);
  echo '
echo "</table>";
[/CODE]
Jemand eine Idee weshalb das nicht geht? Wusste nicht genau wo ich das posten sollte, darum einfach mal in Installation reingepackt.
Du machst da kein POST. Du musst die entsprechenden CURLOPT-Felder setzen. Lies dir am besten mal die Doku zu curl in PHP durch.
