Play a track using track ID & URL?
#1
Just wondering if it's possible to play a track directly from a URL?
For example the track ID is 8b8f32f8-2de3-4b7c-87e0-30514c13bd46
http://101:101:101:101:8087/play/files?id=8b8f32f8-2de3-4b7c-87e0-30514c13bd46 or something similar?
Not sure what you want to achieve here, but API calls are possible if you mean that.
Take a look here https://www.sinusbot.com/api
Also notice that you need to authorize yourself before you can call any API commands successfully
