please help..!! my server can't connect to sinusbot
ggv01
[2019-03-02 06:42:13] [WELCOME] =================================================
[2019-03-02 06:42:13] [WELCOME] = HELLO! Please invest some time to read this.  =
[2019-03-02 06:42:13] [WELCOME] =                                               =
[2019-03-02 06:42:13] [WELCOME] =  Thanks  for  using  this diagnostic script!  =
[2019-03-02 06:42:13] [WELCOME] =  The  more  information  you   provide,  the  =
[2019-03-02 06:42:13] [WELCOME] =  better  we  can help to solve your problem.  =
[2019-03-02 06:42:13] [WELCOME] =  The  execution  may  take  some  moments to  =
[2019-03-02 06:42:13] [WELCOME] =  collection  the most  important information  =
[2019-03-02 06:42:13] [WELCOME] =  of your system  and  your bot installation.  =
[2019-03-02 06:42:13] [WELCOME] =  After  everything  is  done, you will get a  =
[2019-03-02 06:42:13] [WELCOME] =  diagnostic output, ready for copy & pasting  =
[2019-03-02 06:42:13] [WELCOME] =  it within a CODE-tag in the SinusBot forum.  =
[2019-03-02 06:42:13] [WELCOME] =  [Link: https://forum.sinusbot.com]           =
[2019-03-02 06:42:13] [WELCOME] =  No  private  information  will be collected  =
[2019-03-02 06:42:13] [WELCOME] =  nor  the  data  will  be  sent to anywhere.  =
[2019-03-02 06:42:13] [WELCOME] =  This  just generates an example forum post.  =
[2019-03-02 06:42:13] [WELCOME] =  The script does perform a DNS resolution of  =
[2019-03-02 06:42:13] [WELCOME] =  domain 'www.sinusbot.com' to  determine  if  =
[2019-03-02 06:42:13] [WELCOME] =  your  DNS settings are working as expected.  =
[2019-03-02 06:42:13] [WELCOME] = I am thankful for any feedback. Please  also  =
[2019-03-02 06:42:13] [WELCOME] = report any issues you may find either on the  =
[2019-03-02 06:42:13] [WELCOME] = SinusBot forum or via GitHub issues. Thanks!  =
[2019-03-02 06:42:13] [WELCOME] =   -- Patrik Kernstock aka. Patschi.           =
[2019-03-02 06:42:13] [WAIT] Press [ENTER] to continue...
[2019-03-02 06:42:13] [INFO] Starting diagSinusbot v0.7.1 [2018-05-23 22:20 UTC]...
[2019-03-02 06:42:14] [INFO] Checking for new diagnostic script version...
[2019-03-02 06:42:14] [OKAY] You are using the latest version.
[2019-03-02 06:42:14] [INFO] Detected operating system: Debian GNU/Linux 8.11 (jessie)
[2019-03-02 06:42:14] [INFO] Searching bot binary...
[2019-03-02 06:42:14] [DEBUG] Searching in directory '/opt/ts3soundboard'...
[2019-03-02 06:42:14] [DEBUG] Binary 'sinusbot' found.
[2019-03-02 06:42:14] [INFO] Binary found.
[2019-03-02 06:42:14] [DEBUG] Collecting information...
[2019-03-02 06:42:14] [INFO] (Scan may take some moments...)
[2019-03-02 06:42:14] [INFO] Collecting system information...
[2019-03-02 06:42:14] [DEBUG] Getting operating system version...
[2019-03-02 06:42:14] [DEBUG] Checking DNS resolution...
[2019-03-02 06:42:15] [DEBUG] Checking web IPv4 access...
[2019-03-02 06:42:23] [ERROR] Contacting 'www.sinusbot.com' using IPv4-only mode failed: Please check for IPv4 connectivity, for any DNS resolution issues or possible firewall restrictions.
[2019-03-02 06:42:23] [DEBUG] Checking for locales...
[2019-03-02 06:42:23] [DEBUG] Getting processor information...
[2019-03-02 06:42:23] [DEBUG] Checking for available operating system updates...
[2019-03-02 06:42:24] [DEBUG] Getting RAM information...
[2019-03-02 06:42:24] [DEBUG] Getting SWAP information...
[2019-03-02 06:42:24] [DEBUG] Getting DISK information...
[2019-03-02 06:42:24] [DEBUG] Getting disk info by using command:
[2019-03-02 06:42:24] [DEBUG]  $ df -Tl --total -t ext4 -t ext3 -t ext2 -t reiserfs -t jfs -t ntfs -t fat32 -t btrfs -t fuseblk
[2019-03-02 06:42:24] [INFO] Collecting bot information...
[2019-03-02 06:42:24] [DEBUG] Trying to get SinusBot version using version parameter...
[2019-03-02 06:42:24] [DEBUG] Loading bot config file...
[2019-03-02 06:42:24] [DEBUG] Determining bot status...
[2019-03-02 06:42:24] [DEBUG] Reading ListenPort from bot configuration...
[2019-03-02 06:42:24] [DEBUG] Getting installed bot scripts...
[2019-03-02 06:42:24] [DEBUG] Reading LogLevel from bot configuration...
[2019-03-02 06:42:24] [DEBUG] Reading TS3Path from bot configuration...
[2019-03-02 06:42:24] [DEBUG] Trying to get ts3client version...
[2019-03-02 06:42:24] [DEBUG] Checking installation of bot plugin in ts3client...
[2019-03-02 06:42:24] [DEBUG] Checking for 'youtube-dl'...
[2019-03-02 06:42:27] [DEBUG] Generating output...
[CODE]
 - Kernel: Linux 3.16.0-7-amd64 x86_64
 - Load Average: 0.00 0.00 0.00
 - Uptime: 0 days, 1 hours, 50 minutes, 10 seconds
 - OS APT Last Update: 01.03.2019 23:04:05 EST -05:00:00
 - HTTPS check with IPv4 mode: FAILED  [Failed establishing connection to www.sinusbot.com, CODE #000]
    CPU(s):                1
    Thread(s) per core:    1
    Core(s) per socket:    1
    Socket(s):             1
    Model name:            Intel(R) Xeon(R) CPU E5-2630 v3 @ 2.40GHz
    CPU MHz:               2394.454
    Hypervisor vendor:     KVM
    Virtualization type:   full
 - RAM: 179.85 MB/1000.07 MB in use (17%)
 - DISK: 2.46 GB/27.54 GB in use (8%)
   + libglib: 2.42.1-1+b1
 - Webinterface: port locally not reachable (Port: 9000)
 - Binary: /opt/ts3soundboard/sinusbot
 - Binary Info: MD5 Hash: cc7e9b1c61045377b221302a86be605e, Perms: 755, User: sinusbot
 - Version: 1.0.0-alpha.6-a47ac17
   - TS3Path = /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.1.8)
   - YoutubeDLPath = /opt/ts3soundboard/youtube-dl (does exist, version: 2019.03.01)
 - Installed scripts: advertising.js; alonemode.js; bookmark.js; command.js; followme.js; norecording.js; rememberChannel.js; welcome.js; Youtube_Search.js
 - Time (local): 02.03.2019 06:42:25 EST -05:00:00
 - Time (remote): 02.03.2019 06:42:25 EST -05:00:00
 - Timezone: America/New_York
 - TeamSpeak 3 Version: 3.1.8
 - youtube-dl Version: 2019.03.01
 - DiagScript Version: 0.7.1
[2019-03-02 06:42:27] [DEBUG] Done.
[/CODE]
please help me? i don't understand
Rubynia
From ur Text:
Maybe try to allow in ur kvm/(V-)Server the ports for Sinusbot and check that ur KVM have internet conection, if on this run only the bot.
