Solved Prevent sinusbot from expiring or easy upgrade trick?
i am quite bad at linux and i dont like that im forced to upgrade sinusbot after some time.
Is there a way to remove the expiration and keep it working?
Or a easy way for it to automaticly upgrade and restart?
kanalumaddela
The latest Linux beta update comes with a feature to notify of new updates.
comes with a new auto-update mechanism, so that upcoming releases can be downloaded more bandwidth/server friendly. Once such an update is available, you will be notified about it on the web interface.
