[Problem] Sinusbot dosent play anything
Again ... no infos...
Which SinusBot version are you running? Which TS-Client version is running?
Most likely you run a ts version with an incompatible sinusbot version...
Current sinusbot version + 3.1.8 Client I know I should update my client version but is there another way ?
Another way would be if you start READING the messages other people write.
beta1-2 you should probably being able to run TS client 3.1.8-3.2.5 without problems...
You need 1.0.0beta2 or lower, since beta3 and higher only runs with ts 3.3.0
https://sinusbot.github.io/docs/installation/linux/#compatible-versions
Why do you want to run old TS-clients (with security bugs) anyway?
So I hope it's not like 90% of all "i use old version" and your versions isn't a cracked TS server. :rolleyes:
Just find a client version that's running with your server, and then install the fitting SinusBot version.
If you go with the FAQs, you should be able to do it manually.
AliHajipoor
I installed sinusbot version 1.0.0Beta2 + Client 3.0.18 but still have same problem (music bot dosent play anything)
3445
