Solved Problem to start the bot
Thank you for your attention!
It would be great if the bot would work ^^
No Problem, i updated my last poste please check the permissions and tell me the result :)
-rw-r--r--  1 ts3bot ts3bot      136 Dec 21 14:00 config.ini
-rw-r--r--  1 root   root        124 May 25  2015 config.ini.dist
drwxr-xr-x  7 ts3bot ts3bot     4096 Dec 21 13:39 data
-rwxr-xr-x  1 root   root   10910656 Jul  1 00:19 libavcodec.so.56
-rwxr-xr-x  1 root   root    1843856 Jul  1 00:19 libavformat.so.56
-rwxr-xr-x  1 root   root     311752 Jul  1 00:19 libavutil.so.54
-rwxr-xr-x  1 root   root     107992 Jul  1 00:19 libswresample.so.1
drwxr-xr-x  2 root   root       4096 Dec 21 13:41 plugin
-rw-r--r--  1 root   root       3228 May 25  2015 README.md
drwxr-xr-x  2 root   root       4096 Dec 21 13:41 scripts
-rwxr-xr-x  1 root   root   29446913 Nov 16 16:14 sinusbot
-rw-r--r--  1 root   root   10663084 Dec 21 13:36 sinusbot-0.9.8.tar.bz2
-rw-r--r--  1 root   root   14642923 Dec 21 13:40 sinusbot-0.9.9-8f70ff3.tar.bz2
drwxrwxr-x 12 root   root       4096 Dec 21 13:45 TeamSpeak3-Client-linux_amd64
-rwxr-xr-x  1 root   root   36639550 Oct 22 16:17 TeamSpeak3-Client-linux_amd64-3.0.18.2.run
-rwxr-xr-x  1 root   root   15056862 May 27  2015 ts3bot
Same problem :
Could not generate private key
Same problem :
Mhm yes, data and the config has ts3bot as user & group the other files root and i think the bot folder also root that can't work.
Run:
/opt/sinusbot - is the path to your bot
chown -R ts3bot:ts3bot /opt/sinusbot/
After this run the bot only as user 'ts3bot'. Keep in mind with the latest 0.9.9 you don't need the xinit stuff! Just run the bot with
./sinusbot
Oh nice! The bot started, but i can't access with webinterface :/
Version: 0.9.9-8f70ff3
2015/12/21 14:19:38 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin advertising.js
2015/12/21 14:19:38 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin aloneMode.js
2015/12/21 14:19:38 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin badchan.js
2015/12/21 14:19:38 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin bookmark.js
2015/12/21 14:19:38 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin covatar.js
2015/12/21 14:19:38 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin dev.js
2015/12/21 14:19:38 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin followme.js
2015/12/21 14:19:38 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin idle.js
2015/12/21 14:19:38 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin metadata.js
2015/12/21 14:19:38 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin norecording.js
2015/12/21 14:19:38 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin rememberChannel.js
2015/12/21 14:19:38 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin showcase.js
2015/12/21 14:19:38 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin welcometext.js
Generating new bot instance with account 'admin' and password 'foobar'
2015/12/21 14:19:38 X [MAIN] Starting up fake x-server...
2015/12/21 14:19:38 Updating database to v1... 0
2015/12/21 14:19:38 Updating database to v2... 1
2015/12/21 14:19:38 Updating database to v3... 2
2015/12/21 14:19:38 Updating database to v4... 3
2015/12/21 14:19:38 f1c19c9d          INFO   Loading instances
2015/12/21 14:19:38 f1c19c9d          INFO   Creating default instance
2015/12/21 14:19:38 f1c19c9d a12f5871 DEBUG  Spawning instance shortly due to missing configuration file.
2015/12/21 14:19:38 f1c19c9d a12f5871 INFO   Starting instance ts3server://127.0.0.1?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2015/12/21 14:19:38 X [MAIN] New connection
2015/12/21 14:19:38 f1c19c9d          INFO   Promoting instance to main instance
2015/12/21 14:19:38 f1c19c9d          INFO   Adding new user admin
2015/12/21 14:19:38 [GENERAL/FFMPEG ] INFO   FFmpeg/avcodec v3675236; license: LGPL version 2.1 or later; 494 codecs
2015/12/21 14:19:38 [GENERAL/FFMPEG ] INFO   FFmpeg/avformat v3674980; license: LGPL version 2.1 or later; 139 formats
2015/12/21 14:19:38 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2015/12/21 14:19:38 [GENERAL/RADIO  ] INFO   Could not find RadioStation-Data, updating...
2015/12/21 14:19:38 f1c19c9d a12f5871 INFO   TS>Crashdump ENABLED,  directory is: /opt/ts3soundboard/data/ts3/f1c19c9d-b392-42c4-ab42-d730ab340587/a12f5871-085c-4579-9267-6f56169f70e6/crashdumps
2015/12/21 14:19:38 f1c19c9d a12f5871 INFO   TS>DUMP defined! Dumpdir is: /opt/ts3soundboard/data/ts3/f1c19c9d-b392-42c4-ab42-d730ab340587/a12f5871-085c-4579-9267-6f56169f70e6/crashdumps
2015/12/21 14:19:38 f1c19c9d a12f5871 INFO   TS |INFO    |              |   |TeamSpeak 3 Client 3.0.18.2 (2015-10-22 11:14:48)
2015/12/21 14:19:38 f1c19c9d a12f5871 INFO   TS |INFO    |              |   |SystemInformation: Linux 3.16.0-4-amd64 #1 SMP Debian 3.16.7-ckt20-1+deb8u1 (2015-12-14) x86_64 Binary: 64bit
2015/12/21 14:19:38 f1c19c9d a12f5871 INFO   TS |INFO    |              |   |Using hardware aes
2015/12/21 14:19:38 f1c19c9d a12f5871 INFO   TS |ERROR   |SoundBckndIntf|   |libpulse.so.0: cannot open shared object file: No such file or directory
2015/12/21 14:19:38 f1c19c9d a12f5871 INFO   TS |ERROR   |SoundBckndIntf|   |libasound.so.2: cannot open shared object file: No such file or directory
2015/12/21 14:19:38 f1c19c9d a12f5871 INFO   TS |WARNING |SoundDevManager|   |Did not load any sound backends. No (usable) dynamic libraries found.
2015/12/21 14:19:38 f1c19c9d a12f5871 INFO   TS |INFO    |              |   |Loading plugin: libclientquery_plugin
2015/12/21 14:19:38 f1c19c9d a12f5871 INFO   TS |INFO    |              |   |Loading plugin: liblua_plugin
2015/12/21 14:19:38 f1c19c9d a12f5871 INFO   TS |INFO    |              |   |Loading plugin: libsoundbot_plugin
2015/12/21 14:19:38 f1c19c9d a12f5871 INFO   TS |INFO    |              |   |Loading plugin: libtest_plugin
2015/12/21 14:19:38 f1c19c9d a12f5871 INFO   TS |INFO    |Query         |   |listening on 127.0.0.1:25639
2015/12/21 14:19:39 X [MAIN] New connection
2015/12/21 14:19:39 f1c19c9d a12f5871 INFO   TS>ClientQueryPlugin: currentServerConnectionChanged 1 (0)
2015/12/21 14:19:39 f1c19c9d a12f5871 INFO   TS |INFO    |              |   |*** Time [MAINWINDOW]: 199
2015/12/21 14:19:39 f1c19c9d a12f5871 INFO   TS |INFO    |              |   |*** Time [INIT]: 200
2015/12/21 14:19:39 f1c19c9d a12f5871 INFO   TS |INFO    |ClientUI      |   |*** Time [SQLITE_CONVERTER]: 7
2015/12/21 14:19:39 f1c19c9d a12f5871 INFO   TS |INFO    |ClientUI      |   |Failed to init text to speech engine
2015/12/21 14:19:39 f1c19c9d a12f5871 INFO   TS |INFO    |ClientUI      |   |Qt version: 5.5.0
2015/12/21 14:19:39 f1c19c9d a12f5871 INFO   TS |INFO    |ClientUI      |   |Using configuration location: /opt/ts3soundboard/data/ts3/f1c19c9d-b392-42c4-ab42-d730ab340587/a12f5871-085c-4579-9267-6f56169f70e6/settings.db
2015/12/21 14:19:39 f1c19c9d a12f5871 INFO   TS |INFO    |ClientUI      |   |ts3server: 127.0.0.1?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2015/12/21 14:19:39 f1c19c9d a12f5871 INFO   TS |INFO    |ClientUI      |1  |Connect to server: 127.0.0.1
2015/12/21 14:19:39 f1c19c9d a12f5871 INFO   TS |INFO    |ClientUI      |1  |Blacklist check ok
2015/12/21 14:19:39 f1c19c9d a12f5871 INFO   TS |INFO    |ClientUI      |1  |Initiating connection: 127.0.0.1:9987 127.0.0.1
2015/12/21 14:19:39 f1c19c9d a12f5871 INFO   TS |INFO    |ClientUI      |1  |Connect status: Connecting
2015/12/21 14:19:39 f1c19c9d a12f5871 INFO   TS |DEVELOP |PktHandler    |   |Puzzle solve time: 6
2015/12/21 14:19:39 f1c19c9d a12f5871 INFO   TS |INFO    |ClientUI      |1  |Connect status: Connected
2015/12/21 14:19:39 f1c19c9d a12f5871 INFO   TS |INFO    |ClientUI      |1  |Connect status: Establishing connection
2015/12/21 14:19:39 f1c19c9d a12f5871 INFO   TS |INFO    |ClientUI      |1  |Connect status: Connection established
2015/12/21 14:19:39 f1c19c9d a12f5871 INFO   TS |INFO    |PermManager   |   |Requesting permissions from server
2015/12/21 14:19:39 f1c19c9d a12f5871 INFO   TS |INFO    |ClientUI      |   |Last update check was: Never
2015/12/21 14:19:39 f1c19c9d a12f5871 INFO   TS |INFO    |ClientUI      |   |Checking for update
2015/12/21 14:19:39 f1c19c9d a12f5871 INFO   TS |INFO    |Update        |   |Checking for updates...
2015/12/21 14:19:39 f1c19c9d a12f5871 INFO   TS |INFO    |Update        |   |Check license version: 1
2015/12/21 14:19:39 f1c19c9d a12f5871 INFO   TS |INFO    |LicenseViewer |   |License language: en
2015/12/21 14:19:39 f1c19c9d a12f5871 INFO   TS |INFO    |LicenseViewer |   |Requesting remote license for version 1 and language en
2015/12/21 14:19:40 f1c19c9d a12f5871 INFO   TS |INFO    |Newsticker    |   |Newsticker language change detected
2015/12/21 14:19:40 f1c19c9d a12f5871 INFO   TS |INFO    |Newsticker    |   |Newsticker next check:
2015/12/21 14:19:40 f1c19c9d a12f5871 INFO   TS |INFO    |Newsticker    |   |Newsticker received for language en, expires on Mon Dec 21 14:49:40 2015, next check in 1800 seconds
2015/12/21 14:19:40 f1c19c9d a12f5871 INFO   TS |INFO    |LicenseViewer |   |Downloaded license file for version 1 and language en
tracks 11007
2015/12/21 14:19:41 [GENERAL/RADIO  ] INFO   RadioStation data loaded
2015/12/21 14:19:41 [GENERAL/RADIO  ] INFO   Imported radio stations
2015/12/21 14:19:48 f1c19c9d a12f5871 WARN   Could not request shutdown. Please make sure that the loopback interface is not firewalled.
2015/12/21 14:19:49 X [MAIN] Disconnected:  1
2015/12/21 14:19:49 X [MAIN] Disconnected:  0
2015/12/21 14:19:49 f1c19c9d a12f5871 INFO   TS>qt.network.ssl: QSslSocket: cannot resolve SSLv2_client_method
2015/12/21 14:19:49 f1c19c9d a12f5871 INFO   TS>qt.network.ssl: QSslSocket: cannot resolve SSLv2_server_method
2015/12/21 14:19:49 f1c19c9d a12f5871 INFO   TSClient quit.
2015/12/21 14:20:07 f1c19c9d a12f5871 DEBUG  Storing configuration.
Then with http://myip:8087 :
504 Gateway Timeout
Gateway timeout expired while waiting for server response
I installed apache2, but same
504 Gateway Timeout
You don't need a external webserver, the Bot has its own.
Can you give me the IP to your Bot?
Try to shutdown apache / nginx if you don't need it.
And post please the result of:
netstat -tulpn
You want the IP to my VPS?
I stopped apache2.
Result of netstat -tulpn :
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:10011           0.0.0.0:*               LISTEN      431/ts3server_linux
tcp        0      0 0.0.0.0:30033           0.0.0.0:*               LISTEN      431/ts3server_linux
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      299/sshd
tcp6       0      0 :::22                   :::*                    LISTEN      299/sshd
udp        0      0 0.0.0.0:9987            0.0.0.0:*                           431/ts3server_linux
udp        0      0 0.0.0.0:68              0.0.0.0:*                           273/dhclient
udp        0      0 0.0.0.0:14614           0.0.0.0:*                           273/dhclient
udp6       0      0 :::18305                :::*                                273/dhclient
2015/12/21 14:39:27 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin advertising.js
2015/12/21 14:39:27 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin aloneMode.js
2015/12/21 14:39:27 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin badchan.js
2015/12/21 14:39:27 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin bookmark.js
2015/12/21 14:39:27 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin covatar.js
2015/12/21 14:39:27 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin dev.js
2015/12/21 14:39:27 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin followme.js
2015/12/21 14:39:27 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin idle.js
2015/12/21 14:39:27 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin metadata.js
2015/12/21 14:39:27 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin norecording.js
2015/12/21 14:39:27 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin rememberChannel.js
2015/12/21 14:39:27 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin showcase.js
2015/12/21 14:39:27 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin welcometext.js
2015/12/21 14:39:27 f1c19c9d          INFO   Initializing bot://f1c19c9d-b392-42c4-ab42-d730ab340587
2015/12/21 14:39:27 f1c19c9d          INFO   Loading instances
2015/12/21 14:39:27 f1c19c9d          INFO   Loading instance://a12f5871-085c-4579-9267-6f56169f70e6
2015/12/21 14:39:27 f1c19c9d a12f5871 INFO   Initialization complete
2015/12/21 14:39:27 [GENERAL/FFMPEG ] INFO   FFmpeg/avcodec v3675236; license: LGPL version 2.1 or later; 494 codecs
2015/12/21 14:39:27 [GENERAL/FFMPEG ] INFO   FFmpeg/avformat v3674980; license: LGPL version 2.1 or later; 139 formats
2015/12/21 14:39:27 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2015/12/21 14:39:27 X [MAIN] Starting up fake x-server...
2015/12/21 14:39:27 [GENERAL/RADIO  ] INFO   RadioStation data loaded
2015/12/21 14:39:27 [GENERAL/RADIO  ] INFO   Imported radio stations
After ./sinusbot and now i'm blocked, need to launch other terminal to do something on my debian.
Why it happened to me? :(
I launched in other terminal netstat -tulpn :
tcp6       0      0 :::8087                 :::*                    LISTEN        8701/sinusbot
This is normal, you need to run the bot in screen to keep it running if you disconnect from SSH.
I can reach your Bot. :)
Ok it work, my browser blocked some adresse. Thank a lot for your help guys, really nice and really good! I hope it will work!
Edit :But i don't understand what you said, i need to keep my terminal up to launch bot ?
Edit 2 : I can manage the bot with webinterface, but i don't see the bot on my ts3 client
Hi, i have new problem ^^
I can't use second instance on ts :
I have this when i want to start the bot :
2016/01/06 11:22:03 79fdf8de 07d5aa57 INFO   BOT-CONFIG [admin] NAME HOST CHAN CHANPW ANNOUNCE DESCRIPTION ANNOUNCESTR CC OK
2016/01/06 11:22:08 79fdf8de 07d5aa57 INFO   Starting instance ts3server://5.39.81.9?port=9987&nickname=Calogero&password=&channel=&channelpassword=
2016/01/06 11:22:08 X [MAIN] New connection
2016/01/06 11:22:08 79fdf8de 07d5aa57 INFO   TS>Crashdump ENABLED,  directory is: /opt/ts3soundboard/data/ts3/79fdf8de-53f6-4901-9510-4947d71ebb1c/07d5aa57-9aff-4de3-be15-6438c9a948cf/crashdumps
2016/01/06 11:22:08 79fdf8de 07d5aa57 INFO   TS>DUMP defined! Dumpdir is: /opt/ts3soundboard/data/ts3/79fdf8de-53f6-4901-9510-4947d71ebb1c/07d5aa57-9aff-4de3-be15-6438c9a948cf/crashdumps
2016/01/06 11:22:08 79fdf8de 07d5aa57 INFO   TS |INFO    |              |   |TeamSpeak 3 Client 3.0.18.2 (2015-10-22 11:14:48)
2016/01/06 11:22:08 79fdf8de 07d5aa57 INFO   TS |INFO    |              |   |SystemInformation: Linux 4.2.6-1-pve #1 SMP Sat Dec 19 15:42:50 CET 2015 x86_64 Binary: 64bit
2016/01/06 11:22:08 X [MAIN] Disconnected:  7
2016/01/06 11:22:08 79fdf8de 07d5aa57 INFO   TS |ERROR   |PulseAudio    |   |pa_context_connect failed
2016/01/06 11:22:08 79fdf8de 07d5aa57 INFO   TS>Breakpad crash /opt/ts3soundboard/data/ts3/79fdf8de-53f6-4901-9510-4947d71ebb1c/07d5aa57-9aff-4de3-be15-6438c9a948cf/crashdumps/461ebbc5-1fea-846c-566eed44-1f762be3.dmp
2016/01/06 11:22:08 79fdf8de 07d5aa57 INFO   TS>Starting Error Reporter: /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/error_report
2016/01/06 11:22:08 X [MAIN] Disconnected:  6
So the button become green on webinterface, but i don't see the music bot on teamspeak (of course i changed the ip address) and i want to shut down the bot and i have :
2016/01/06 11:40:06 79fdf8de 07d5aa57 WARN Could not request shutdown. Please make sure that the loopback interface is not firewalled.
2016/01/06 11:40:07 79fdf8de 07d5aa57 INFO KILL [admin] OK
