Solved Problem to start the bot
Duche
HI, when i want to execute the bot, i have this :
xinit: Unable to run program "/opt/ts3soundboard/ts3bot": No such file or directory
Specify a program on the command line or make sure that /usr/bin
is in your path.
Any idea?
Thanx
Duche
Thank you for you answer, and sorry.
So more information:
My linux version :
Linux localhost.localdomain 3.2.0-4-686-pae #1 SMP Debian 3.2.68-1+deb7u1 i686 GNU/Linux
8.0
Debian GNU/Linux 8 \n \l
Memory :
Total Width: 64 bits
Data Width: 64 bits
Form Factor: DIMM
Processor :
Version: Intel(R) Atom(TM) CPU N270 @ 1.60GHz
Config.ini :
My problem :
I wanted to launch the bot with
xinit /opt/ts3soundboard/ts3bot -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -ac
But it don't work :
is in your path.
Ask me for more information.
Thank you!
Edit : ok my processor is in 32 bits, i'm not sure but maybe it's the problem ?
Duche
Ok i tried with my VPS and it seems to work :
Generating new bot instance with account 'admin' and password 'foobar'
2015/12/21 11:11:08 Updating database to v1... 0
2015/12/21 11:11:08 Updating database to v2... 1
2015/12/21 11:11:08 Updating database to v3... 2
2015/12/21 11:11:08 7a202591 INFO Creating default instance
2015/12/21 11:11:08 7a202591 INFO Promoting instance to main instance
2015/12/21 11:11:08 7a202591 4b60424c INFO Starting instance ts3server://127.0.0.1?port=9987&nickname=TS3SB-Demobot&password=&channel=&channelpassword=
2015/12/21 11:11:08 7a202591 INFO Adding new useradmin
2015/12/21 11:11:08 FFmpeg/avcodec v3675236; license: LGPL version 2.1 or later; 494 codecs
2015/12/21 11:11:08 FFmpeg/avformat v3674980; license: LGPL version 2.1 or later; 139 formats
2015/12/21 11:11:08 Could not find RadioStation-Data, updating...
tracks 10809
2015/12/21 11:11:10 RadioStation data loaded
2015/12/21 11:11:11 Imported radio stations
2015/12/21 11:11:13 7a202591 4b60424c INFO TSClient quit.
I can't log in webinterface so i tried to do
xinit /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -ac
but i have :
/opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64: error while loading shared libraries: libquazip.so: cannot open shared object file: No such file or directory
Patschi
Is any firewall blocking the request or is maybe the entered IP wrong?
Patschi
I thought about an network issue, because you had any "504 Gateway timeout" error in your post above... but it seems that you just edited your post and removed that lines silently.
So... Which Debian version are you using? If you are using Debian Squeeze 6, so please update to a recent one. If you are using Wheezy 7 or Jessie 8, please use my diagnostic script here and post the output then.
Duche
Yes i have this when i try to go on webinterface :
504 Gateway Timeout
Gateway timeout expired while waiting for server response
I'm using Jessie 8, i will try your diagnostic, thank you!
Edit : log :
- Operating System: Debian GNU/Linux 8.2 (jessie)
- Load Average: 0.00 0.02 0.05
- Uptime: 0 days, 1 hours, 26 minutes, 26 seconds
- OS APT Last Update: 21.12.2015 10:38:59 CET +01:00:00
    CPU(s):                1
    Thread(s) per core:    1
    Core(s) per socket:    1
    Socket(s):             1
    Model name:            Intel Xeon E312xx (Sandy Bridge)
    CPU MHz:               2394.470
    Virtualization:        VT-x
    Hypervisor vendor:     KVM
    Virtualization type:   full
- RAM: 123.79 MB/1.91 GB in use (6%)
- SWAP: 0 B/0 B in use (%)
- DISK: 1.16 GB/8.22 GB in use (14%)
- Report date: 21.12.2015 11:50:23 CET +01:00:00 (timezone: )
- Binary: /opt/ts3soundboard/ts3bot (Hash: 3b2c7f99a3b0a358e7d328079c4fa8b8)
- Version: unknown
   - YoutubeDLPath = not set
- Installed Scripts: config.ini config.ini.dist data diagSinusbot.sh libavcodec.so.56 libavformat.so.56 libavutil.so.54 libswresample.so.1 plugin README.md sinusbot-0.9.8.tar.bz2 TeamSpeak3-Client-linux_amd64 TeamSpeak3-Client-linux_amd64-3.0.18.2.run ts3bot
GetMeOutOfHere
you cant connect because the bot is not running
Duche
If i start the bot with :
xinit /opt/ts3soundboard/ts3bot -RunningAsRootIsEvilAndIKnowThat -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -ac
i have :
2015/12/21 12:04:52 7a202591 INFO Initializing bot://7a202591-18bb-407a-a8b9-4d16299394b1
2015/12/21 12:04:52 7a202591 4b60424c INFO Loaded
2015/12/21 12:04:52 FFmpeg/avcodec v3675236; license: LGPL version 2.1 or later; 494 codecs
2015/12/21 12:04:52 FFmpeg/avformat v3674980; license: LGPL version 2.1 or later; 139 formats
2015/12/21 12:04:52 RadioStation data loaded
2015/12/21 12:04:52 Imported radio stations
Then nothing happened and i can't do anything
And always
504 Gateway Timeout
Duche
I upgrade to the latest Beta.
I extract the file and copy libsoundbot_plugin.so to TeamSpeak3-Client-linux_amd64/plugin
Maybe i forget something?
I'm new in Linux sorry for this
When i use ./sinusbot :
Version: 0.9.9-8f70ff3
Could not generate private key.
And always
504 Gateway Timeout
Please set LogLevel to 10 in your config.ini and post your logs.
You running a nginx or so in front of your Bot? I never seen a 504 from the bot self.
Duche
I haven't any server web do i need to install one?
In config.ini i have :
I need to add LogLevel=10?
Duche
LogLevel=10
An same problem : Could not generate private key.
And yes i follow the tutoriel
x11vnc xinit xvfb libxcursor1 ca-certificates bzip2 are installed.
I tried to install apache2, but it don't work
Okay moment i go to a short consultation with Flyth. :)
The Bot Folder has Permissions?
[faq=18][/faq]
