Acordi
Good Day
Hi i have an issue with my sinusbot,
I have 2 virtual servers on both i setup sinusbot but on the one it is using only about 300 MB ram in total and on the other virtual server it is using a bit more than 1 GB ram this is not normal right.
*And it is not that i am running more scripts on the one because i am actually running more scripts on the one that is using less ram.
I did htop in the console and got the following that will be attached, you can see there it is duplicating or something
BTW i installed on both server sinusbot the same way and same versions
