Hello!
I am submitting this report because i can't open "scripts" page in my sinusbot!
I always had a really good time using this bot but since 2 days ago i can't do anything.
Bot does spawn correctly but scripts not working. Tried with a fresh new installation (with no scripts in the folder but the default ones) but the problem persisted.
Tried deleting scripts folder with the default ones, but nothing happened.
Any ideas? If you need i can provide a video too but i think that's all!
DIAGNOSE SCRIPT OUTPUT (https://forum.sinusbot.com/threads/diagsinusbot-sh-sinusbot-diagnostic-script.831/)
Instance-Log OUTPUT
Bot Log Output
config.ini Output
- SinusBot version -->1.0.0-beta.10-202ee4d
- TS Client and Server version --> Client 3.3.2 Server 3.11.0 on Linux
- OS (operating system) --> Ubuntu 19.04
- hardware specs --> in the diagnose script output
- any browser.
- Operating System: Ubuntu 19.04
- Kernel: Linux 5.0.0-38-generic x86_64
- Load Average: 0.57 0.45 0.37
- Uptime: 0 days, 0 hours, 59 minutes, 33 seconds
- OS APT Last Update: 02.02.2020 11:27:50 CET +01:00:00
- Shell Locale: en_US.UTF-8
CPU(s): 4
Thread(s) per core: 1
Core(s) per socket: 4
Socket(s): 1
Model name: Intel(R) Xeon(R) CPU E5-2620 v3 @ 2.40GHz
CPU MHz: 2399.996
Hypervisor vendor: KVM
Virtualization type: full
- RAM: 1.03 GB/7.78 GB in use (13%)
- DISK: 58.51 GB/195.84 GB in use (29%)
- libglib: 2.60.4-0ubuntu0.19.04.1
- Status: running (PIDs: 7808 7801, User: sinusbot)
- Webinterface: port locally reachable (Port: 8088)
- YoutubeDLPath = not set
linux-vdso.so.1 (0x00007ffc09bb0000)
libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007f1a6e994000)
libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007f1a6e63c000)
libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007f1a6e23b000)
libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007f1a6d8d6000)
libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007f1a6d662000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f1a6d651000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f1a6d501000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f1a6d4e0000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f1a6d2fe000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f1a6d2e4000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f1a6d0f9000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f1a6d0dd000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f1a6d0d0000)
/lib64/ld-linux-x86-64.so.2 (0x00007f1a6ebb0000)
- Time (local): 02.02.2020 12:14:41 CET +01:00:00
- Time (remote): 02.02.2020 12:14:41 CET +01:00:00
- TeamSpeak3 Version: 3.3.2
- youtube-dl Version: unknown
Instance-Log OUTPUT
2020-02-02T12:21:07+01:00 imported module: command
2020-02-02T12:21:07+01:00 resolving module command
2020-02-02T12:21:07+01:00 script command loaded
2020-02-02T12:21:07+01:00 module registered as command
2020-02-02T12:21:07+01:00 registered callback for event chat
2020-02-02T12:21:07+01:00 Initialization complete
2020-02-02T12:21:07+01:00 script sinusbot-commands loaded
2020-02-02T12:21:07+01:00 registered callback for event load
2020-02-02T12:21:07+01:00 [sinusbot-commands:86:12] Loaded SinusBot Commands v1.0.0 by Jonas Bögle (@irgendwr).
2020-02-02T12:21:07+01:00 executing script command
2020-02-02T12:21:07+01:00 executing script sinusbot-commands
Bot Log Output
2020-02-02T12:21:07+01:00 Loading instance://6de2c431-06f0-4c75-a159-3901d36d6722
2020-02-02T12:21:07+01:00 Loading instances
config.ini Output
ListenPort = 8088
ExternalFileBase = ""
LicenseKey = "Daas95xmePmIkAPtHZH0xn9P8GL9pbXW0xWpckheHH4="
DevMode = false
[TTS]
Enabled = false
