Sinusbot a Vestacp
Manius
Hello! I installed the Vestacp panel, and then I got to the SinusBot and the problem is I can not run SinusBot, i.e. the page under the port: 8087 works, I have access but I can not connect to TS3 servos, which is on a different machine, and where it can be problem?
Manius
used version :
    0.14.3-0e747fd
    TeamSpeak 3 Version: 3.2.1
    3.5.0 (2018-10-26 08:48:07)Linux
used operating system:
 Debian GNU/Linux 8.11 (jessie)
hardware specs:
    CPU(s):                2
    Thread(s) per core:    1
    Core(s) per socket:    1
    Socket(s):             2
    Model name:            Intel(R) Xeon(R) CPU E5-2690 v2 @ 3.00GHz
    CPU MHz:               2992.788
    Virtualization:        VT-x
    Hypervisor vendor:     KVM
    Virtualization type:   full
- RAM: 1.28 GB/3.87 GB in use (33%)
- DISK: 4.14 GB/49.18 GB in use (8%)
   + libglib: 2.42.1-1+b1
used browser:
  Firefox 63.0.3 64bity
your config.ini:
    UseSSL = true
    SSLKeyFile = "/opt/sinusbot/ssl/privkey.pem"
    SSLCertFile = "/opt/sinusbot/ssl/fullchain.pem"
    LicenseKey = "GXO0FP+D1zgwjdnviAZ8ZRS0rtZTG7tNLHOJORISFiE="
      ChunkSize = 5242880
Logi:
  Version: 0.14.3-0e747fd
2018/11/25 08:15:06 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin advertising.js
2018/11/25 08:15:06 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin alonemode.js
2018/11/25 08:15:06 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin bookmark.js
2018/11/25 08:15:06 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin followme.js
2018/11/25 08:15:06 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin norecording.js
2018/11/25 08:15:06 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin rememberChannel.js
2018/11/25 08:15:06 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin welcome.js
2018/11/25 08:15:06 [GENERAL/SCRIPTS] INFO   Loading ScriptPlugin youtube.js
2018/11/25 08:15:09 9518118d          INFO   Loading instances
2018/11/25 08:15:10 9518118d          INFO   Loading instance://b5029325-ee1c-7ba0-a943-f8ea67e715c9
2018/11/25 08:15:10 9518118d b5029325 INFO   Initialization complete
2018/11/25 08:15:10 9518118d          INFO   Loading instance://8ad285c0-7926-44ef-bd1f-a80e11a14200
2018/11/25 08:15:10 9518118d 8ad285c0 INFO   Loading script youtube
2018/11/25 08:15:10 9518118d 8ad285c0 PLUGIN youtube   :49   YTWeb Webinterface Ready
2018/11/25 08:15:10 getSearchResult handler registered
2018/11/25 08:15:11 9518118d 8ad285c0 INFO   Initialization complete
2018/11/25 08:15:11 9518118d          INFO   Loading instance://57ab3c44-ee59-d8e8-061f-9bee8e51edd2
2018/11/25 08:15:11 9518118d 57ab3c44 INFO   Loading script youtube
2018/11/25 08:15:11 9518118d 57ab3c44 PLUGIN youtube   :49   YTWeb Webinterface Ready
2018/11/25 08:15:11 getSearchResult handler registered
2018/11/25 08:15:14 9518118d 57ab3c44 INFO   Initialization complete
2018/11/25 08:15:14 9518118d          INFO   Loading instance://d218939f-7ebb-2ecd-dc46-3efcd08ed072
2018/11/25 08:15:14 9518118d d218939f INFO   Initialization complete
2018/11/25 08:15:14 9518118d          INFO   Loading instance://fcebe3e4-15e8-dd51-21b7-e2970527dd1d
2018/11/25 08:15:14 9518118d fcebe3e4 INFO   Loading script youtube
2018/11/25 08:15:14 9518118d fcebe3e4 PLUGIN youtube   :49   YTWeb Webinterface Ready
2018/11/25 08:15:14 getSearchResult handler registered
2018/11/25 08:15:15 9518118d fcebe3e4 INFO   Initialization complete
2018/11/25 08:15:15 9518118d          INFO   Loading instance://cfc301e0-1dc3-3ec1-fcbe-19a72df71ef1
2018/11/25 08:15:15 9518118d cfc301e0 INFO   Initialization complete
2018/11/25 08:15:15 9518118d          INFO   Loading instance://6787823e-8853-c3fc-6797-b0e2b31504b7
2018/11/25 08:15:15 9518118d 6787823e INFO   Initialization complete
2018/11/25 08:15:15 [GENERAL/FFMPEG ] INFO   FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2018/11/25 08:15:15 [GENERAL/FFMPEG ] INFO   FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2018/11/25 08:15:15 [GENERAL/YTDL   ] INFO   youtube-dl checking...
2018/11/25 08:15:16 [GENERAL/YTDL   ] INFO   youtube-dl version compatible, support enabled
2018/11/25 08:15:16 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://31.133.0.215:8087
2018/11/25 08:15:16 Adding youtube web script @ /opt/sinusbot/scripts/youtube/html
2018/11/25 08:15:16 [GENERAL/RADIO  ] INFO   RadioStation data loaded
2018/11/25 08:15:16 [GENERAL/RADIO  ] INFO   Imported radio stations
2018/11/25 08:15:43 9518118d 8ad285c0 DEBUG  Prespawn.
2018/11/25 08:15:43 9518118d 8ad285c0 DEBUG  About to run.
2018/11/25 08:15:43 9518118d 8ad285c0 WARN   Could not create Chat-Tabletable Chat already exists
2018/11/25 08:15:43 9518118d 8ad285c0 WARN   Could not create WhisperReceive-Tabletable WhisperReceive already exists
2018/11/25 08:15:43 9518118d 8ad285c0 WARN   Could not create Notifications-Tabletable Notifications already exists
2018/11/25 08:15:43 9518118d 8ad285c0 DEBUG  Could not delete from FileTransferno such table: FileTransfer
2018/11/25 08:15:43 9518118d 8ad285c0 DEBUG  Could not insert into FileTransfer-Tableno such table: FileTransfer
2018/11/25 08:15:44 9518118d 8ad285c0 INFO   Starting instance ts3server://ts24h.pl?port=9987&nickname=TS24H.PL%C2%AE%20Witamy&password=&channel=&channelpassword=
2018/11/25 08:15:44 X [MAIN] New connection
2018/11/25 08:15:45 9518118d 8ad285c0 DEBUG  TS>Crashdump ENABLED,  directory is: /opt/sinusbot/data/ts3/9518118d-a61e-4568-bac1-0b2ee552ad7f/8ad285c0-7926-44ef-bd1f-a80e11a14200/crashdumps
2018/11/25 08:15:45 9518118d 8ad285c0 DEBUG  TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/9518118d-a61e-4568-bac1-0b2ee552ad7f/8ad285c0-7926-44ef-bd1f-a80e11a14200/crashdumps
2018/11/25 08:15:45 X [MAIN] New connection
2018/11/25 08:15:45 9518118d 8ad285c0 INFO   TS |INFO    |              |   |TeamSpeak 3 Client 3.2.1 (2018-08-14 14:00:36)
2018/11/25 08:15:45 9518118d 8ad285c0 INFO   TS |INFO    |              |   |SystemInformation: Linux 3.16.0-4-amd64 #1 SMP Debian 3.16.51-3 (2017-12-13) x86_64 Binary: 64bit
2018/11/25 08:15:45 9518118d 8ad285c0 INFO   TS |INFO    |              |   |Using hardware aes
2018/11/25 08:15:45 9518118d 8ad285c0 INFO   TS |ERROR   |SoundBckndIntf|   |libpulse.so.0: cannot open shared object file: No such file or directory
2018/11/25 08:15:45 9518118d 8ad285c0 INFO   TS |INFO    |ClientUI      |   |Unable to create an Open GL context.
2018/11/25 08:15:45 9518118d 8ad285c0 INFO   TS |ERROR   |RevocationListCache|   |Failed to import revocation list from cache
2018/11/25 08:15:45 9518118d 8ad285c0 INFO   TS |INFO    |Addons        |   |Checking for addon updates...
2018/11/25 08:15:45 9518118d 8ad285c0 INFO   TS |INFO    |              |   |successfully downloaded revocation list for myteamspeak id
2018/11/25 08:15:45 9518118d 8ad285c0 INFO   TS |INFO    |              |   |successfully downloaded revocation list for accounting
2018/11/25 08:15:45 9518118d 8ad285c0 INFO   TS |INFO    |Plugins       |   |Loading plugin: libsoundbot_plugin.so
2018/11/25 08:15:47 9518118d 8ad285c0 WARN   Could not send var command: HTTP returned an error: Error; Code: 500; Message: Error
2018/11/25 08:15:47 9518118d 8ad285c0 WARN   Could not send config: HTTP returned an error: Error; Code: 500; Message: Error
2018/11/25 08:15:50 9518118d 8ad285c0 INFO   TS |INFO    |              |   |*** Time [CONTACTS]: 1805
2018/11/25 08:15:51 9518118d 8ad285c0 INFO   TS |INFO    |              |   |*** Time [MAINWINDOW]: 1942
2018/11/25 08:15:51 9518118d 8ad285c0 INFO   TS |INFO    |              |   |*** Time [INIT]: 1942
2018/11/25 08:15:51 9518118d 8ad285c0 INFO   TS |DEVELOP |ClientUI      |   |Notifications init: Soundpack path: /opt/sinusbot/teamspeak3-client/sound/nosounds
2018/11/25 08:15:51 9518118d 8ad285c0 INFO   TS |INFO    |ClientUI      |   |Failed to init text to speech engine
2018/11/25 08:15:51 9518118d 8ad285c0 INFO   TS |INFO    |ClientUI      |   |Qt version: 5.6.1
2018/11/25 08:15:51 9518118d 8ad285c0 INFO   TS |INFO    |ClientUI      |   |Using configuration location: /opt/sinusbot/data/ts3/9518118d-a61e-4568-bac1-0b2ee552ad7f/8ad285c0-7926-44ef-bd1f-a80e11a14200/settings.db
2018/11/25 08:15:51 9518118d 8ad285c0 INFO   TS |INFO    |ClientUI      |   |ts3server: ts24h.pl?port=9987&nickname=TS24H.PL%C2%AE%20Witamy&password=&channel=&channelpassword=
2018/11/25 08:15:51 9518118d 8ad285c0 INFO   TS |INFO    |ClientUI      |1  |Connect to server: ts24h.pl
2018/11/25 08:15:51 9518118d 8ad285c0 INFO   TS |INFO    |ClientUI      |1  |Trying to resolve ts24h.pl
2018/11/25 08:15:51 9518118d 8ad285c0 INFO   TS |INFO    |TSDNS         |   |A/AAAA DNS resolve successful, "ts24h.pl" =(h: 31.133.0.215 p:0)
2018/11/25 08:15:51 9518118d 8ad285c0 INFO   TS |INFO    |TSDNS         |   |A/AAAA DNS resolve for possible TSDNS successful, "ts24h.pl" =(h: 31.133.0.215 p:0)
2018/11/25 08:15:51 9518118d 8ad285c0 INFO   TS |INFO    |TSDNS         |   |SRV DNS resolve successful, "_ts3._udp.ts24h.pl" =(h: ts3.ts24h.pl p:9987)
2018/11/25 08:15:51 9518118d 8ad285c0 INFO   TS |INFO    |TSDNS         |   |TSDNS queried unsuccessfully 31.133.0.215:41144
2018/11/25 08:15:51 9518118d 8ad285c0 INFO   TS |INFO    |TSDNS         |   |No TSDNS found
2018/11/25 08:15:51 9518118d 8ad285c0 INFO   TS |INFO    |TSDNS         |   |SRV DNS resolve successful, "_tsdns._tcp.ts24h.pl" =(h: tsdns.ts3.ts24h.pl p:41144)
2018/11/25 08:15:51 9518118d 8ad285c0 INFO   TS |INFO    |TSDNS         |   |A/AAAA DNS resolve successful, "ts3.ts24h.pl" =(h: 178.217.186.149 p:0)
2018/11/25 08:15:51 9518118d 8ad285c0 INFO   TS |INFO    |ClientUI      |1  |Lookup finished: ip=178.217.186.149 port=9987 query=ts24h.pl error=0
2018/11/25 08:15:51 9518118d 8ad285c0 INFO   TS |INFO    |ClientUI      |1  |Resolve successful: 178.217.186.149:9987
2018/11/25 08:15:51 9518118d 8ad285c0 INFO   TS |INFO    |ClientUI      |1  |Initiating connection: 178.217.186.149:9987
2018/11/25 08:15:52 9518118d 8ad285c0 INFO   TS |INFO    |PreProSpeex   |1  |Speex version: 1.2rc1
2018/11/25 08:15:52 9518118d 8ad285c0 INFO   TS |INFO    |ClientUI      |1  |Connect status: Connecting
2018/11/25 08:15:52 9518118d 8ad285c0 INFO   TS |INFO    |Bookmarks     |   |Collecting autoconnect bookmarks
2018/11/25 08:15:52 9518118d 8ad285c0 INFO   TS |INFO    |ClientUI      |   |Last update check was: Tue Jan 1 00:00:01 2019
2018/11/25 08:15:52 9518118d 8ad285c0 INFO   TS |INFO    |              |   |Statistics report: User has not yet confirmed participation
2018/11/25 08:15:52 9518118d 8ad285c0 INFO   New connection status 1; Error 0
2018/11/25 08:15:57 9518118d 8ad285c0 INFO   TS |INFO    |ClientUI      |1  |Connect status: Disconnected
2018/11/25 08:15:57 9518118d 8ad285c0 INFO   TS |INFO    |ClientUI      |1  |Failed to connect to server, want autoreconnect = 0
2018/11/25 08:15:57 9518118d 8ad285c0 INFO   The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation or the password is wrong , the security level of your identity is too low or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2018/11/25 08:15:57 9518118d 8ad285c0 INFO   New connection status 0; Error 1797
2018/11/25 08:15:58 9518118d 8ad285c0 DEBUG  TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2018/11/25 08:15:58 9518118d 8ad285c0 DEBUG  TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2018/11/25 08:15:58 9518118d 8ad285c0 INFO   TSClient quit.
2018/11/25 08:15:58 9518118d 8ad285c0 DEBUG  TS>libpng warning: iCCP: known incorrect sRGB profile
2018/11/25 08:15:58 9518118d 8ad285c0 DEBUG  Closed.
2018/11/25 08:16:10 9518118d 8ad285c0 DEBUG  Storing configuration.
2018/11/25 08:16:23 [GENERAL        ] Shutting down... Hold on...
Logi diagnostic:
[2018-11-25 07:55:52] [INFO] Starting diagSinusbot v0.7.1 [2018-05-23 22:20 UTC]...
[2018-11-25 07:55:52] [INFO] Checking for new diagnostic script version...
[2018-11-25 07:55:52] [OKAY] You are using the latest version.
[2018-11-25 07:55:52] [INFO] Detected operating system: Debian GNU/Linux 8.11 (jessie)
[2018-11-25 07:55:52] [INFO] Searching bot binary...
[2018-11-25 07:55:52] [DEBUG] Searching in directory '/opt/sinusbot'...
[2018-11-25 07:55:52] [DEBUG] Binary 'sinusbot' found.
[2018-11-25 07:55:52] [INFO] Binary found.
[2018-11-25 07:55:53] [DEBUG] Collecting information...
[2018-11-25 07:55:53] [INFO] (Scan may take some moments...)
[2018-11-25 07:55:53] [INFO] Collecting system information...
[2018-11-25 07:55:53] [DEBUG] Getting operating system version...
[2018-11-25 07:55:53] [DEBUG] Checking DNS resolution...
[2018-11-25 07:55:53] [DEBUG] Checking web IPv4 access...
[2018-11-25 07:55:53] [DEBUG] Checking for locales...
[2018-11-25 07:55:53] [DEBUG] Getting processor information...
[2018-11-25 07:55:53] [DEBUG] Checking for available operating system updates...
[2018-11-25 07:55:53] [DEBUG] Getting RAM information...
[2018-11-25 07:55:54] [DEBUG] Getting SWAP information...
[2018-11-25 07:55:54] [DEBUG] Getting DISK information...
[2018-11-25 07:55:54] [DEBUG] Getting disk info by using command:
[2018-11-25 07:55:54] [DEBUG]  $ df -Tl --total -t ext4 -t ext3 -t ext2 -t reiserfs -t jfs -t ntfs -t fat32 -t btrfs -t fuseblk
[2018-11-25 07:55:54] [INFO] Collecting bot information...
[2018-11-25 07:55:54] [DEBUG] Trying to get SinusBot version using version parameter...
[2018-11-25 07:55:54] [DEBUG] Loading bot config file...
[2018-11-25 07:55:54] [DEBUG] Determining bot status...
[2018-11-25 07:55:54] [DEBUG] Reading ListenPort from bot configuration...
[2018-11-25 07:55:54] [DEBUG] Getting installed bot scripts...
[2018-11-25 07:55:54] [DEBUG] Reading LogLevel from bot configuration...
[2018-11-25 07:55:54] [DEBUG] Reading TS3Path from bot configuration...
[2018-11-25 07:55:54] [DEBUG] Trying to get ts3client version...
[2018-11-25 07:55:54] [DEBUG] Checking installation of bot plugin in ts3client...
[2018-11-25 07:55:54] [DEBUG] Checking for 'youtube-dl'...
xxd: sorry cannot seek.
[2018-11-25 07:55:57] [ERROR] Failed trieving remote time from NTP server time.google.com! Is any firewall blocking the NTP request, or is the DNS resolution failing?
[2018-11-25 07:55:57] [DEBUG] Generating output...
- Load Average: 2.14 2.08 2.08
- Uptime: 0 days, 11 hours, 27 minutes, 43 seconds
- OS APT Last Update: 25.11.2018 04:50:01 UTC +00:00:00
    CPU(s):                2
    Socket(s):             2
    CPU MHz:               2992.788
- Version: 0.14.3-0e747fd
   - TS3Path = /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64 (Version 3.2.1)
   - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2018.11.23)
- Installed scripts: advertising.js; alonemode.js; bookmark.js; followme.js; norecording.js; rememberChannel.js; welcome.js; youtube.js
- Time (local): 25.11.2018 07:55:55 UTC +00:00:00
- Timezone: Etc/UTC
- TeamSpeak 3 Version: 3.2.1
- youtube-dl Version: 2018.11.23
- DiagScript Version: 0.7.1
Please check this:
Manius
Well, I know, but why? As everything else works, i.e. other server bots and IPs added to the whitelist ...
in 99% the IP or UID of the Sinusbot is in the Ban List, it also may be possible that the other hosting Provider blocks the IP of your Host
is the TeamSpeak Server you are connecting to your Server?
is the Bot you try to connect with a instance with the extended License?
Manius
so does the bot show up for a split second on your server and instantly disconnects?
Manius
Hello! The problem is that it does not appear on the server at all ... And I have it on the same server, i.e. M-bot, and normally connects to this sev teamspeak from the same server where the server with a sinusbot is
Sinusbot does not use query, it uses a TeamSpeak Client to connect, so you dont need to put him inside a query_whitelist or what so ever
just check if the bot is not banned, you are connecting to the right ip address, the hoster is not blocking the IP from where you are connecting from, the security level is high enough
