SinusBot bot does not connect to TS3
David1981
Hello, I want to connect the radio to ts3 and no bot can connect .Here I have a complete list of what it says, I'm really at the bottom of it .So far everything has worked as it should but the bot does not connect. It's been a week thank you very much for any advice . David
2021-12-05T21:42:53+01:00 Storing configuration.
2021-12-05T21:42:48+01:00 closing channels
2021-12-05T21:42:47+01:00 TSClient quit.
2021-12-05T21:42:47+01:00 Closed.
2021-12-05T21:42:47+01:00 TS>libpng warning: iCCP: known incorrect sRGB profile
2021-12-05T21:42:47+01:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2021-12-05T21:42:47+01:00 TS>QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-sinusbot'
2021-12-05T21:42:47+01:00 TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present
2021-12-05T21:42:47+01:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2021-12-05T21:42:46+01:00 New connection status 0; Error 1797
2021-12-05T21:42:46+01:00 The bot could not connect. This might have several reasons: the server doesn't exist at that address, the server password is wrong, the default channel doesn't exist, the bot has been banned, the server is an illegal installation, the password is wrong, the security level of your identity is too low, the nickname is too short or too long or the server does not allow the version of the client you are using. See our Wiki / Forums for more help.
2021-12-05T21:42:46+01:00 TS |INFO |ClientUI |1 |Failed to connect to server, want autoreconnect = 0
2021-12-05T21:42:46+01:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2021-12-05T21:42:42+01:00 Already online.
2021-12-05T21:42:42+01:00 Prespawn.
2021-12-05T21:42:41+01:00 TS |INFO | | |Statistics report: User has not yet confirmed participation
2021-12-05T21:42:41+01:00 TS |INFO |ClientUI | |Last update check was: Sat Jan 1 00:00:01 2022
2021-12-05T21:42:41+01:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2021-12-05T21:42:41+01:00 New connection status 1; Error 0
MauriceR
Most of the times the security level of the identity is not high enough...
