Hallo zusammen,
ich habe heute mal meinen sinusbot mit samt dem Teamspeak client geupdatet. Nachdem der Bot ganz normal startet und man dann auf connect geht kommt folgendes. Der Bot connected auch nicht auf den Teamspeak
Meine frage wie kann ich den Fehler beheben?
Mfg
Acesaft
2019/09/28 16:00:03 7ae55ff0 INFO Loading instances
2019/09/28 16:00:03 7ae55ff0 INFO Loading instance://991334f1-c45c-4ec7-8df3-f1e9b2309fe6
2019/09/28 16:00:03 7ae55ff0 991334f1 INFO Initialization complete
2019/09/28 16:00:03 7ae55ff0 INFO Loading instance://062f237b-e9c4-4430-9421-76498ef13586
2019/09/28 16:00:03 7ae55ff0 062f237b INFO Initialization complete
2019/09/28 16:00:03 7ae55ff0 062f237b INFO Last track was 530cd6bc-9f0c-49e0-9dec-04295dcfb5c9, will auto-play soon
2019/09/28 16:00:03 [GENERAL/FFMPEG ] INFO FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2019/09/28 16:00:03 [GENERAL/FFMPEG ] INFO FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2019/09/28 16:00:03 [GENERAL/YTDL ] INFO youtube-dl checking...
2019/09/28 16:00:04 7ae55ff0 062f237b INFO Auto-Playing last track
2019/09/28 16:00:04 [GENERAL/YTDL ] INFO youtube-dl version compatible, support enabled
2019/09/28 16:00:04 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2019/09/28 16:00:05 [GENERAL/RADIO ] INFO RadioStation data loaded
2019/09/28 16:00:05 [GENERAL/RADIO ] INFO Imported radio stations
2019/09/28 16:00:05 [AUDIOPROXY ] Streaming http://stream.laut.fm/sockenschuss-x
2019/09/28 16:00:06 7ae55ff0 062f237b DEBUG New channel 530cd6bc-9f0c-49e0-9dec-04295dcfb5c9 () ID e9f4ba66-ff70-444e-aa5b-f1064725e5a5 (cc 0)
2019/09/28 16:00:06 7ae55ff0 062f237b DEBUG new track info: Epic Music (45706963204d75736963)
2019/09/28 16:00:06 7ae55ff0 062f237b DEBUG Prespawn.
2019/09/28 16:00:06 7ae55ff0 062f237b DEBUG About to run.
2019/09/28 16:00:06 7ae55ff0 062f237b WARN Could not delete from Applicationno such table: Application
2019/09/28 16:00:06 7ae55ff0 062f237b WARN Could not insert into Application-Tableno such table: Application
2019/09/28 16:00:06 7ae55ff0 062f237b DEBUG Could not delete from FileTransferno such table: FileTransfer
2019/09/28 16:00:06 7ae55ff0 062f237b DEBUG Could not insert into FileTransfer-Tableno such table: FileTransfer
2019/09/28 16:00:06 7ae55ff0 062f237b WARN Could not delete from Profilesno such table: Profiles
2019/09/28 16:00:06 7ae55ff0 062f237b WARN Could not insert into Profiles-Tableno such table: Profiles
2019/09/28 16:00:06 7ae55ff0 062f237b DEBUG Could not delete from Newsno such table: News
2019/09/28 16:00:06 7ae55ff0 062f237b DEBUG Could not insert into News-Tableno such table: News
2019/09/28 16:00:06 7ae55ff0 062f237b INFO Starting instance ts3server://Hierkönnteihreipstehen?port=9987&nickname=%28%E2%80%A2_%E2%80%A2%29%20HBO%20BOT%20%28%E2%80%A2_%E2%80%A2%29&password=&cid=40&channelpassword=
2019/09/28 16:00:06 X [MAIN] New connection
- Kernel: Linux 4.4.0-042stab127.2 x86_64
- Load Average: 0.03 0.05 0.02
- Uptime: 463 days, 1 hours, 14 minutes, 50 seconds
- OS Updates: 0
- OS APT Last Update: 27.09.2019 00:12:03 UTC +00:00:00
- Shell Locale: en_US.UTF-8
- Bot Start Script: found at /etc/systemd/system/sinusbot.service [perms: 644]
- RAM: B/8.00 GB in use (%)
- SWAP: B/ B in use (%)
- DISK: 64.97 GB/393.59 GB in use (16%)
- libglib: 2.48.2-0ubuntu4.4
- TS3Path = /opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.3.0)
- YoutubeDLPath = /opt/sinusbot/youtube-dl (does exist, version: 2018.11.07)
- Installed scripts: *.js
linux-vdso.so.1 => (0x00007fffa85ed000)
libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007fc946fae000)
libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007fc946c56000)
libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007fc946855000)
libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007fc945eef000)
libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007fc945c7b000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fc945a69000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fc94575f000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fc945542000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fc9451c0000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fc944fa9000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fc944bdf000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fc9449c5000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007fc9447bc000)
/lib64/ld-linux-x86-64.so.2 (0x00005619fe83c000)
- Time (local): 28.09.2019 16:14:02 UTC +00:00:00
- Timezone: Etc/UTC
- TeamSpeak3 Version: 3.3.0
- youtube-dl Version: 2018.11.07
Mfg
Acesaft
