Sinusbot does not recognise commands
owzyyy
Hello
i installed Sinusbot on my new VPS using the installation script as usual. Everything works perfectly, but the bot does not recognise any commands. I have also updated all the scripts, but it still doesn't work. I don't know what to do. Maybe someone here has an idea.
pls check vers.
and if you have settings enabled to see feedback
ex:
Command Library 1.4.4 by Multivitamin <david.kartnaller at g00g73.com> (command) -​
Library to handle and manage commands
Send a message if no command has been found?
YES
Debug Messages (default is INFO)
INFO
SinusBot Commands 1.1.2 by Jonas Bögle @irgendwr (sinusbot-commands)​
Enables the default commands.
Disable the default SinusBot commands.
Add a reaction to each command if it was successfull.
Show discord settings
and if you want the oklib
OKlib 1.0.8 by Tuetchen || Smorrebrod || Cedrik <cedrik.paetz at g00g73.com> && Diesmon || Dimos <dontmindme12 at vväb.de> (OKlib) -​
A lib that is OK.
Sets a global debug log level for all scripts that use this lib. The logs will be displayed in the instance log.
3 - Missing items
Morning.
After 9 Hours, I got tired and y33ted the bot from the discord. It just refuses to listen to any command I give it. Even the simple playing command just does not want to recognise.
If I dm the bot privately, it works ( for 5% of the time ) and the bot sees me as its slave, but on Discord itself in a server, it has a mind of its own. When forced rebooted, the CSS completely breaks off sinusbot and a forced server boot needs to occur to get all bots back online..
Questions that staff prob will ask me
  1. Yes, I updated everything to the latest version.
  2. Yes, I host it myself. (through a partner [REDACTED] )
  3. No, nothing needs to be updated.
  4. no, I don't share/give login details. You also don't share your PIN with anyone else...
  5. Logs are fine, nothing to be seen on it that could give an optional solution.
  6. Got 5 Gigs of space for music, but doubt that would be the cause.
