DomsimirDuo
Hallo.
Als ich meinen TS neugestartet habe, waren alle Bots gemuted. Es waren keine Lautsprecher und kein Mikrofon beim Bot aktiviert.
Hier die infos:
2019/07/21 10:34:08 64dbfc61 INFO Loading instances
2019/07/21 10:34:08 64dbfc61 INFO Loading instance://66bb1a49-0a8a-4806-a7ab-35c7380b84b1
2019/07/21 10:34:08 64dbfc61 66bb1a49 INFO Initialization complete
2019/07/21 10:34:08 64dbfc61 66bb1a49 INFO Auto-Starting 64dbfc61-163a-4f7b-9592-d90b5162654f/66bb1a49-0a8a-4806-a7ab-35c7380b84b1 in 500 ms...
2019/07/21 10:34:08 [GENERAL/FFMPEG ] INFO FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2019/07/21 10:34:08 [GENERAL/FFMPEG ] INFO FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2019/07/21 10:34:08 [GENERAL/YTDL ] INFO youtube-dl checking...
2019/07/21 10:34:08 64dbfc61 66bb1a49 INFO script command loaded
2019/07/21 10:34:08 64dbfc61 66bb1a49 WARN Could not create Chat-Tabletable Chat already exists
2019/07/21 10:34:08 64dbfc61 66bb1a49 WARN Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019/07/21 10:34:08 64dbfc61 66bb1a49 WARN Could not create Notifications-Tabletable Notifications already exists
2019/07/21 10:34:09 64dbfc61 66bb1a49 INFO Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019/07/21 10:34:09 X [MAIN] New connection
2019/07/21 10:34:09 64dbfc61 66bb1a49 INFO TS |INFO | | |TeamSpeak 3 Client 3.1.8 (2018-01-22 09:50:07)
2019/07/21 10:34:09 64dbfc61 66bb1a49 INFO TS |INFO | | |SystemInformation: Linux 2.6.32-042stab138.1 #1 SMP Wed May 15 09:33:10 MSK 2019 x86_64 Binary: 64bit
2019/07/21 10:34:09 64dbfc61 66bb1a49 INFO TS |INFO | | |Using hardware aes
2019/07/21 10:34:09 64dbfc61 66bb1a49 INFO TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2019/07/21 10:34:09 64dbfc61 66bb1a49 INFO TS |INFO |ClientUI | |Unable to create an Open GL context.
2019/07/21 10:34:09 64dbfc61 66bb1a49 INFO TS |INFO |Addons | |Checking for addon updates...
2019/07/21 10:34:09 64dbfc61 66bb1a49 INFO TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2019/07/21 10:34:09 64dbfc61 66bb1a49 INFO TS |INFO |Plugins | |Api version is not compatible for plugin: /opt/SinusPort-8881/TeamSpeak3-Client-linux_amd64/plugins/libsoundbot_plugin.so
2019/07/21 10:34:09 64dbfc61 66bb1a49 INFO TS |INFO | | |successfully downloaded revocation list
2019/07/21 10:34:09 64dbfc61 66bb1a49 INFO TS |INFO | | |*** Time [MAINWINDOW]: 148
2019/07/21 10:34:09 64dbfc61 66bb1a49 INFO TS |INFO | | |*** Time [INIT]: 149
2019/07/21 10:34:09 64dbfc61 66bb1a49 INFO TS |DEVELOP |ClientUI | |Notifications init: Soundpack path: /opt/SinusPort-8881/TeamSpeak3-Client-linux_amd64/sound/nosounds
2019/07/21 10:34:09 64dbfc61 66bb1a49 INFO TS |INFO |ClientUI | |Failed to init text to speech engine
2019/07/21 10:34:09 64dbfc61 66bb1a49 INFO TS |INFO |ClientUI | |Qt version: 5.6.1
2019/07/21 10:34:09 64dbfc61 66bb1a49 INFO TS |INFO |ClientUI | |Using configuration location: /opt/SinusPort-8881/data/ts3/64dbfc61-163a-4f7b-9592-d90b5162654f/66bb1a49-0a8a-4806-a7ab-35c7380b84b1/settings.db
2019/07/21 10:34:09 64dbfc61 66bb1a49 INFO TS |INFO |ClientUI | |ts3server: 127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019/07/21 10:34:09 64dbfc61 66bb1a49 INFO TS |INFO |ClientUI |1 |Connect to server: 127.0.0.1
2019/07/21 10:34:09 64dbfc61 66bb1a49 INFO TS |INFO |ClientUI |1 |Initiating connection: 127.0.0.1:9987
2019/07/21 10:34:09 64dbfc61 66bb1a49 INFO TS |INFO |PlaySoundSet | |Found invalid playback device 'SinusBot', using default device 'ts3.alsa.dummy.playbackdefault
2019/07/21 10:34:09 64dbfc61 66bb1a49 INFO TS |ERROR |ALSA | |snd_pcm_open: No such file or directory -
2019/07/21 10:34:09 64dbfc61 66bb1a49 INFO TS |ERROR |SoundBckndIntf| |/opt/SinusPort-8881/TeamSpeak3-Client-linux_amd64/soundbackends/libalsa_linux_amd64.so error: ALSA
2019/07/21 10:34:09 64dbfc61 66bb1a49 INFO TS |INFO |CapSoundSet | |Found invalid capture device 'SinusBot', using default device 'ts3.alsa.dummy.capturedefault
2019/07/21 10:34:09 64dbfc61 66bb1a49 INFO TS |DEVELOP |PktHandler | |Puzzle solve time: 9
2019/07/21 10:34:09 64dbfc61 66bb1a49 INFO TS |INFO |ClientUI |1 |Connect status: Connecting
2019/07/21 10:34:09 64dbfc61 66bb1a49 INFO TS |INFO |ClientUI |1 |Connect status: Connected
2019/07/21 10:34:09 [GENERAL/YTDL ] INFO youtube-dl version compatible, support enabled
2019/07/21 10:34:09 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8881
2019/07/21 10:34:10 [GENERAL/RADIO ] INFO RadioStation data loaded
2019/07/21 10:34:10 64dbfc61 66bb1a49 INFO TS |INFO |ClientUI |1 |Connect status: Establishing connection
2019/07/21 10:34:10 64dbfc61 66bb1a49 INFO TS |INFO |ClientUI |1 |Connect status: Connection established
2019/07/21 10:34:10 64dbfc61 66bb1a49 INFO TS |INFO |PermManager | |Loading permissions from cache
2019/07/21 10:34:10 64dbfc61 66bb1a49 INFO TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2019/07/21 10:34:10 64dbfc61 66bb1a49 INFO TS |INFO |ClientUI | |Last update check was: Sat Jan 1 00:00:01 2022
2019/07/21 10:34:10 64dbfc61 66bb1a49 INFO TS |INFO | | |Statistics report: Not yet, next report on Sat Aug 17 10:06:43 2019
2019/07/21 10:34:10 [GENERAL/RADIO ] INFO Imported radio stations
Freue mich um hilfe ^^
ps. hab den Bot mehrmals neu installiert und meinen Server neu aufgesetzt. ohne erfolg....
Hier die infos:
