Solved Sinusbot läst sich nicht installieren
Teddyline
Versuche jetzt wieder mal seit paar tagen den Sinusbot zu installieren aber jedes mal komme ich nur bis hier hin:
[email protected]:~# bash <(wget --no-check-certificate -O - 'https://raw.githubusercontent.com/SinusBot/installer-linux/master/sinusbot_installer.sh')
--2020-03-19 00:54:44--  https://raw.githubusercontent.com/SinusBot/installer-linux/master/sinusbot_installer.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 151.101.12.133
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|151.101.12.133|:443... connected.
Length: 32234 (31K) [text/plain]
Saving to: ‘STDOUT’
-                                                   100%[==================================================================================================================>]  31.48K  --.-KB/s    in 0.008s
2020-03-19 00:54:44 (4.05 MB/s) - written to stdout [32234/32234]
Checking for the latest installer version
/dev/fd/63: line 92: 3: No such file or directory
You're using installer 1.5
What should the installer do?
1) Install
2) Update
3) Remove
4) PW Reset
5) Quit
#? 1
W: The repository 'http://ppa.launchpad.net/ondrej/php/ubuntu focal Release' does not have a Release file.
E: Failed to fetch http://ppa.launchpad.net/ondrej/php/ubuntu/dists/focal/main/binary-amd64/Packages  404  Not Found
Command which failed was: "    apt-get update". Please try to execute it manually and attach the output to the bug report in the forum thread.
If it still doesn't work report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Line 263.
Mein VPS Server hat aber Debian 9 drauf. Warum bekomme ich aber diesen: "http://ppa.launchpad.net/ondrej/php/ubuntu/dists/focal/main/binary-amd64/Packages 404 Not Found" Fehler hier immer?
wenn ich "apt-get update" und "apt-get upgrade" mache ist dort auch dieses drinne :
Err:6 http://ppa.launchpad.net/ondrej/php/ubuntu focal/main amd64 Packages
  404  Not Found
Ign:7 http://ppa.launchpad.net/ondrej/php/ubuntu focal/main Translation-en
Ign:8 http://ppa.launchpad.net/ondrej/php/ubuntu focal/main Translation-en_US
Reading package lists... Done
N: Data from such a repository can't be authenticated and is therefore potentially dangerous to use.
N: See apt-secure(8) manpage for repository creation and user configuration details.
Könnt Ihr mir da vielleicht weiter helfen?
Und gleich im vornherrein ich kann kein Englisch und ich habe auch eine Rechtschreib schwäche.
MfG
Nicole
Dann mach ein Backup deiner sources.list und entferne alle korrupten Einträge, die einen Fehler werfen. Wie das geht, ist im Link oben erklärt.
Teddyline
Egal wie ich es mache bleibt bei dem 404 oder dann den 403 Fehler. Habe eigentlich alles so gemacht wie da drinne steht. Hoffe der Übersetzer hat es richtig übersetzt alles.
fabm3n
Tier II
Tier I
Dann schau nochmal nach, da entfernte einträge im APT gar nicht mehr abgefragt werden somit könnte auch kein 403 kommen.
Edit: Warum ist der Thread schon als Solved? Sieht eigentlich nicht Solved aus :D
