Sinusbot Memory Leak
Roshke
I use sinusbot for over a year now and I've noticed that your program is memory leaking, basically the binary "sinusbot", not ts3client_linux, is just steadily climbing with RAM usage.
I use the latest version of sinusbot and here's a screenshot of the RAM usage on my Proxmox Container:
https://i.imgur.com/w1VkXB1.png
Distribution: Ubuntu 18.04 LTS
Kernel Version: Linux 5.3.18-2-pve
Can you please provide informations what Version you are using? And can you aswell try disabling scripts? Might come from scripts aswell
r3flex
I mean I dont know if this can be case but there is known memory leak due to using function setInterval the solution is to replace it with setTimeout.
Source?
This still leaves the question about which scripts are active to possible cause it... in your screenshot I just see sawtooths rather letting me think, allocated memory is released again.
r3flex
Nvm I couldn't reproduce this bug, I must have misunderstood something.
I tried searching for this but no luck.
