Sinusbot not launching TeamSpeak
JustEbu
Hello. When i start Sinusbot, it doesn't start the TeamSpeak client anymore.
Running on a Windows VPS.
I hope someone can help me.
JustEbu
SinusBot version: 1.0.0-beta.8
TS3 Client version: 3.3.2
TS3 Server version: 3.10.0
OS: Windows Server 2016 64Bit
Hardware Specs: VPS: 2,20 GHz CPU, 8GB RAM, 2Gbps Internet speed.
2019-11-08T17:41:42+01:00 LOGIN [admin] OK
2019-11-08T17:41:22+01:00 Loading instance://489243d0-5823-4ac9-ae3d-6a8cd09fe9b1
2019-11-08T17:41:21+01:00 Loading instance://972e22f1-b64b-4f5e-bfe9-66f88338bd43
2019-11-08T17:41:21+01:00 Loading instances
2019-11-08T17:41:51+01:00 Storing configuration.
2019-11-08T17:41:32+01:00 [fortniteRotation:79:27] Fortnite Rotation: Backend is not connected!
2019-11-08T17:41:32+01:00 registered callback for event chat
2019-11-08T17:41:32+01:00 [advancedclientinfo:41:15] [ACI-INFO] Script Functions enabled
2019-11-08T17:41:32+01:00 [advancedclientinfo:37:15] [ACI-WARNING] Command !ainfo will not be available because of missing ServerGroup.
2019-11-08T17:41:32+01:00 [advancedclientinfo:37:15] [ACI-WARNING] If you are sure the ID is correct, please reload your scripts to fix the problem.
2019-11-08T17:41:32+01:00 [advancedclientinfo:37:15] [ACI-WARNING] Could not find a ServerGroup matching the ID you entered, please recheck!
2019-11-08T17:41:32+01:00 [advancedclientinfo:41:15] [ACI-INFO] Advanced Client Info - Version 1.3.1 - developed by Fabeyy <www.fabeyy.me>
2019-11-08T17:41:23+01:00 New channel e252c338-1991-4a57-9e6e-e7b2422631c5 () ID 5120627d-9567-49b5-afd9-b4f04895f841 (cc 0)
2019-11-08T17:41:23+01:00 new track info: Music TV - Evening chillin' - lofi hip hop-jazz hop mix [Study-Sleep-Game] (4d75736963205456202d204576656e696e67206368696c6c696e27202d206c6f66692068697020686f702d6a617a7a20686f70206d6978205b53747564792d536c6565702d47616d655d)
2019-11-08T17:41:23+01:00 Auto-Playing last track
2019-11-08T17:41:22+01:00 script norecording loaded
2019-11-08T17:41:22+01:00 registered callback for event clientRecord
2019-11-08T17:41:22+01:00 Last track was e252c338-1991-4a57-9e6e-e7b2422631c5, will auto-play soon
2019-11-08T17:41:22+01:00 Initialization complete
2019-11-08T17:41:22+01:00 script youtube loaded
2019-11-08T17:41:22+01:00 registered callback for event api:ytwebconfig
2019-11-08T17:41:22+01:00 registered callback for event api:ytdl
2019-11-08T17:41:22+01:00 registered callback for event api:ytenq
2019-11-08T17:41:22+01:00 registered callback for event api:ytplay
2019-11-08T17:41:22+01:00 registered callback for event chat
2019-11-08T17:41:22+01:00 [ youtube:54:12] YTWeb Webinterface Ready
2019-11-08T17:41:22+01:00 executing script norecording
2019-11-08T17:41:22+01:00 script rememberChannel loaded
2019-11-08T17:41:22+01:00 registered callback for event clientMove
2019-11-08T17:41:22+01:00 executing script youtube
2019-11-08T17:41:22+01:00 script fortniteRotation loaded
2019-11-08T17:41:22+01:00 [fortniteRotation:240:12] [Script] "Fortnite Rotation (fortniteapi.io)" [Version] "0.4.6" [Author] "DrWarpMan <[email protected]>"
2019-11-08T17:41:22+01:00 registered callback for event connect
2019-11-08T17:41:22+01:00 executing script rememberChannel
2019-11-08T17:41:22+01:00 script AFK_Mover_(AwayMuteDeafIdle) loaded
2019-11-08T17:41:22+01:00 [AFK_Mover_(AwayMuteDeafIdle):695:24] [INFO] AFK mover (Away/Mute/Deaf/Idle) v2.1.2 by irgendwer / Jonas <[email protected]> loaded successfully!
2019-11-08T17:41:22+01:00 [AFK_Mover_(AwayMuteDeafIdle):695:24] [INFO] debug messages are disabled
2019-11-08T17:41:22+01:00 registered callback for event clientUndeaf
2019-11-08T17:41:22+01:00 registered callback for event clientDeaf
2019-11-08T17:41:22+01:00 registered callback for event clientUnmute
2019-11-08T17:41:22+01:00 registered callback for event clientMute
2019-11-08T17:41:22+01:00 registered callback for event clientBack
2019-11-08T17:41:22+01:00 registered callback for event clientAway
2019-11-08T17:41:22+01:00 executing script fortniteRotation
2019-11-08T17:41:22+01:00 executing script AFK_Mover_(AwayMuteDeafIdle)
2019-11-08T17:41:22+01:00 script SpamControl loaded
2019-11-08T17:41:22+01:00 registered callback for event channelCreate
2019-11-08T17:41:22+01:00 registered callback for event clientNick
2019-11-08T17:41:22+01:00 registered callback for event api:set_instance_config
2019-11-08T17:41:22+01:00 registered callback for event api:get_instance_config
2019-11-08T17:41:22+01:00 registered callback for event api:getServerGroups
2019-11-08T17:41:22+01:00 script avatarbanner loaded
2019-11-08T17:41:22+01:00 registered callback for event trackInfo
2019-11-08T17:41:22+01:00 executing script SpamControl
2019-11-08T17:41:22+01:00 script advancedclientinfo loaded
2019-11-08T17:41:22+01:00 executing script avatarbanner
2019-11-08T17:41:22+01:00 script Youtube_Search loaded
2019-11-08T17:41:22+01:00 executing script advancedclientinfo
2019-11-08T17:41:22+01:00 script YT-search loaded
2019-11-08T17:41:22+01:00 executing script Youtube_Search
2019-11-08T17:41:22+01:00 script Jail loaded
2019-11-08T17:41:22+01:00 registered callback for event serverGroupAdded
2019-11-08T17:41:22+01:00 executing script YT-search
2019-11-08T17:41:22+01:00 script command loaded
2019-11-08T17:41:22+01:00 module registered as command
2019-11-08T17:41:22+01:00 executing script Jail
2019-11-08T17:41:22+01:00 executing script command
I hope that's the way to go :)
Smurfi231
#stayinghome
Have you ever tried another Sinusbot version? Also had a similar problem and so I fixed it too.
https://forum.sinusbot.com/resources/internal-windows-beta-64bit.150/history
