Sinusbot spielt nichts ab
Darkandro
Ich habe ne frische Installation von Sinusbot gemacht, über das Install-Script, aber er spielt nichts ab, es gibt im Log auch keine Fehler
Darkandro
- Operating System: Ubuntu 18.04.1 LTS
- Kernel: Linux 4.15.0-30-generic x86_64
- Load Average: 0.64 0.60 0.55
- Uptime: 0 days, 1 hours, 15 minutes, 2 seconds
- OS APT Last Update: 13.08.2018 05:16:59 EDT -04:00:00
    Architecture:        x86_64
    CPU(s):              4
    Thread(s) per core:  1
    Core(s) per socket:  1
    Socket(s):           4
    Model name:          QEMU Virtual CPU version (cpu64-rhel6)
    CPU MHz:             3499.996
    Hypervisor vendor:   KVM
    Virtualization type: full
- RAM: 723.80 MB/5.82 GB in use (12%)
- SWAP: 0 B/1023.99 MB in use (0%)
- DISK: 9.80 GB/48.17 GB in use (20%)
   + libglib: 2.56.1-2ubuntu1
- Status: running (PIDs: 28853 28851, User: sinusbot)
- Version: 0.14.3-0e747fd
   - TS3Path = /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64 (Version 3.1.9)
   - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2018.08.04)
- Time (local): 13.08.2018 05:42:21 EDT -04:00:00
- Time (remote): 13.08.2018 05:42:21 EDT -04:00:00
- Timezone: America/New_York
- TeamSpeak 3 Version: 3.1.9
- youtube-dl Version: 2018.08.04
- DiagScript Version: 0.7.1
SinusBot Log
2018-08-13T11:49:09+02:00 Deleting channel () ID cded62ab-bd1b-4fea-b43f-587509d51e72 (cc 2)
2018-08-13T11:49:09+02:00 Removing closed channel () ID cded62ab-bd1b-4fea-b43f-587509d51e72
2018-08-13T11:49:08+02:00 new track info: Avicii - The Nights (417669636969202d20546865204e6967687473)
2018-08-13T11:49:08+02:00 new track info: ()
2018-08-13T11:49:08+02:00 Removing duplicate channel for alias () ID cded62ab-bd1b-4fea-b43f-587509d51e72
2018-08-13T11:49:08+02:00 New channel () ID e2984bd0-d6f3-4852-8878-8b1e9f0bc78a (cc 1)
2018-08-13T11:49:06+02:00 CHAT 1 [admin @ Darkandro] < yt [URL]https://www.youtube.com/watch?v=UtF6Jej8yb4[/URL] > / OK
2018-08-13T11:49:06+02:00 PRIVATE-CHAT [Darkandro] yt [URL]https://www.youtube.com/watch?v=UtF6Jej8yb4[/URL]
Kamikaze
Stoppen deinen Sinusbot und setze den Loglevel in der config.ini auf 10.
Starte den Bot und poste den ganzen Log (
läuft der bot auf einem hetzner server und versuchst du im discord etwas abzuspielen?
Darkandro
Try !ytdl
Hat nicht funktioniert :/
2018-08-13T11:58:35+02:00 TS/ERR 2564 e'access to default group is forbidden' x'' r'PR:{e930c69d-74f0-40a9-895d-a3fe5da3a76a}:28/GCLL'
2018-08-13T11:58:34+02:00 TS |INFO | | |Statistics report: Not yet, next report on Tue Sep 4 05:19:14 2018
2018-08-13T11:58:34+02:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2018-08-13T11:58:34+02:00 TS |INFO |Bookmarks | |Collecting autoconnect bookmarks
2018-08-13T11:58:34+02:00 New connection status 4; Error 0
2018-08-13T11:58:34+02:00 TS |INFO |PermManager | |Loading permissions from cache
2018-08-13T11:58:34+02:00 TS |INFO |ClientUI |1 |Connect status: Connection established
2018-08-13T11:58:34+02:00 Darkandro joined the channel
2018-08-13T11:58:34+02:00 New connection status 3; Error 0
2018-08-13T11:58:34+02:00 New connection status 2; Error 0
2018-08-13T11:58:34+02:00 TS |INFO |ClientUI |1 |Connect status: Establishing connection
2018-08-13T11:58:34+02:00 TS |INFO |ClientUI |1 |Connect status: Connected
2018-08-13T11:58:34+02:00 TS |DEVELOP |PktHandler | |Puzzle solve time: 12
2018-08-13T11:58:34+02:00 New connection status 1; Error 0
2018-08-13T11:58:34+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2018-08-13T11:58:34+02:00 TS |INFO |PreProSpeex |1 |Speex version: 1.2rc1
2018-08-13T11:58:34+02:00 TS |INFO |ClientUI |1 |Initiating connection: 127.0.0.1:9987
2018-08-13T11:58:34+02:00 TS |INFO |ClientUI |1 |Connect to server: 127.0.0.1
2018-08-13T11:58:34+02:00 TS |INFO |ClientUI | |ts3server: 127.0.0.1?port=9987&nickname=Camarac&password=&cid=1&channelpassword=
2018-08-13T11:58:34+02:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/4d670042-6dfe-474e-829e-731fc12a54dd/31f65711-dae7-4697-98b0-928f68db2195/settings.db
2018-08-13T11:58:34+02:00 TS |INFO |ClientUI | |Qt version: 5.6.1
2018-08-13T11:58:34+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2018-08-13T11:58:34+02:00 TS |DEVELOP |ClientUI | |Notifications init: Soundpack path: /opt/sinusbot/teamspeak3-client/sound/nosounds
2018-08-13T11:58:34+02:00 TS |INFO | | |*** Time [INIT]: 151
2018-08-13T11:58:34+02:00 TS |INFO | | |*** Time [MAINWINDOW]: 150
2018-08-13T11:58:34+02:00 TS |INFO | | |successfully downloaded revocation list
2018-08-13T11:58:34+02:00 TS |INFO |Plugins | |Loading plugin: libsoundbot_plugin.so
2018-08-13T11:58:34+02:00 TS |INFO |Addons | |Checking for addon updates...
2018-08-13T11:58:34+02:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2018-08-13T11:58:34+02:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2018-08-13T11:58:34+02:00 TS |INFO | | |SystemInformation: Linux 4.15.0-30-generic #32-Ubuntu SMP Thu Jul 26 17:42:43 UTC 2018 x86_64 Binary: 64bit
2018-08-13T11:58:34+02:00 TS |INFO | | |TeamSpeak 3 Client 3.1.9 (2018-05-04 13:54:44)
2018-08-13T11:58:34+02:00 TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/4d670042-6dfe-474e-829e-731fc12a54dd/31f65711-dae7-4697-98b0-928f68db2195/crashdumps
2018-08-13T11:58:34+02:00 TS>Crashdump ENABLED, directory is: /opt/sinusbot/data/ts3/4d670042-6dfe-474e-829e-731fc12a54dd/31f65711-dae7-4697-98b0-928f68db2195/crashdumps
2018-08-13T11:58:34+02:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=Camarac&password=&cid=1&channelpassword=
2018-08-13T11:58:34+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2018-08-13T11:58:34+02:00 Could not delete from FileTransferno such table: FileTransfer
2018-08-13T11:58:34+02:00 Could not create Notifications-Tabletable Notifications already exists
2018-08-13T11:58:34+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2018-08-13T11:58:34+02:00 Could not create Chat-Tabletable Chat already exists
2018-08-13T11:58:34+02:00 About to run.
2018-08-13T11:58:34+02:00 Prespawn.
2018-08-13T11:58:33+02:00 Auto-Starting 4d670042-6dfe-474e-829e-731fc12a54dd/31f65711-dae7-4697-98b0-928f68db2195 in 500 ms...
2018-08-13T11:58:33+02:00 Initialization complete
Nein ist kein Hetzner Server und ich möchte es im TS abspielen
Lala Sabathil
Könntest du das log nach dem befehl mal posten
Darkandro
Instanz Log
2018-08-13T12:05:14+02:00 new track info: AviciiOfficialVEVO - Avicii - The Nights (4176696369694f6666696369616c5645564f202d20417669636969202d20546865204e6967687473)
2018-08-13T12:05:14+02:00 New channel 9ef89554-bf22-407c-bf34-21a980b73f7b () ID 5a3471b9-18ac-4780-9c26-ab45bcb8a807 (cc 0)
2018-08-13T12:05:11+02:00 CHAT 1 [admin @ Darkandro] < ytdl [URL]https://www.youtube.com/watch?v=UtF6Jej8yb4[/URL] > / OK
2018-08-13T12:05:11+02:00 PRIVATE-CHAT [Darkandro] ytdl [URL]https://www.youtube.com/watch?v=UtF6Jej8yb4[/URL]
Bot Log
2018-08-13T12:05:14+02:00 DOWNLOAD [] https://www.youtube.com/watch?v=UtF6Jej8yb4 OK
2018-08-13T12:05:14+02:00 Downloading (multi) 3M with codec opus from youtube
2018-08-13T12:05:14+02:00 Probing https://r1---sn-4g5edne7.googlevideo.com/videoplayback?fvip=1&dur=190.641&initcwndbps=837500&lmt=1517929900738580&sparams=clen%2Cdur%2Cei%2Cgir%2Cid%2Cinitcwndbps%2Cip%2Cipbits%2Citag%2Ckeepalive%2Clmt%2Cmime%2Cmm%2Cmn%2Cms%2Cmv%2Cpl%2Crequiressl%2Csource%2Cexpire&gir=yes&ei=2VdxW6eIE4ah7QT04KPgDg&pl=47&mn=sn-4g5edne7%2Csn-hpa7zn7d&mm=31%2C26&source=youtube&requiressl=yes&mime=audio%2Fwebm&ip=2001%3A470%3A1f0b%3A1d0%3A216%3A3cff%3Afeb6%3A4914&expire=1534176313&ipbits=0&ms=au%2Conr&id=o-AOQk6ALYe2zafpb9cuFGFF5u_CbR9XT10DaomfpT2u2T&mv=m&mt=1534154566&keepalive=yes&key=yt6&c=WEB&clen=3115726&itag=251&signature=A5A844AFBADFE6E796A1CAF3AAE082C6A0AB7F2B.2CABE2548141067CD3CD65A666FDF8D680BBBC2E&ratebypass=yes for HTTP range support
2018-08-13T12:05:14+02:00 Downloading thumbnail
