Betriebssystem: Linux
TS3 Version: 3.1.1.1
Ich habe den Sinusbot mittels des Sinusbot-Installers installiert und das ganze läuft auch. Danach wollte ich den Sinusbot stoppen um die lizenz datei hochzuladen, die mir 4 weitere Sinusbots gibt. Das ganze habe ich mit den Commands "service sinusbot stop" bzw "service sinusbot start" gemacht und es kam der Fehler, ich solle hier nachschauen: "systemctl status sinusbot.service"
Fehlerbehebungs-Script Output
● sinusbot.service - LSB: Sinusbot
Loaded: loaded (/etc/init.d/sinusbot)
Active: failed (Result: exit-code) since Sat 2017-03-04 16:16:25 CET; 9s ago
Process: 5748 ExecStart=/etc/init.d/sinusbot start (code=exited, status=1/FAILURE)
Mar 04 16:16:23 sinusbot[5748]: BOT RUN CMD: ./sinusbot
Mar 04 16:16:25 sinusbot[5748]: Starting sinusbot...
Mar 04 16:16:25 su[5753]: Successful su for sinusbot by root
Mar 04 16:16:25 su[5753]: + ??? root:sinusbot
Mar 04 16:16:25 su[5753]: pam_unix(su:session): session opened for user sinusbot by (uid=0)
Mar 04 16:16:25 su[5753]: pam_unix(su:session): session closed for user sinusbot
Mar 04 16:16:25 sinusbot[5748]: sinusbot is already running
Mar 04 16:16:25 systemd[1]: sinusbot.service: control process exited, code=exited status=1
Mar 04 16:16:25 systemd[1]: Failed to start LSB: Sinusbot.
Mar 04 16:16:25 systemd[1]: Unit sinusbot.service entered failed state.
- Operating System: Debian GNU/Linux 8.7 (jessie)
- Load Average: 0.38 0.25 0.20
- Uptime: 1 days, 20 hours, 43 minutes, 12 seconds
- OS APT Last Update: 04.03.2017 15:48:09 CET +01:00:00
CPU(s): 16
Thread(s) per core: 2
Core(s) per socket: 8
Socket(s): 1
Model name: Intel(R) Xeon(R) CPU D-1540 @ 2.00GHz
CPU MHz: 1576.093
Virtualization: VT-x
- RAM: 1.55 GB/62.95 GB in use (2%)
- SWAP: 0 B/15.25 GB in use (0%)
- DISK: 1.87 GB/1.69 TB in use (0%)
> libglib: 2.42.1-1+b1
- Status: running (PIDs: 5581 5579, User: sinusbot)
- Binary: /opt/sinusbot/sinusbot (MD5 Hash: 0005c8c289b99913844c9f761dbb50e9)
- Version: 0.9.16-10f0fad
- Bot Plugin: 28b54596e19937601df973b709aa0667
- TS3 Client: 28b54596e19937601df973b709aa0667
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2017.03.02)
- Report date: 04.03.2017 16:19:45 CET +01:00:00 (timezone: Europe/Berlin)
- youtube-dl Version: 2017.03.02
- DiagScript version: 0.5.0
