Justus43
2018-04-02T14:23:18+02:00 TSClient quit.
2018-04-02T14:23:18+02:00 KILL [justus43] OK
2018-04-02T14:23:17+02:00 Could not request shutdown. Please make sure that the plugin is installed correctly; HTTP returned an error: Timeout; Code: 500; Message: Timeout
2018-04-02T14:22:37+02:00 Ping failed.
2018-04-02T14:17:29+02:00 TS |INFO |ClientUI |1 |Connect status: Disconnected
2018-04-02T14:17:29+02:00 TS |INFO | | |Statistics report: User has not yet confirmed participation
2018-04-02T14:17:29+02:00 TS |INFO |ClientUI | |Last update check was: Tue Jan 1 00:00:01 2019
2018-04-02T14:17:29+02:00 TS |INFO |ClientUI |1 |Connect status: Connecting
2018-04-02T14:17:29+02:00 TS |INFO |CapSoundSet | |Found invalid capture device 'SinusBot', using default device '
2018-04-02T14:17:28+02:00 TS |INFO |PlaySoundSet | |Found invalid playback device 'SinusBot', using default device '
2018-04-02T14:17:28+02:00 TS |INFO |ClientUI |1 |Initiating connection: 84.200.122.214:9987 84.200.122.214
2018-04-02T14:17:28+02:00 TS |INFO |ClientUI |1 |Blacklist check ok
2018-04-02T14:17:28+02:00 TS |INFO |ClientUI |1 |Connect to server: 84.200.122.214
2018-04-02T14:17:28+02:00 TS |INFO |ClientUI | |ts3server: 84.200.122.214?port=9987&nickname=T%C3%BCrsteher&password=&cid=1&channelpassword=
2018-04-02T14:17:28+02:00 TS |INFO |ClientUI | |Using configuration location: /opt/sinusbot/data/ts3/5ea2e5f8-f7ac-4dfe-adc8-43a2e6170225/7469cb69-c9bc-4231-9bb1-09670138aa2b/settings.db
2018-04-02T14:17:28+02:00 TS |INFO |ClientUI | |Qt version: 5.5.0
2018-04-02T14:17:28+02:00 TS |INFO |ClientUI | |Failed to init text to speech engine
2018-04-02T14:17:28+02:00 TS |INFO | | |*** Time [INIT]: 251
2018-04-02T14:17:28+02:00 TS |INFO | | |*** Time [MAINWINDOW]: 251
2018-04-02T14:17:28+02:00 TS |INFO | | |*** Time [CONTACTS]: 145
2018-04-02T14:17:27+02:00 TS |INFO | | |Api version is not compatible for plugin: /opt/sinusbot/teamspeak3-client/plugins/libsoundbot_plugin.so
2018-04-02T14:17:27+02:00 TS |ERROR |Query | |bind failed on 127.0.0.1:25639
2018-04-02T14:17:27+02:00 TS |INFO | | |Loading plugin: libtest_plugin
2018-04-02T14:17:27+02:00 TS |INFO | | |Loading plugin: libsoundbot_plugin
2018-04-02T14:17:27+02:00 TS |INFO | | |Loading plugin: liblua_plugin
2018-04-02T14:17:27+02:00 TS |INFO | | |Loading plugin: libclientquery_plugin
2018-04-02T14:17:27+02:00 TS |WARNING |SoundDevManager| |Did not load any sound backends. No (usable) dynamic libraries found.
2018-04-02T14:17:27+02:00 TS |ERROR |SoundBckndIntf| |libpulse.so.0: cannot open shared object file: No such file or directory
2018-04-02T14:17:27+02:00 TS |ERROR |SoundBckndIntf| |libasound.so.2: cannot open shared object file: No such file or directory
2018-04-02T14:17:27+02:00 TS |INFO | | |SystemInformation: Linux 2.6.32-042stab127.2 #1 SMP Thu Jan 4 16:41:44 MSK 2018 x86_64 Binary: 64bit
2018-04-02T14:17:27+02:00 TS |INFO | | |TeamSpeak 3 Client 3.0.18.2 (2015-10-22 11:14:48)
2018-04-02T14:17:27+02:00 Starting instance ts3server://84.200.122.214?port=9987&nickname=T%C3%BCrsteher&password=&cid=1&channelpassword=
2018-04-02T14:17:27+02:00 Could not create Notifications-Tabletable Notifications already exists
2018-04-02T14:17:27+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2018-04-02T14:17:27+02:00 Could not create Chat-Tabletable Chat already exists
2018-04-02T14:17:27+02:00 Fail from voice reader: read unix @->@: use of closed network connection
2018-04-02T14:17:07+02:00 TSClient quit.
Debian 8 wird auf dem Server genutzt. Sinusbot ist die aktuellste Version sowie mein Teamspeak läuft auch auf der aktuellsten.
