Operating System: Linux - Centos 7
SinusBot Version: 0.11
TS3 Version: 3.0.13.8
So I have been having this problem with two separate VPS's, installation of the SinusBot goes fine, everything works as it should. But, when I reboot the VPS, the VPS won't come back online, this has happened with two VPS's I have, both with different (but similar) spec's, and yes it is the Sinusbot, because it reboot's fine before the installation of SinusBot.
Not saying this is Sinusbot's fault, it is most probable that it is something wrong with my servers, as this seems to be an isolated problem with only me?
Server Spec's
So I have used CentOS 7 for both servers (as this is what I prefer), Should i try using Ubuntu or Debian? or maybe CentOS 6?
Edit* Going to try Ubuntu and see if this problem still happens, will update as I go.
Edit* Fixed confusion
Server Spec's
Spec's Server 1:
CPU: i7-4820K
Cores: 4
RAM: 2.75GB
Network: 1GBps
Operating System: CentOS Linux release 7.4.1708
TS3 Server Version: 3.0.13.8
Installation: Auto Installer by Qhiliqq
CPU: i7-4820K
Cores: 4
RAM: 2.75GB
Network: 1GBps
Spec's Server 2 - Second Test Server:
CPU: Xeon 5650
Cores: 8
RAM: 2GB
Network: 1GBps
CPU: Xeon 5650
Cores: 8
RAM: 2GB
Network: 1GBps
