feufeutank22
hier ein paar Infos was das debug-script ausgespuckt hat.
SinusBot 1.0.0-beta.3-735814e
instance-log
- Operating System: Debian GNU/Linux 9.9 (stretch) (OpenVZ)
- Kernel: Linux 2.6.32-042stab134.7 x86_64
- Load Average: 0.00 0.17 0.17
- Uptime: 0 days, 0 hours, 21 minutes, 51 seconds
- OS APT Last Update: 07.07.2019 04:54:02 UTC +00:00:00
- Shell Locale: en_US.UTF-8
- RAM: B/1.00 GB in use (%)
- SWAP: B/ B in use (%)
- DISK: 13.91 GB/25.00 GB in use (55%)
- libglib: 2.50.3-2
- Status: running (PIDs: 1112 1111, User: sinusbot)
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2019.03.18)
linux-vdso.so.1 (0x00007ffd7dcf5000)
libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007faa912b8000)
libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007faa90f60000)
libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007faa90b5f000)
libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007faa901fa000)
libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007faa8ff86000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007faa8fd76000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007faa8fa70000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007faa8f853000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007faa8f4d1000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007faa8f2ba000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007faa8ef1b000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007faa8ed01000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007faa8eaf7000)
/lib64/ld-linux-x86-64.so.2 (0x000055a62f69e000)
- Time (local): 05.08.2019 12:26:27 UTC +00:00:00
- Time (remote): 05.08.2019 12:26:27 UTC +00:00:00
- Timezone: Etc/UTC
- TeamSpeak3 Version: 3.3.0
- youtube-dl Version: 2019.03.18
[SIZE=13px][FONT=Open Sans][COLOR=rgb(119, 119, 119)]2019-08-05T14:25:34+02:00 Storing configuration.
2019-08-05T14:25:32+02:00 closing channels[/COLOR]
[COLOR=rgb(34, 34, 34)]2019-08-05T14:25:31+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.[/COLOR]
[COLOR=rgb(119, 119, 119)]2019-08-05T14:25:31+02:00 Closed.
2019-08-05T14:25:31+02:00 TS>terminating with uncaught exception of type boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::uuids::entropy_error> >: getrandom
2019-08-05T14:25:31+02:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2019-08-05T14:25:31+02:00 TS>QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-sinusbot'
2019-08-05T14:25:31+02:00 TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present
2019-08-05T14:25:31+02:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first[/COLOR]
[COLOR=rgb(34, 34, 34)]2019-08-05T14:25:31+02:00 Starting instance ts3server:XXX-Censored-XXX[/COLOR]
[COLOR=rgb(119, 119, 119)]2019-08-05T14:25:31+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2019-08-05T14:25:31+02:00 Could not delete from FileTransferno such table: FileTransfer
2019-08-05T14:25:31+02:00 Could not delete from FileTransferno such table: FileTransfer[/COLOR]
[COLOR=rgb(153, 102, 51)]2019-08-05T14:25:31+02:00 Could not create Notifications-Tabletable Notifications already exists
2019-08-05T14:25:31+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019-08-05T14:25:31+02:00 Could not create Chat-Tabletable Chat already exists[/COLOR]
[COLOR=rgb(119, 119, 119)]2019-08-05T14:25:31+02:00 About to run.
2019-08-05T14:25:31+02:00 Prespawn.[/COLOR][/FONT][/SIZE]
