Solved Skipping from the webinterface of using !next isn't working
Tom7653
Operating System: Linux - CentOS 7
SinusBot Version: Latest
TS3 Version: 3.0.19.4
When using !next it simply stops the YouTube playlist. (Basically skips the whole playlist rather than the song)
BadassOverlord
SinusBot Version: 0.9.20
TS3 Version: 3.0.19.3
I hit !next and I thought it would skip the song, but the music just stopped playing. I look on the web interface and it looks like the song keeps playing until the end of the song, but no music is playing from the bot. When the song reaches the end, it will keep going back to the last 3 seconds and repeat to the end, over and over again.
2017-06-10T19:03:07-07:00 PLAY-NEXT [admin] OK
2017-06-10T19:03:07-07:00 Stopping
SimoBot
Operating System: Windows / Linux
TS3 Version: 3.0.18.2
Updated the bot to the last version. Used youtube search plugin setted as queue, then other scripts, after adding two songs, the first plays then when using !next it stops. Went back using the native command !queue on two uploaded songs. When using next i can fix it using !say command, while using queue it just stop the first and play the second immediately. Dunno if it is related, but i have an error message on boot.
2017/06/12 10:47:01 b2703e0e ac39939e DEBUG  Could not delete from FileTransferno such table: FileTransfer
2017/06/12 10:47:01 b2703e0e ac39939e DEBUG  Could not insert into FileTransfer-Tableno such table: FileTransfer
Crackisapro
Operating System: Ubuntu 16.04.2 LTS (64bits)
SinusBot Version: 0.9.18-8499d2c (I think, I installed it with the script installer)
Same problem here. If I'm listening a song and I try to skip it by pressing next, it just stops the song but the time of the song continues .. If I type !next in the chat, nothing (And the ignore chat option is disabled). I tried to disable all the scripts but nothing has changed
- Operating System: Ubuntu 16.04.2 LTS
- Kernel: Linux 4.4.0-79-generic x86_64
- Load Average: 0.26 0.14 0.16
- Uptime: 0 days, 11 hours, 53 minutes, 4 seconds
- OS APT Last Update: 12.06.2017 04:53:12 EDT -04:00:00
    CPU(s):                2
    Thread(s) per core:    1
    Core(s) per socket:    2
    Socket(s):             1
    Model name:            Intel(R) Pentium(R) D  CPU 2.66GHz
    CPU MHz:               2660.011
- RAM: 485.64 MB/2.93 GB in use (16%)
- SWAP: 47.54 MB/2.99 GB in use (1%)
- DISK: 22.07 GB/192.50 GB in use (11%)
   > libglib: 2.48.2-0ubuntu1
- Status: running (PIDs: 1530 1493, User: sinusbot)
- Binary: /opt/sinusbot/sinusbot (MD5 Hash: adecf87cd9d5dc4f4216133871aca055)
- Version: 0.9.20-a9b8dc6
   - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2017.06.12)
- Installed scripts: adpi_en_1.4.js; Advanced Display Playback Information.js; advertising.js; AFK Mover.js; aloneMode.js; Animated Nickname.js; badchan.js; bookmark.js; covatar.js; dev.js; followme.js; idle.js; metadata.js; Next Track Please.js; norecording.js; Now Playing.js; rememberChannel.js; showcase.js; sound.js; Sticky Channel.js; TwitchHitbox Status.js; welcometext.js; Youtube Search.js
- Report date: 12.06.2017 13:53:47 EDT -04:00:00 (timezone: America/Toronto)
- youtube-dl Version: 2017.06.12
- DiagScript version: 0.5.1
Ammar
I am experiencing few problems lately. Firstly, I can't seem to access the "Addons" tab under settings. Secondly, I'm getting an error: "Could not playback the selected file / stream". I get this error when trying to play a song using a YT-DL playlist and lastly, "!next" command does nothing anymore as the instant i write "!next", the sound of the bot(music) is gone and next song never starts even though on the webinterface, the song is still playing and after that i can't manually play a song using webinterface as i get the aforementioned error stating that "Could not playback the selected file / stream". After sinusbot restart, song resumes. Weird!
I've tried updating both the bot and youtube-dl 4 times and even tried reinstalling it 2 times but i keep on getting the same issue. I've also tried restarting, stopping and starting sinusbot service. Restarting the VPS but still no luck.
Any help regarding this would be highly appreciated.
My VPS specs:
Processr: 1 vCore(i7 4.0-4.7 GHz)
RAM: 1 GB DDR4 ECC 2400 MHz
Storage: 10 GBSSD RAID
Connection: 100 Mbps(1 Gbps Burst)
The solution is to use this version. A public release will follow in the next few days.
https://www.sinusbot.com/pre/sinusbot-0.9.21-87a90ce.tar.bz2
Chucky
SinusBot Version: 3.0.19.4 on Linux
TS3 Version: 3.0.13.6 on Linux
Describe your problem in detail. What did you do exactly, what did you expect to happen and what did actually happen?
My SinusBot Wont play next songs itself i must play one by one by my hands can't automatically even the next button is not working it mutes the songs please help me this really annoying it was fine but dunno why now it's bugged
Hi, I have same problem. When you restart the sinusbot from putty it works somehours without problem. After it. Queue stoped and working only when i type !next
Any solution?
PS: Sorry for my BAD ENGLISH :D
Chucky
my !next command is stoping the music not play next song im so tired with it many things i try but always have some buggs
