Hi guys,
I just installed my Let's Encypt cert and allowed my sinusbot user to accses the /letsencrypt/live/domain/ folder and copy pasta the nginx config like in the documentation.
Now the probem. If i startup my bot no Errors are shown that the bot can't accses the cert file or anything else. now i try to connenct with https://www.mydomain.com:8087 but boom no TLS handshake. i post my nginx config and my sinusbot conf. maybe someone of you can help me.
ListenHost = "127.0.0.1"
LogLevel = 3
YoutubeDLPath = "/opt/sinusbot/youtube-dl"
ExternalFileBase = ""
UseSSL = true
SSLKeyFile = "/etc/letsencrypt/live/www.mydomain.com/privkey.pem"
SSLCertFile = "/etc/letsencrypt/live/www.mydomain.com/fullchain.pem"
Hostname = "www.mydomain.com"
LicenseKey = ""
IsProxied = true
AllowGIF = true
DevMode = false
UserAgent = "SinusBot (1.0.0-beta.5-b262b6a)"
server {
listen 80;
listen [::]:80;
# Set your domain here:
server_name www.mydomain.com;
access_log /var/log/nginx/sinusbot.access.log;
error_log /var/log/nginx/sinusbot.error.log;
return 301 https://$host$request_uri;
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
client_max_body_size 200M;
# Set the path to your ssl cert here:
ssl on;
ssl_certificate /etc/letsencrypt/live/www.mydomain.com/fullchain.pem;
ssl_certificate_key /etc/letsencrypt/live/www.mydomain.com/privkey.pem;
location / {
proxy_pass http://127.0.0.1:8087;
proxy_http_version 1.0;
proxy_set_header X-Forwarded-For $remote_addr;
# pass upgrade/connection headers for websockets
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "Upgrade";
