SSL for Webserver possible?
Halandar
i just installed sinusbot for the first time on a linux box and it is running great.
Question is though, is it possible to make the webinterface available only via SSL / HTTPS, without doing an apache reverse proxy or similar?
This would be important for me, as the server is on a public network, and I login to this interface.
Thank you!
yep, you can define the SSL certificate in the config file
