TSClient Quit. LogLevel increased
Chiura
Hi! Ich habe ein Start problem. Hab den Loglevel auch in der config.ini auf 10 gestellt aber es kommt immer noch das selbe.
Also ich komme in das webinterface aber der bot connectet nicht. Bitte um hilfe! Danke!
Ausgabe:
___ ___ _ _ _ _ ___ ___ ___ _____
Version: 1.0.0-beta.3-735814e
2019/08/27 23:42:08 77e2bcf8 INFO Loading instances
2019/08/27 23:42:08 77e2bcf8 INFO Loading instance://f7a8bc85-4e8f-45 8c-8572-1cdf64ce06d5
2019/08/27 23:42:08 77e2bcf8 f7a8bc85 DEBUG executing script command
2019/08/27 23:42:08 77e2bcf8 f7a8bc85 INFO Initialization complete
2019/08/27 23:42:08 [GENERAL/FFMPEG ] INFO FFmpeg/avcodec v3741798; license: L GPL version 2.1 or later; 81 codecs
2019/08/27 23:42:08 [GENERAL/FFMPEG ] INFO FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2019/08/27 23:42:08 [GENERAL/!!!!!!!] NOTICE You may now configure and launch th e bots from the webinterface. http://0.0.0.0:8087
2019/08/27 23:42:08 77e2bcf8 f7a8bc85 DEBUG serialized function: true
2019/08/27 23:42:08 77e2bcf8 f7a8bc85 DEBUG registered callback for event chat
2019/08/27 23:42:08 77e2bcf8 f7a8bc85 DEBUG module registered as command
2019/08/27 23:42:08 77e2bcf8 f7a8bc85 INFO script command loaded
2019/08/27 23:42:08 [GENERAL/RADIO ] INFO RadioStation data loaded
2019/08/27 23:42:09 [GENERAL/RADIO ] INFO Imported radio stations
2019/08/27 23:42:29 77e2bcf8 f7a8bc85 DEBUG Prespawn.
2019/08/27 23:42:29 77e2bcf8 f7a8bc85 DEBUG About to run.
2019/08/27 23:42:29 77e2bcf8 f7a8bc85 WARN Could not create Chat-Tabletable Ch at already exists
2019/08/27 23:42:29 77e2bcf8 f7a8bc85 WARN Could not create WhisperReceive-Tab letable WhisperReceive already exists
2019/08/27 23:42:29 77e2bcf8 f7a8bc85 WARN Could not create Notifications-Tabl etable Notifications already exists
2019/08/27 23:42:29 77e2bcf8 f7a8bc85 WARN Could not delete from Applicationno such table: Application
2019/08/27 23:42:29 77e2bcf8 f7a8bc85 WARN Could not insert into Application-T ableno such table: Application
2019/08/27 23:42:29 77e2bcf8 f7a8bc85 DEBUG Could not delete from FileTransfern o such table: FileTransfer
2019/08/27 23:42:29 77e2bcf8 f7a8bc85 DEBUG Could not insert into FileTransfer- Tableno such table: FileTransfer
2019/08/27 23:42:29 77e2bcf8 f7a8bc85 WARN Could not delete from Profilesno su ch table: Profiles
2019/08/27 23:42:29 77e2bcf8 f7a8bc85 WARN Could not insert into Profiles-Tabl eno such table: Profiles
2019/08/27 23:42:29 77e2bcf8 f7a8bc85 DEBUG Could not delete from Newsno such t able: News
2019/08/27 23:42:29 77e2bcf8 f7a8bc85 DEBUG Could not insert into News-Tableno such table: News
2019/08/27 23:42:29 77e2bcf8 f7a8bc85 INFO Starting instance ts3server://ehren squad.eu?port=9987&nickname=Ehrensquad%20Bot&password=&channel=&channelpassword=
2019/08/27 23:42:29 X [MAIN] New connection
2019/08/27 23:42:29 77e2bcf8 f7a8bc85 DEBUG TS>/opt/sinusbot/TeamSpeak3-Client- linux_amd64/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libdbus-1.so.3: no vers ion information available (required by /opt/sinusbot/TeamSpeak3-Client-linux_amd 64/libQt5WebEngineCore.so.5)
2019/08/27 23:42:29 77e2bcf8 f7a8bc85 DEBUG TS>QCoreApplication::applicationDir Path: Please instantiate the QApplication object first
2019/08/27 23:42:29 77e2bcf8 f7a8bc85 DEBUG TS>qt.qpa.xkeyboard: no keyboard la youts with latin keys present
2019/08/27 23:42:29 77e2bcf8 f7a8bc85 DEBUG TS>QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-sinusbot'
2019/08/27 23:42:29 77e2bcf8 f7a8bc85 DEBUG TS>QXcbIntegration: Cannot create p latform OpenGL context, neither GLX nor EGL are enabled
2019/08/27 23:42:29 77e2bcf8 f7a8bc85 DEBUG TS>terminating with uncaught except ion of type boost::exception_detail::clone_impl<boost::exception_detail::error_i nfo_injector<boost::uuids::entropy_error> >: getrandom
2019/08/27 23:42:29 77e2bcf8 f7a8bc85 DEBUG Closed.
2019/08/27 23:42:29 77e2bcf8 f7a8bc85 INFO TSClient quit. LogLevel has been in creased, please try to connect again to see more details.
2019/08/27 23:42:30 77e2bcf8 f7a8bc85 DEBUG closing channels
2019/08/27 23:42:30 77e2bcf8 f7a8bc85 DEBUG eof from voice
2019/08/27 23:42:38 77e2bcf8 f7a8bc85 DEBUG Storing configuration.
ExternalFileBase = ""
PS: Wenn wir schon dabei sind, wie kann ich den bot 24/7 laufen lassen ohne das er sich schließt wenn ich putty beende?
Deutet auf einen zu alten Kernel hin. Der Befehl uname -r sollte dir Aufschluss geben.
https://sinusbot.github.io/docs/installation/linux/#compatible-versions
Auch bei dieser Frage wirst du in der Documentation fündig:
https://sinusbot.github.io/docs/installation/linux/#using-a-startscript
Qinaii
Und was ist, wenn der kernel nicht veraltet ist (4.9.0) ?
Habe das selbe Problem, kann nur zwei conntecten lassen, beim dritten, kommt das selbe Problem mit dem Loglevel (Beta1.0.0-beta.8-9e95ca7)
MFG
@Qinaii: Hör bitte auf, alte Threads zu hijacken, die vermutlich nichts mit deinem Problem zu tun haben. Erstelle statt dessen einen neuen Thread und poste alle Infos, die im "LIES MICH BEVOR..." / "READ ME BEFORE..." gefordert werden.
Qinaii
Aber es ist doch genau das selbe Problem und man soll doch erst alte Thread anschauen bevor man das selbe erneut posted..
2019/10/22 10:40:43 d6e0e5f7 86dc813c DEBUG Closed.
2019/10/22 10:40:43 d6e0e5f7 86dc813c INFO TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019/10/22 10:40:44 d6e0e5f7 86dc813c DEBUG eof from voice
2019/10/22 10:40:44 d6e0e5f7 86dc813c DEBUG closing channels
und Hijacking ist was anderes..:D
Soweit ich das sehen kann ist das nicht dasselbe Problem - ansonsten wäre es auch mit der Antwort von @TwentyFour getan. Wenn das so ist, prima.
Wenn ich mir deinen Post in dem anderen Thread (von dem ich wegen der verwendeten Sprache nicht mal ne Ahnung habe worum es genau geht, du etwa?) ansehe, dann würde ich eher auf andere Probleme schließen.
Grundsätzlich ist das schon richtig, dass man andere Threads nutzen sollte, wenn es um EXAKT dasselbe Problem (oder dieselben Symptome) geht und noch Dinge unklar sind. Aber das ist hier soweit ich das sehen kann nicht der Fall.
Qinaii
Und ist es nicht der Fall, dass ich genau wie der Thread ersteller ein problem mit Loglevel habe ? Brauche ja diesbezüglich hier hilfe und in diesem Thread geht es ja um Loglevel..
Ich habe auch die "Änderung" gesehen, sie hilft aber auch nicht weiter und ändert insofern nichts an dem, was ich schon sagte...
Qinaii
Dann werde ich ein Thread aufmachen müssen mit EXACT den selben Titel.
schönen Tag noch.
Solange alle Infos drin sind, die gefordert werden, ist das nicht so schlimm. Problem hier im Thread war, dass keine Bots starten - wenn ich das richtig verstanden habe, starten bei dir aber einige. Da wäre ein Titel wie "Nur ein Teil meiner Bots startet" zum Beispiel nicht schlecht. Zusammen mit den Infos, die du ja dann hoffentlich angefügt hast, wird man sich ziemlich schnell ein Bild machen können. Um dir das ein bisschen näher zu bringen: dein Fehlerbild sagt mir "vermutlich zu wenig RAM" und ich würde nachsehen, wieviel du hast, wenn du die Infos angefügt hättest. Entweder um auszuschließen, dass es daran liegt, oder es zu bestätigen.
Wie gesagt: Threads zu nutzen, die auf jeden Fall dasselbe Problem schildern ist super und lobenswert. Aber bei Titeln wie "MY BOT IS NOT WORKING" oder "HELP PLEASE" muss mann dann schon noch differenzieren - leider haben 80% der Threads so einen oder ähnliche Titel. Und wenn dann schon Moderatoren antworten und dir sagen, was du bitte machen sollst, damit man dir helfen kann, wäre es super, wenn du das einfach tun könntest, anstatt eine besserwisserische Art an den Tag zu legen. Das spart uns allen Zeit und hilft dir auch dabei, dass deine Bots eher tun, was du von ihnen willst^^
