what did i do wrong?
Bealsibe
i did the local install below do i leave the url blank in my instance setting cant seem to get the tts to work​
Installing libraries from the Chromium project🔗
These are basic instructions for Linux. You need at least SinusBot 1.0 for this to work.
  • Download and install the library and the voices
cd /opt/sinusbot/tts
wget https://chromium.googlesource.com/c...+archive/master/speech_synthesis/patts.tar.gz
tar -xzf patts.tar.gz
rm patts.tar.gz
unzip tts_service_x86_64.nexe.zip
If the last command fails, you probably need to install unzip first. On Debian/Ubuntu this can be done with apt install unzip.
Afterwards, edit your config.ini to contain the following:
[TTS]
Enabled = true
[[TTS.Modules]]
Locale = "en-US"
Filename = "voice_lstm_en-US.zvoice"
PipelineFile = "voice_lstm_en-US/sfg/pipeline"
Prefix = "voice_lstm_en-US/sfg/"
Instances = 2
[[TTS.Modules]]
Locale = "de-DE"
Filename = "voice_lstm_de-DE.zvoice"
PipelineFile = "voice_lstm_de-DE/nfh/pipeline"
Prefix = "voice_lstm_de-DE/nfh/"
Instances = 2
