Then maybe both are wrong? Check for example with: https://www.timeanddate.com/ or google "time".
Again: it must be precise, a few minutes off is not okay.
check it out plsThat's usually irrelevant. Make sure minutes/seconds are correct. I changed the link above to this one: https://time.is/ - the one mentioned earlier uses the local time on your pc![]()
Nope, but that will make you run into the next issue, then.this error can shows up if im using newest ts client? i downloaded to my vps teamspeak v. 3.1.1.1
ntpd -q -g
nvm, im downgraded it already so its should be fine.Nope, but that will make you run into the next issue, then.
why im im off on 1 minute? look at scr my time on vps is 20:59:01 and time on https://time.is/ is 20:59:02You still seem to be a minute or so off
apt-get install ntpd
sudo service ntp restart
root@118332-vds-devoldini:~# sudo service ntp stop
root@118332-vds-devoldini:~# sudo ntpd -q -g
19 Mar 21:36:27 ntpd[5326]: ntpd [email protected] Wed Oct 5 12:34:45 UTC 2016 (1): Starting
19 Mar 21:36:27 ntpd[5326]: Command line: ntpd -q -g
19 Mar 21:36:27 ntpd[5326]: proto: precision = 0.087 usec (-23)
19 Mar 21:36:27 ntpd[5326]: Listen and drop on 0 v6wildcard [::]:123
19 Mar 21:36:27 ntpd[5326]: Listen and drop on 1 v4wildcard 0.0.0.0:123
19 Mar 21:36:27 ntpd[5326]: Listen normally on 2 lo 127.0.0.1:123
19 Mar 21:36:27 ntpd[5326]: Listen normally on 3 ens3 185.86.76.51:123
19 Mar 21:36:27 ntpd[5326]: Listen normally on 4 lo [::1]:123
19 Mar 21:36:27 ntpd[5326]: Listen normally on 5 ens3 [fe80::5054:ff:fee3:e80%2]:123
19 Mar 21:36:27 ntpd[5326]: Listening on routing socket on fd #22 for interface updates
19 Mar 21:36:28 ntpd[5326]: Soliciting pool server 193.27.209.20
19 Mar 21:36:29 ntpd[5326]: Soliciting pool server 91.236.251.12
19 Mar 21:36:29 ntpd[5326]: Soliciting pool server 91.236.251.5
19 Mar 21:36:30 ntpd[5326]: Soliciting pool server 82.193.117.90
19 Mar 21:36:30 ntpd[5326]: Soliciting pool server 91.198.10.4
19 Mar 21:36:30 ntpd[5326]: ntpd: time slew +0.003248 s
ntpd: time slew +0.003248s
root@118332-vds-devoldini:~# sudo service ntp start
root@118332-vds-devoldini:~# date
Вск Мар 19 21:37:04 EET 2017
root@118332-vds-devoldini:~# cd /opt/ts3soundboard
root@118332-vds-devoldini:/opt/ts3soundboard# ./sinusbot -RunningAsRootIsEvilAndIKnowThat
2017/03/19 21:37:38 [GENERAL/!!!!!!!] WARN !!!!!!! YOU ARE RUNNING THE BOT AS UID 0 (ROOT) WITHOUT HAVING SET ANOTHER UID. THIS IS A SERIOUS SECURITY VIOLATION !!!!!!!!
Version: 0.9.18-8499d2c
2017/03/19 21:37:38 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2017/03/19 21:37:38 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin aloneMode.js
2017/03/19 21:37:38 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin badchan.js
2017/03/19 21:37:38 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2017/03/19 21:37:38 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin covatar.js
2017/03/19 21:37:38 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin dev.js
2017/03/19 21:37:38 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2017/03/19 21:37:38 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin idle.js
2017/03/19 21:37:38 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin metadata.js
2017/03/19 21:37:38 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2017/03/19 21:37:38 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin rememberChannel.js
2017/03/19 21:37:38 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin showcase.js
2017/03/19 21:37:38 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin sound.js
2017/03/19 21:37:38 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcometext.js
2017/03/19 21:37:38 X [MAIN] Starting up fake x-server...
a manual update is required
A manual update is required error debian 8 vps how can i solve this problem sorry for my bad english .
wget https://www.sinusbot.com/dl/sinusbot-beta.tar.bz2
tar -xjvf sinusbot-beta.tar.bz2
cp plugin/libsoundbot_plugin.so /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/plugins
Code:cd /opt/ts3soundboard wget https://www.sinusbot.com/dl/sinusbot-beta.tar.bz2 tar -xjvf sinusbot-beta.tar.bz2 cp plugin/libsoundbot_plugin.so /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/plugins
TS3Path = "/home/sinusbot/sinusbot1/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64"
DataDir = "/home/sinusbot/sinusbot1/data/"
LicenseKey = "8yz+M1G/Vfv6UHQcMBqJq3ITCiAJ8Ymn0BsgrFTryDU="
UserAgent = "SinusBot (0.9.16-10f0fad)"
If you don't have any experience on Linux, rent a Windows Server. If you don't want that, use the unofficial Sinus-Bot-Installer. Thanks.[GENERAL/!!!!!!!] WARN !!!!!!! YOU ARE RUNNING THE BOT AS UID 0 (ROOT) WITHOUT HAVING SET ANOTHER UID. THIS IS A SERIOUS SECURITY VIOLATION !!!!!!!!
Das ist normal.ich habe auch die X40 datei gelöscht und die Sinusbot.lock, aber die datei X40 erstellt sich bei jedem starten des bots
wtf?TS3 Version: 3.1.1.1
