You realy expect help at 2AM in a small little support community forum?any help support forum ?????
Your patience is gold man. I am reading posts of these idiots and thinking does this guy have a limit. If i was you i would already break my keyboard and die from the amout of retardeness they postThen maybe both are wrong? Check for example with: https://time.is/ or google "time".
Again: it must be precise, a few minutes off is not okay.
Das müsste ich über den Hoster machen lassen mir sind alle Zeit Befehle gesperrt...aber in der Minecraft Console stimmt die Zeit zu 100% mit der jetzigen Zeit überein.BItte überprüfe deine Systemzeit
Bei mir half es, die Systemzeit auf Europe/Berlin zu stellen
- Operating System: Debian GNU/Linux 8.9 (jessie)
- Load Average: 0.27 0.18 0.15
- Uptime: 308 days, 19 hours, 16 minutes, 22 seconds
- OS APT Last Update: 05.08.2017 19:48:11 CEST +02:00:00
CPU(s): 2
Thread(s) per core: 1
Core(s) per socket: 1
Socket(s): 2
Model name: Intel(R) Xeon(R) CPU E5-2620 v2 @ 2.10GHz
CPU MHz: 2094.950
Virtualization: VT-x
Hypervisor vendor: KVM
Virtualization type: full
- RAM: 331.38 MB/1.96 GB in use (16%)
- SWAP: 21.24 MB/3.28 GB in use (0%)
- DISK: 20.32 GB/51.20 GB in use (39%)
> libglib: 2.42.1-1+b1
- Binary: /opt/ts3soundboard/sinusbot (MD5 Hash: adecf87cd9d5dc4f4216133871aca055)
- Version: 0.9.20-a9b8dc6
- TS3Path = /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.0.19.4)
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2017.07.23)
- Installed scripts: advertising.js; aloneMode.js; badchan.js; bookmark.js; come.js; covatar.js; dev.js; followme.js; idle.js; metadata.js; musicchannel.js; norecording.js; Random GIFs.js; rememberChannel.js; showcase.js; sound.js; welcometext.js
- Report date: 05.08.2017 20:23:12 CEST +02:00:00 (timezone: Europe/Berlin)
- youtube-dl Version: 2017.07.23
- DiagScript version: 0.5.1
UploadLimit = 200000000
MTU = 1500
SampleInterval = 100
LicenseKey = "w7xBTxsyE9pqEzwEopiRCGWqHuWr817QUxK4haueExk="
DisableLocalXServer = false
DebugLocalXServer = false
License = ****
2017/08/05 20:39:16 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin Random GIFs.js
2017/08/05 20:39:16 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2017/08/05 20:39:16 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin aloneMode.js
2017/08/05 20:39:16 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin badchan.js
2017/08/05 20:39:16 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2017/08/05 20:39:16 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin come.js
2017/08/05 20:39:16 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin covatar.js
2017/08/05 20:39:16 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin dev.js
2017/08/05 20:39:16 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2017/08/05 20:39:16 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin idle.js
2017/08/05 20:39:16 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin metadata.js
2017/08/05 20:39:16 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin musicchannel.js
2017/08/05 20:39:16 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2017/08/05 20:39:16 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin rememberChannel.js
2017/08/05 20:39:16 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin showcase.js
2017/08/05 20:39:16 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin sound.js
2017/08/05 20:39:16 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcometext.js
2017/08/05 20:39:16 X [MAIN] Starting up fake x-server...
a manual update is required
Was sollte darin enthalten sein?Ich konnte das Problem lösen. Annscheinend hat es mein Server-Anbieter geschafft, meine resolv.conf zu leeren...
