_XDarkShadowX_
Huhu
Habe sowas noch nie gemacht, wie kann ich dieses Script so konfigurieren, dass der Name einer meiner beiden Musikbots so ist: Musik | (aktueller Titelname) ?
https://forum.sinusbot.com/resources/advanced-display-playback-information.47/
Also dass ich die .js Datei öffnen muss, weiß ich, ich kapiers aber nicht ^^.
Hier noch der Inhalt der Datei, damit ihr es euch nicht extra runterladen müsst:
Danke schonmal
LG
registerPlugin({
name: 'Advanced display playback information',
version: '1.4',
description: 'It can replace the channel name on the current radio/track and add the playback indicator ►/■, replace the bot nick on the artist + track, radiostation or ►/■ + the nickname of your choice. In the custom description bot can display all the information about the track plus the title of the currently playing playlist, the current position (in real time), the length of the track, as well as simulation of N-band graphic equalizer (N from 3 to 50). Attention! The maximum length of the nickname 30 characters, name of the channel 40, the excess will be cut off!',
author: 'kapabac',
vars: [
title: 'Allow to change the channel name on the name of the current station/track (for this function, the bot need privileges b_channel_modify_name and perhaps i_channel_modify_power)',
type: 'select',
options: [
'no',
'yes'
indent: 1,
title: 'Channel bot whose name will be changed',
type: 'channel',
conditions: [
{ field: 'chc', value: 1 }
indent: 1,
title: 'Display the playback indicator ►/■',
type: 'select',
options: [
'no',
'yes'
conditions: [
title: 'Allow to change the nick bot',
type: 'select',
options: [
'no',
'yes'
indent: 1,
title: 'Options for replacing the nick bot',
type: 'select',
options: [
'artist + track',
'radiostation name',
'the nickname of your choice'
conditions: [
{ field: 'chn', value: 1 }
indent: 2,
title: 'Your chosen nickname of the bot',
type: 'string',
placeholder: 'for example: Radio Bot'
conditions: [
{ field: 'chns', value: 2 }
indent: 1,
title: 'Allow to replace the URL to your phrase when using chat command "!stream"',
type: 'select',
options: [
'no',
'yes'
conditions: [
indent: 2,
title: 'The phrase which can be replaced with the URL when using chat command "!stream". It must be unique for each bot on a server',
type: 'string',
placeholder: 'default: Streaming internet audio'
conditions: [
{ field: 'str', value: 1 }
indent: 1,
type: 'select',
options: [
'no',
'yes'
conditions: [
title: 'Show advanced bot description',
type: 'select',
options: [
'no',
'yes'
indent: 1,
title: 'Display animated simulation of N-band graphic equalizer',
type: 'select',
options: [
'no',
'yes'
conditions: [
{ field: 'chd', value: 1 }
indent: 2,
title: 'Specify the number of bands graphic equalizer N (from 3 to 50, default is 15)',
type: 'number',
placeholder: '15'
conditions: [
{ field: 'sige', value: 1 }
indent: 2,
title: 'Specify how frequently to update the graphic equalizer (FPS from 1 to 5, 1 by default). Attention, increase FPS proportionally increases the load on the CPU, take care!!!',
type: 'number',
placeholder: '1'
conditions: [
indent: 1,
title: 'Display the current position (in real time)',
type: 'select',
options: [
'no',
'yes'
conditions: [
indent: 1,
type: 'select',
options: [
'no',
'yes'
conditions: [
indent: 1,
title: 'Display playback status word or phrase, for example: "Now playing" or "Stopped"',
type: 'select',
options: [
'no',
'yes'
conditions: [
indent: 2,
title: 'Word or phrase while playing',
type: 'string',
placeholder: 'default: Now playing'
conditions: [
{ field: 'spls', value: 1 }
indent: 2,
title: 'A word or phrase when playback is stopped',
type: 'string',
placeholder: 'default: Stopped'
conditions: [
indent: 1,
title: 'Display name of the currently playing playlist if playing a playlist',
type: 'select',
options: [
'no',
'yes'
conditions: [
indent: 2,
title: 'The word "playlist", will appear before the name of the currently playing playlist',
type: 'string',
placeholder: 'default: playlist'
conditions: [
{ field: 'spl', value: 1 }
title: 'The character that will be separate by the radiostation name, artist, and track',
type: 'string',
placeholder: 'default: ~'
title: 'The symbol or the word to be replaced by a null value "undefined" radiostation, artist or track. It must be unique for each bot on a server',
type: 'string',
placeholder: 'default: ---'
var sip;
var desc;
var nick;
var title;
var odesc;
var onick;
var otitle;
var cp = '';
var cpd = '';
var ap = ['▂', '▃', '▅', '▆', '▇'];
if (!config.chcn && config.chc == 1) return;
if (typeof config.str == 'undefined') config.str = 0;
if (typeof config.chc == 'undefined') config.chc = 0;
if (typeof config.chn == 'undefined') config.chn = 0;
if (typeof config.chd == 'undefined') config.chd = 0;
if (typeof config.spl == 'undefined') config.spl = 1;
if (typeof config.sipc == 'undefined') config.sipc = 0;
if (typeof config.sipn == 'undefined') config.sipn = 0;
if (typeof config.sipd == 'undefined') config.sipd = 1;
if (typeof config.chns == 'undefined') config.chns = 0;
if (typeof config.spos == 'undefined') config.spos = 1;
if (typeof config.spls == 'undefined') config.spls = 1;
if (typeof config.sige == 'undefined') config.sige = 1;
if (config.spls == 1) {
if (typeof config.dplay == 'undefined' || config.dplay == '') config.dplay = 'Now playing';
if (typeof config.dstop == 'undefined' || config.dstop == '') config.dstop = 'Stopped';
} else {
config.dplay = '';
config.dstop = '';
if (config.chns == 2) {
if (typeof config.nnick == 'undefined' || !config.nnick) return;
if (typeof config.sep == 'undefined' || !config.sep) {
var sepn = '~';
var sepd = ' ~ ';
} else {
var sepn = config.sep;
var sepd = ' ' + config.sep + ' ';
if (typeof config.undef == 'undefined' || !config.undef) {
var undef = '---';
} else var undef = config.undef;
if (typeof config.fps == 'undefined' || !config.fps || config.fps < 1 || config.fps > 5) {
var fps = 1;
} else var fps = config.fps;
if (config.spl == 1) {
if (typeof config.wpl == 'undefined' || config.wpl == '') {
var wpl = 'playlist';
} else var wpl = config.wpl;
if (config.sipc == 1 || config.sipn == 1 || config.sipd == 1) var sip = 1;
if (!config.band || config.band < 3 || config.band > 50) config.band = 15;
if (typeof config.strs == 'undefined' || !config.strs) config.strs = 'Streaming internet audio';
setInterval(function() {
var track = sinusbot.getCurrentTrack();
if (!track) return;
var apd = '';
var pln = '';
var typ = track.type;
var tit = track.title;
var talb = track.album;
var tTit = track.tempTitle;
var tArt = track.tempArtist;
if (typeof tit == 'undefined' || tit == '') tit = undef;
if (typeof talb == 'undefined' || talb == '') talb = undef;
if (typeof tArt == 'undefined' || tArt == '') tArt = undef;
if (typeof tTit == 'undefined' || tTit == '') tTit = undef;
var cPlI = sinusbot.getCurrentPlaylistId();
if (cPlI != '') {
if (wpl[0].match(/[a-zA-Z]/)) {
var l = 1;
} else var l = 2;
pln = ' ' + wpl[0].toLowerCase() + wpl.substring(l) + ' "' + sinusbot.playlistGet(cPlI).name + '"';
} else pln = wpl[0].toUpperCase() + wpl.substring(l) + ' "' + sinusbot.playlistGet(cPlI).name + '"';
if (sinusbot.playing()) {
if (config.sige == 1) {
for (i = 0; i < config.band; i++) {
apd += ap[Math.floor(Math.random() * 5)];
apd += ' ';
cpd = '' + config.dplay;
if (sip == 1) cp = '► ';
} else {
apd += '▂';
apd += ' ';
cpd = '' + config.dstop;
if (sip == 1) cp = '■ ';
var dh = Math.floor(track.duration / 3600000);
var dm = Math.floor(track.duration / 60000) - dh * 60;
if (dm < 10) dm = '0' + dm;
var ds = Math.floor(track.duration / 1000) - dm * 60 - dh * 3600;
if (ds < 10) ds = '0' + ds;
if (dh == 0) {
dh = '';
} else dh = dh + ':';
var dt = sepd + dh + dm + ':' + ds;
if (config.spos == 1) {
var ph = Math.floor(getPos() / 3600000);
var pm = Math.floor(getPos() / 60000) - ph * 60;
if (pm < 10) pm = '0' + pm;
var ps = Math.floor(getPos() / 1000) - pm * 60 - ph * 3600;
if (ps < 10) ps = '0' + ps;
var pt = ph + ':' + pm + ':' + ps + ' ';
} else var pt = '';
if (config.sipd != 1) {
var dcp = '';
} else var dcp = cp;
if (apd == '' && pt == '' && cp == '' && cpd =='' && pln == '') {
var sepo = '';
} else var sepo = sepd;
if (typ == 'url') {
if ((tit.substring(0,7) == 'http://' || tit.substring(0,8) == 'https://') && config.str == 1) tit = config.strs;
desc = apd + pt + dcp + cpd + pln + sepo + tit + sepd + tArt + sepd + tTit;
} else {
tArt = track.artist;
if (typ == 'ytdl') {
desc = apd + pt + dcp + cpd + pln + sepo + talb + sepd + tit;
} else desc = apd + pt + dcp + cpd + pln + sepo + tArt + sepd + tit + sepd + talb + dt;
var sdesc = '';
for (i = 0; i < 200; i++) {
sdesc += desc.charAt(i);
if (sdesc != odesc) {
sinusbot.setDescription(sdesc);
odesc = sdesc;
if (config.sipn != 1) {
var ncp = '';
} else var ncp = cp;
if (config.chn == 1) {
if (typ == 'url') {
nick = tArt + sepn + tTit;
} else {
nick = talb + sepn + tit;
} else nick = tArt + sepn + tit;
if (config.chns == 1) {
nick = ncp + tit;
} else {
nick = ncp + config.nnick;
} else nick = ncp + nick;
var snick = '';
for (i = 0; i < 30; i++) {
snick += nick.charAt(i);
if (snick != onick) {
sinusbot.setNick(snick);
onick = snick;
if (config.sipc != 1) {
var ccp = '';
} else var ccp = cp;
if (config.chc == 1) {
if (typ != 'url') {
tit = talb;
} else tit = tArt;
title = ccp + tit;
var stitle = '';
for (i = 0; i < 40; i++) {
stitle += title.charAt(i);
if (stitle != otitle) {
sinusbot.channelUpdate(config.chcn, { name: stitle });
otitle = stitle;
}, 1000 / fps);
Danke schonmal
LG
