Bot License fail?
T4LLY-0
Hi, I got a license to increment the amount of bots. After adding the the file and restarting sinusbot the bot/s they're not joining at all and I still only have an increment of 2 bots.
I see in the bot log "NOK Limit exceeded"
T4LLY-0
Ubuntu Linux 16.04.6
I did what the instructions say, using the .dat file.
Restarted, then they don't join anymore.
T4LLY-0
Ok. It seems to be working now. I did a bit of fiddling about. I removed Python totally. Re-installed Python, updated the system <again!> And Bingo!
I'm not blaming Python, just saying that's what I did. After a system reboot, they're there. The previous bot before the license issue joins now too.
fabm3n
Tier II
Tier I
Ubuntu 16.04 is no longer supported by Sinusbot (If I remember correctly because of the TS Client).
It would be the best if you upgrade when you have some free minutes (or hours) :D
T4LLY-0
Well it's plodding along just fine now. I'm happy. It's my first real set up and it's working, yay!
But I'll look into upgrading soon.
Thanks for your input.
