Bot not starting [solved]
D
Deleted member 3323
Guest
Hello I can not turn on the bot gives me the following error. hoping your reply I wish you a good day
Crashdump ENABLED, directory is: /root/.ts3client/crashdumps
DUMP defined! Dumpdir is: /root/.ts3client/crashdumps
2016-06-16 08:16:13.169820|INFO | | |TeamSpeak 3 Client 3.0.18.2 (2015-10-22 11:14:48)
2016-06-16 08:16:13.185836|INFO | | |SystemInformation: Linux 3.13.0-88-generic #135-Ubuntu SMP Wed Jun 8 21:10:42 UTC 2016 x86_64 Binary: 64bit
2016-06-16 08:16:13.210303|INFO | | |Using hardware aes
2016-06-16 08:16:14.632547|ERROR |PulseAudio | |pa_context_connect failed
2016-06-16 08:16:14.632719|ERROR |SoundBckndIntf| |/opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2016-06-16 08:16:15.208576|INFO | | |Loading plugin: libclientquery_plugin
2016-06-16 08:16:15.208768|INFO | | |Loading plugin: liblua_plugin
2016-06-16 08:16:15.208830|INFO | | |Loading plugin: libsoundbot_plugin
2016-06-16 08:16:15.208883|INFO | | |Loading plugin: libtest_plugin
2016-06-16 08:16:15.399403|INFO |Query | |listening on 127.0.0.1:25639
voiceloop quit
2016-06-16 08:16:21.703269|INFO | | |*** Time [SERVERVIEW]: 157
2016-06-16 08:16:21.759216|INFO | | |*** Time [SERVERVIEWMANAGER]: 184
^Cxinit: connection to X server lost
waiting for X server to shut down The X11 connection broke: I/O error (code 1)
XIO: fatal IO error 22 (Invalid argument) on X server ":1"
after 274475 requests (274475 known processed) with 0 events remaining.
QObject::~QObject: Timers cannot be stopped from another thread
xinit: unexpected signal 2
sorry
hardware specs VPS
Ubuntu 14.04 64Bit
Version: sinusbot-0.9.11-ee30ef7
Config.ini
TS3Path = "/opt/ts3soundboard/TeamSpeak3-Client-linux_amd64"
Update to the latest beta
Thats not the "big" config. You need to set the rights in linux correctly
I did update but it has not solved anything, should I do that command to set the rights to Linux?
/opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64: symbol lookup error: /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64: undefined symbol: _ZN9QMetaType22registerNormalizedTypeERK10QByteArrayPFvPvEPFS3_S3_PKvEi6QFlagsINS_8TypeFlagEEPK11QMetaObject
so strange... How do you start the Bot?
in the beta version, you just need to type
./sinusobt
./sinusobt
start command: xinit /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -ac
I made another attempt to change the command line to turn it now gives me the following error
root@vmi71920:/opt/ts3soundboard# xinit /opt/ts3soundboard/TeamSpeak3-Client-linux_amd64 -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -ac
Initializing built-in extension Generic Event Extension
Initializing built-in extension SHAPE
Initializing built-in extension MIT-SHM
Initializing built-in extension XInputExtension
Initializing built-in extension XTEST
Initializing built-in extension BIG-REQUESTS
Initializing built-in extension SYNC
Initializing built-in extension XKEYBOARD
Initializing built-in extension XC-MISC
Initializing built-in extension SECURITY
Initializing built-in extension XINERAMA
Initializing built-in extension XFIXES
Initializing built-in extension RENDER
Initializing built-in extension RANDR
Initializing built-in extension COMPOSITE
Initializing built-in extension DAMAGE
Initializing built-in extension MIT-SCREEN-SAVER
Initializing built-in extension DOUBLE-BUFFER
Initializing built-in extension RECORD
Initializing built-in extension DPMS
Initializing built-in extension Present
Initializing built-in extension DRI3
Initializing built-in extension X-Resource
Initializing built-in extension XVideo
Initializing built-in extension XVideo-MotionCompensation
Initializing built-in extension SELinux
Initializing built-in extension GLX
Do not start the bot with Xinit just
./sinusbot
And what do you do with the teamspeak client? you dont need to do something with him. Just set the path in the config.
./sinusbot
root@vmi71920:/opt/ts3soundboard# ./sinusbot -RunningAsRootIsEvilAndIKnowThat
2016/06/16 16:15:05 [GENERAL/!!!!!!!] WARN !!!!!!! YOU ARE RUNNING THE BOT AS UID 0 (ROOT) WITHOUT HAVING SET ANOTHER UID. THIS IS A SERIOUS SECURITY VIOLATION !!!!!!!!
Edit your config.ini and set TS3Path to the TS3-Client-executable (not the directory).
Good evening, I wanted to announce that I have resolved and you can close the post
Thanks for the help
