Bot verbindet sich nicht da er Einstellungen nicht speichern kann
ManuGun
Hallo
Ich wollte den Sinusbot richtig einstellen also IP, Name etc. aber dann kommt immer dieser Fehler:
CHAN CHANPW ANNOUNCE ANNOUNCESTR DUCKING DUCKINGVOLUME STICKY TTSLOCALE CHATIGNSRV CHATIGNPRIV CHATIGNCHAN CC OK
und im Log steht zwar das er sich verbindet, aber dies tut er nicht.
Log:
2016/08/01 10:24:52 f1af5fe5 INFO   Initializing bot://f1af5fe5-1a47-4e22-bf28-5f3a14341696
2016/08/01 10:24:52 f1af5fe5 95f1ae8d INFO   Loaded
2016/08/01 10:24:52 Auto-Starting f1af5fe5-1a47-4e22-bf28-5f3a14341696/95f1ae8d-0237-4f91-a59b-ef77e1116235 in 2500 ms...
2016/08/01 10:24:52 f1af5fe5 9554cfa6 INFO   Loaded
2016/08/01 10:24:52 Auto-Starting f1af5fe5-1a47-4e22-bf28-5f3a14341696/9554cfa6-d7bf-493d-bf8e-485b18343fb4 in 5000 ms...
2016/08/01 10:24:52 FFmpeg/avcodec v3675236; license: LGPL version 2.1 or later; 494 codecs
2016/08/01 10:24:52 FFmpeg/avformat v3674980; license: LGPL version 2.1 or later; 139 formats
2016/08/01 10:24:52 youtube-dl checking...
2016/08/01 10:24:52 fork/exec /usr/local/bin/youtube-dl: exec format error youtube-dl not found
2016/08/01 10:24:52 RadioStation data loaded
2016/08/01 10:24:52 Imported radio stations
2016/08/01 10:24:55 f1af5fe5 95f1ae8d INFO   Starting instance ts3server://37.59.195.46?port=9987&nickname=2222222&password=&channel=&channelpassword=
2016/08/01 10:24:57 f1af5fe5 9554cfa6 INFO   Starting instance ts3server://37.59.195.46?port=9987&nickname=PatArtworks2&password=&channel=&channelpassword=
2016/08/01 10:25:14 f1af5fe5 INFO   LOGIN [admin] OK
2016/08/01 10:25:14 f1af5fe5 95f1ae8d INFO   BOT-CONFIG [admin] CHAN CHANPW ANNOUNCE ANNOUNCESTR DUCKING DUCKINGVOLUME STICKY TTSLOCALE CHATIGNSRV CHATIGNPRIV CHATIGNCHAN CC OK
2016/08/01 10:25:16 f1af5fe5 95f1ae8d INFO   BOT-CONFIG [admin] CHAN CHANPW ANNOUNCE ANNOUNCESTR DUCKING DUCKINGVOLUME STICKY TTSLOCALE CHATIGNSRV CHATIGNPRIV CHATIGNCHAN CC OK
Sinusbot Version: 0.9.8
System: Debian 8
Browser: Google Chrome
Arbeitsspeicher: 16GB Ram
config.ini
Zum einen update mal auf die neuste Beta zum anderen checke die Berechtigungen von dem Sinusbot Ordner nach.
ManuGun
Mit der neuen Version kommt der Error immer noch. Welche Rechte brauch den der Sinusbot Ordner 777 oder 755. Der Sinusbot Ordner ist liegt ja in diesem Pfad /opt/ts3soundboard?
