Bot will nicht Starten
 - Kernel: Linux 4.9.0-0.bpo.9-amd64 x86_64
 - Load Average: 0.42 0.29 0.14
 - Uptime: 0 days, 0 hours, 5 minutes, 46 seconds
 - OS APT Last Update: 05.08.2019 01:12:46 CEST +02:00:00
 - Shell Locale: de_DE.UTF-8
    CPU(s):                1
    Thread(s) per core:    1
    Core(s) per socket:    1
    Socket(s):             1
    Model name:            Common KVM processor
    CPU MHz:               3990.756
    Hypervisor vendor:     KVM
    Virtualization type:   full
 - RAM: 72.69 MB/492.26 MB in use (14%)
 - SWAP: 0 B/671.99 MB in use (0%)
 - DISK: 6.25 GB/13.99 GB in use (44%)
   - libglib: 2.42.1-1+deb8u2
   - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2019.08.02)
    linux-vdso.so.1 (0x00007ffdb4d89000)
    libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007f0351f32000)
    libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007f0351bda000)
    libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007f03517d9000)
    libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007f0350e74000)
    libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007f0350c00000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007f03509fc000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007f03506fb000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007f03504de000)
    libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007f03501d3000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007f034ffbd000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007f034fc12000)
    libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007f034f9f7000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f034f7ef000)
    /lib64/ld-linux-x86-64.so.2 (0x00007f035214c000)
 - Time (local): 05.08.2019 01:31:29 CEST +02:00:00
 - Time (remote): 05.08.2019 01:31:29 CEST +02:00:00
 - TeamSpeak3 Version: 3.3.0
 - youtube-dl Version: 2019.08.02
config.ini:
ExternalFileBase = ""
LicenseKey = "WWG0rRckhGb7ad8gmzVXU3qU2Mgd9rzlH8q9L4Qg/wo="
  DevMode = false
[TTS]
  Enabled = false
INSTANCE-LOG:
2019-08-05T01:40:24+02:00 closing channels
2019-08-05T01:40:23+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-08-05T01:40:23+02:00 Closed.
2019-08-05T01:40:23+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: symbol lookup error: /opt/sinusbot/teamspeak3-client/libQt5XcbQpa.so.5: undefined symbol: FT_Get_Font_Format
2019-08-05T01:40:23+02:00 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2019-08-05T01:40:23+02:00 TS>QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-sinusbot'
2019-08-05T01:40:23+02:00 TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present
2019-08-05T01:40:23+02:00 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2019-08-05T01:40:23+02:00 TS>/opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: /lib/x86_64-linux-gnu/libdbus-1.so.3: no version information available (required by /opt/sinusbot/teamspeak3-client/libQt5WebEngineCore.so.5)
2019-08-05T01:40:23+02:00 TS |INFO |Addons | |Checking for addon updates...
2019-08-05T01:40:23+02:00 TS |INFO | | |*** Time [ICONMANGER]: 194
2019-08-05T01:40:23+02:00 TS |ERROR |RevocationListCache| |Failed to import revocation list from cache
2019-08-05T01:40:23+02:00 TS |INFO |ClientUI | |Unable to create an Open GL context.
2019-08-05T01:40:23+02:00 TS |ERROR |SoundBckndIntf| |/opt/sinusbot/teamspeak3-client/soundbackends/libpulseaudio_linux_amd64.so error: INIT_PA_IMPL
2019-08-05T01:40:23+02:00 TS |ERROR |PulseAudio | |pa_context_connect failed -
2019-08-05T01:40:23+02:00 TS |ERROR |PulseAudio | |failed to connect to pulse audio server -
2019-08-05T01:40:22+02:00 TS |INFO | | |SystemInformation: Linux 4.9.0-0.bpo.9-amd64 #1 SMP Debian 4.9.168-1+deb9u4~deb8u1 (2019-07-22) x86_64 Binary: 64bit
2019-08-05T01:40:22+02:00 TS |INFO | | |TeamSpeak 3 Client 3.3.0 (2019-06-18 09:29:01)
2019-08-05T01:40:22+02:00 TS>DUMP defined! Dumpdir is: /opt/sinusbot/data/ts3/c5b994e9-4401-4551-a0be-9ac2c22b4686/b9ef63d6-947e-4d1e-afad-7c4501e34f83/crashdumps
2019-08-05T01:40:22+02:00 TS>Crashdump ENABLED, directory is: /opt/sinusbot/data/ts3/c5b994e9-4401-4551-a0be-9ac2c22b4686/b9ef63d6-947e-4d1e-afad-7c4501e34f83/crashdumps
2019-08-05T01:40:22+02:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019-08-05T01:40:22+02:00 Could not insert into News-Tableno such table: News
2019-08-05T01:40:22+02:00 Could not delete from Newsno such table: News
2019-08-05T01:40:22+02:00 Could not insert into Profiles-Tableno such table: Profiles
2019-08-05T01:40:22+02:00 Could not delete from Profilesno such table: Profiles
2019-08-05T01:40:22+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2019-08-05T01:40:22+02:00 Could not delete from FileTransferno such table: FileTransfer
2019-08-05T01:40:22+02:00 Could not create Notifications-Tabletable Notifications already exists
2019-08-05T01:40:22+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019-08-05T01:40:22+02:00 Could not create Chat-Tabletable Chat already exists
2019-08-05T01:40:22+02:00 About to run.
2019-08-05T01:40:22+02:00 Prespawn.
2019-08-05T01:40:15+02:00 script command loaded
2019-08-05T01:40:15+02:00 module registered as command
2019-08-05T01:40:15+02:00 registered callback for event chat
2019-08-05T01:40:15+02:00 serialized function: true
2019-08-05T01:40:15+02:00 Initialization complete
2019-08-05T01:40:15+02:00 executing script command
Bot will nicht starten, bitte keine Dummen Kommentare wie: Der Bot mag dich nicht
Diese Fragen sind Sinnlos und Helfen mir nicht
Ich wollte nen Bot Installieren und es ging nicht...
Nunja, anhand der Posts die so zur Zeit im Zuge des TS 3.3.0 Version reinkommen, scheint der Bot in der Tat einige Sachen nicht zu mögen. Glücklicherweise gehörst du nicht dazu.
Allerdings gibt es einige Leute mit ziemlich identischen Fehlermeldungen (TS-Client crasht, Bot an sich läuft ja).
https://forum.sinusbot.com/threads/connection-problem.7221/
Du könntest die Lösungsvorschläge obiger Links durcharbeiten, allerdings lief es bei beiden darauf raus, auf Debian 10 upzugraden. Die Specs deines VPS deuten ja darauf hin, dass du nur den Bot darauf betreibst.
Probiere vorher mal folgende Commands noch (evtl. mit sudo davor):
apt-get update
apt-get upgrade
apt-get install -y x11vnc xvfb libxcursor1 ca-certificates bzip2 libnss3 libegl1-mesa x11-xkb-utils libasound2 libpci3 libxslt1.1 libxkbcommon0 curl libglib2.0-0
Ich habe auch die neuste Version vom Kernel, aber auf 5 Update ich nicht, da noch bei Debian es buggt. Ich habe alle apt Pakete Installiert.
Himsel
Mir scheint es so als würde dieser Fehler halt nur auf Debian 8 auftauchen. Ich würde dir auch empfehlen auf Debian 9 oder sogar 10 zu updaten. Es gibt bislang keine gescheite Lösung "glaube ich".
Kannst du eventuell mal folgende Befehle eingeben, wenn du dich im Teamspeak Client Ordner befindest und die Outputs hier zeigen?
ldd libQt5WebEngineCore.so.5
und
sudo find / -name "libdbus-1.so.3"
