Solved Bots Disconnecting daily
R3v07v3R
Hi Guys,
I've been using the bots for a few years and they're amazing! Thank you.
I have been having an issue with the bots disconnecting every day, sometimes twice a day.
I will then need to SSH into the server and run"service sinusbot restart".
The web interface also becomes unavailable, but this appears to be a by-product of the service not running.
Below is a link to my Log File (@lvl-10) and the Debug Script Output.
Log File:
https://pastebin.com/CPtqBpPZ
- Operating System: Ubuntu 20.04.1 LTS
- Kernel: Linux 5.4.0-1034-aws x86_64
- Load Average: 0.15 0.07 0.03
- Uptime: 1 days, 1 hours, 2 minutes, 47 seconds
- OS APT Last Update: 07.01.2021 04:00:42 UTC +00:00:00
- Shell Locale: C.UTF-8
    Architecture:                    x86_64
    CPU(s):                          2
    Thread(s) per core:              2
    Core(s) per socket:              1
    Socket(s):                       1
    Model name:                      Intel(R) Xeon(R) Platinum 8175M CPU @ 2.50GHz
    CPU MHz:                         2499.998
    Hypervisor vendor:               KVM
    Virtualization type:             full
- RAM: 523.28 MB/953.37 MB in use (54%)
- DISK: 8.10 GB/9.63 GB in use (84%)
   - libglib: 2.64.3-1~ubuntu20.04.1
   - TS3Path = /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64 (Version 3.5.3)
   - YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2021.01.03)
- Installed scripts: advertising.js; alonemode.js; bookmark.js; channelcleaner.js; command.js; followme.js; norecording.js; rememberChannel.js; simple_channel_creator.js; simple_channel_notifications.js; sinusbot-commands.js; welcome.js
    linux-vdso.so.1 (0x00007ffe6945c000)
    libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007fd518091000)
    libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007fd517d39000)
    libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007fd517938000)
    libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007fd516fd3000)
    libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007fd516d5f000)
    libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fd516d50000)
    libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fd516bff000)
    libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fd516bdc000)
    libstdc++.so.6 => /lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fd5169fb000)
    libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fd5169e0000)
    libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fd5167ee000)
    libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fd5167d2000)
    librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007fd5167c5000)
    /lib64/ld-linux-x86-64.so.2 (0x00007fd5182ad000)
- Time (local): 07.01.2021 06:37:00 UTC +00:00:00
- Time (remote): 07.01.2021 06:37:00 UTC +00:00:00
- Timezone: Etc/UTC
- TeamSpeak3 Version: 3.5.3
- youtube-dl Version: 2021.01.03
R3v07v3R
I'm sure all the system info is in the Debug Script, however, I will pull it out and format it to make it easier.
Added the config.ini at the bottom.
Please let me know if there is any other information I can log or provide to make the diagnosis easier, as I have no idea what else to look for.
  • SinusBot version:
    • 1.0.0-beta.10-202ee4d
  • TS Client:
    • TeamSpeak3 Version: 3.5.3
  • OS:
    • - Operating System: Ubuntu 20.04.1 LTS
  • uname -a:
    • (Linux ip-<server-ip> 5.4.0-1034-aws #35-Ubuntu SMP Thu Dec 17 23:32:42 UTC 2020 x86_64 x86_64 x86_64 GNU/Linux)
  • hardware specs:
    • CPU:
      • Architecture: x86_64
        CPU(s): 2
        Socket(s): 1
        CPU MHz: 2499.998
    • RAM:
      • 523.28 MB/953.37 MB in use (54%)
    • HDD:
      • DISK: 8.10 GB/9.63 GB in use (84%)
ExternalFileBase = ""
LogFile = "/opt/sinusbot/fullLog.txt"
LicenseKey = "L79uB1ngvx+kuPq/ULOZ+xzhNu2tPmNHYWulTWK4JE4="
DevMode = false
[TTS]
Enabled = false
I'm really sorry, I didn't see the debug in the spoiler but looked for the output in the pastebin.
Your available RAM seems pretty low, that might be it.
You said the web interface isn't available as the process has been stopped when it happens, so if that's not due to a crash, your system log might deliver more info on that (on high memory pressure processes might get killed). So you could try and search for clues in your /var/log/messages, /var/log/syslog (whichever of these exists for you) and the dmesg output.
R3v07v3R
Alright, I happened to be online when the bots disconnected.
I checked the /var/log/syslog file as you suggested and filtered the results for for "sinusbot", below are the results;
Jan 10 04:19:43 ip-<server-ip> kernel: [341133.871582] [ 55733] 1002 55733 16022 260 102400 0 0 sinusbot
Jan 10 04:19:43 ip-<server-ip> kernel: [341133.871584] [ 55734] 1002 55734 777429 38142 3096576 0 0 sinusbot
Jan 10 04:19:43 ip-<server-ip> kernel: [341133.871654] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/system.slice/sinusbot.service,task=sinusbot,pid=55734,uid=1002
Jan 10 04:19:43 ip-<server-ip> kernel: [341133.871707] Out of memory: Killed process 55734 (sinusbot) total-vm:3109716kB, anon-rss:152552kB, file-rss:16kB, shmem-rss:0kB, UID:1002 pgtables:3024kB oom_score_adj:0
Jan 10 04:19:43 ip-<server-ip> kernel: [341133.941127] oom_reaper: reaped process 55734 (sinusbot), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
Jan 10 04:19:44 ip-<server-ip> systemd[1]: sinusbot.service: Main process exited, code=exited, status=255/EXCEPTION
Jan 10 04:19:45 ip-<server-ip> systemd[1]: sinusbot.service: Failed with result 'exit-code'.
From what I can make out, the "Out of memory: Killed process 55734 (sinusbot)" is the issue.
Good guess!
I was not sure what to set the system up with initially.
I have added;
Please let me know if you think I should modify those values.
I will get back to you in 24 hours if it hasn't crashed
