Bug Default theme in config isn't working
arkanium
Operating System: Windows
SinusBot Version: 0.9.18
TS3 Version: 3.0.19.4
Tonight I wanted to connect to the bot as every time I had nothing touch at the config.ini level and login page any bug I let you watch on this screenshot
http://prntscr.com/eqg6zd
My default theme is "Paper", and when I put another theme all remarks. I do not understand.
Here is my config.ini in pastebin
https://pastebin.com/DXL2gBiY
I am sorry but being a beginner in sinusbot I did not find the file with the logs.
I thank you in advance
I am available for any proposal,
Sincerly
Arkanium.
PASTEBIN (config.ini) => https://pastebin.com/DXL2gBiY
Screen bug => http://prntscr.com/eqg6zd
EDIT : It does not work when I put another theme
quick summary (from chat):
- setting default themes in the config doesn't seem to work
- personal settings are lost after logout
siysco
I think I am experiencing the same issue and symptoms with SinusBot 0.9.21 on Debian 9.
Setting a default theme via the config.ini file does not work.
When you do set a default theme, via config.ini, you get this.
Setting a theme within Personal Settings works and, in my experience, persists.
Maybe this is a simple syntax error? Are we doing this wrong?
There is limited documentation about the [Themes] function, so it is hard telling.
This works and loads the default red theme.
Anything else causes this.
  Default = "Cosmo"
Maybe the ID is lowercase? Nope, still causes this.
  Default = "cosmo"
