[English]How to install a script
Linux: just install a beta and drop the script (js file) into the scripts folder
Windows: not available atm no eta
TGTGamer
When I fix my Linux version, I will write a Tutorial, Step by step for using both Vb & online servers.
TGTGamer
Whats so complicated to "install" or copy a script into the "scripts/" folder?
What do you mean with "Vb" and "online servers"? ;)
VirtualBox servers and rented servers. This allows anyone to run bots with commands, It will probably be added onto a "How to linux" tutorial with video, including setting up Vb.
christo
Thank you for your reply, I have a scripts folder on the beta version but none of the scripts apparaits the bot.
TGTGamer
Can you explain that?
Have you got a log which you can show me?
Like I said, i'm still working on getting the latest version working. I'v actually just reinstalled
sinusbot-0.9.9-8f70ff3
Latest version keeps crashing on me, I have 4 Vb servers which im running the latest on, trying to error code this crash. But the 0.9.9 is stable on my system and isnt crashing....
Be sure, that you redownload the file. Flyth reuploaded a newer version, but he version number didn't changed.
TGTGamer
Tried that. You can see this conversation here over in the bug reports.
-- Topic solved --
