HELP
Try_Harder_26
Command which failed was: " su -c "$LOCATION/sinusbot" $SINUSBOTUSER". Please t ry to execute it manually and attach the output to the bug report in the forum t hread.
If it still doesn't work report this to the author at https://forum.sinusbot.com /threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause t his is an error of your system not of the installer script. Line 1097.
Try_Harder_26
[QUOTE = "flyth, post: 40185, member: 2"]
Versuchen Sie es noch einmal, indem Sie diesen Text lesen ... * seufz *
[/ZITAT]
welchen text?
Try_Harder_26
Checking for the latest installer version
Your installer is up-to-date.
Installer by Philipp Esswein | DAThosting.eu - Your game-/voiceserver hoster (on ly german).
Please rate this script at: https://forum.sinusbot.com/resources/sinusbot-instal ler-script.58/
You're using installer 1.5
What should the installer do?
1) Install
2) Update
3) Remove
4) PW Reset
5) Quit
#? 1
1Done!
Automatically chosen system.d for your startscript!
1) Automatic
2) Own path
3) Quit
Should I install TeamSpeak or only Discord Mode?
1) Both
2) Only Discord
3) Quit
#? 1
SinusBot already installed with automatic install option!
Would you like to update the bot instead? [Y / N]: Y
1) No
2) Yes
#? 2
1) Yes
2) No
#? 1
Update the system packages to the latest version? Recommended, as otherwise depe ndencies might break! Option "No" will exit the installer
1) Yes
2) No
#? 1
Starting the installer now!
Detected latest TS3-Client version as 3.2.5
Reading package lists... Done
Building dependency tree
ntp is already the newest version (1:4.2.8p10+dfsg-3+deb9u2).
Packages installed!
Local time: Fri 2019-06-14 14:37:04 CEST
Universal time: Fri 2019-06-14 12:37:04 UTC
RTC time: Fri 2019-06-14 12:37:04
Time zone: Europe/Berlin (CEST, +0200)
Network time on: yes
NTP synchronized: yes
RTC in local TZ: no
Automatically set time to Fri Jun 14 14:37:04 CEST 2019!
Added TS3 Path to config.
TS3 already latest version.
Downloading latest SinusBot.
Extracting SinusBot files.
SinusBot update done.
Starting systemd installation
Installed systemd file to start the SinusBot with "service sinusbot {start|stop|status|restart}"
Installing YT-Downloader now!
cat: /etc/cron.d/ytdl: No such file or directory
Installing Cronjob for automatic YT-DL update...
Installing Cronjob successful.
Downloading YT-DL now...
Download successful!
youtube-dl is up-to-date (2019.06.08)
Please wait... This will take some seconds!
___ ___ _ _ _ _ ___ ___ ___ _____
Version: 1.0.0-beta.1-06a54d7
could not contact update server
If it still doesn't work report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Line 1097.
Qhiliqq
Licensed Partner
https://forum.sinusbot.com/threads/...update-server-german-deutsch.7050/#post-40207
Your IP is most likely banned. Don't waste your time re-installing. Read the link in post #8
Thread starter Similar threads Forum Replies Date
Pwned General Questions 10
D General Questions 5
H General Questions 0
wiggy General Questions 3
serar General Questions 3
