Solved Hilfe ersucht
_XSERVTransSocketOpenCOTSServer: Unable to open socket for inet6
_XSERVTransOpen: transport open failed for inet6/vs001:1
_XSERVTransMakeAllCOTSServerListeners: failed to open listener for inet6
[dix] Could not init font path element /usr/share/fonts/X11/Type1, removing from list!
Version: 0.9.18-8499d2c
2017/05/11 15:33:42 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2017/05/11 15:33:42 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin aloneMode.js
2017/05/11 15:33:42 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin badchan.js
2017/05/11 15:33:42 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2017/05/11 15:33:42 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin covatar.js
2017/05/11 15:33:42 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin dev.js
2017/05/11 15:33:42 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2017/05/11 15:33:42 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin idle.js
2017/05/11 15:33:42 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin metadata.js
2017/05/11 15:33:42 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2017/05/11 15:33:42 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin rememberChannel.js
2017/05/11 15:33:42 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin showcase.js
2017/05/11 15:33:42 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin sound.js
2017/05/11 15:33:42 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcometext.js
2017/05/11 15:33:42 X [MAIN] Starting up fake x-server...
2017/05/11 15:33:42 Could not open X11 socket. This happens either if the bot is already running or you ran it before using a different user (root?). Please make sure the bot is not running and delete /tmp/.X11-unix/X40 manually.
sinusbot@vs001:/opt/ts3soundboard$
xinit wird schon lange nicht mehr benötigt.
also ich habe alles versucht
Und habe es nun Geschafft
Ich habe die alte version und mit einem Screen gestartet xD danke für die Hilfe
Welche alte version? Hast du etwa die von dem TS3 coach da geladen? Die ist unfassbar alt (2 jahre) und hat nichtmal scriptunsterstüzung.
Alternative nutze doch das sinusbot installer script: https://forum.sinusbot.com/resources/sinusbot-installer-script.58/
Das installiert auch gleichzeitig einen service, womit du den sinusbot von überall mit "service sinusbot start/stop/restart/etc" starten/stoppen kannst.
Das Script ist für Linux Anfänger die wirklich nur den Bot laufen lassen wollen ziemlich gut. Wenn du allerdings die befehle bzw linux generell lernen willst dann ist manuell wahrscheinlich besser.
Hier nochmal der screen eintrag vom Linux-/Ubuntuwiki: https://wiki.ubuntuusers.de/Screen/ (hat mir sehr geholfen am Anfang die Funktionseiweiße von screen zu verstehen :) )
Find es btw sehr gut das du dem Bot erstmal eine 1-Sterne Bewertung gegeben hast, nur weil du etwas falsch gemacht hast :D
Betriebssystem: Linux
SinusBot Version: 0.9.8
TS3 Version: 3.0.18
Problembeschreibung
Erläutere bitte das Problem im Detail. Was hast du getan, was hast du erwartet und was ist stattdessen passiert?
Hallo
ich habe dieses Tutorial Befolgt
https://www.vultr.com/docs/how-to-install-sinusbot-for-teamspeak-3-on-debian
Doch es ist ja eine alte Version von Sinusbot, damit ich die neuere Verwenden kann habe ich das obige Tutorial Benutzt.
Jedoch sobald ich ein Update aufziehen möchte schreibt er Libary not Found!
Auf dem System ist Debian 7 Minimal Installiert!
Ich verzweifel hier langsam, da ich echt keinen Rat mehr weis
Kopiere bitte die Ausgabe des Diagnose-Scripts hierher.
Wie kann ich das machen?
Und wenn ich folgendes mache ./ts3bot -update folgt folgendes
2017/05/17 04:31:45 UPDATER No update available.
Patschi
Aktuellste Version ist hier zu finden, zur Aktualisierung einfach die neuen Dateien über die vorhandenen drüberpacken. Nicht vergessen, dass TS3 Plugin zu aktualisieren. Dann sollte es eigentlich gehen. Ansonsten gib bitte mal die gesamte Rückmeldung des Bots bekannt.
Zudem würde ich zum Umstieg auf Debian Jessie 8 vorschlagen, da Debian Wheezy 7 nicht mehr so lange supportet werden wird. Zudem steht schon Debian 9 in den Startlöchern.
Da mein Tread von
@Xuxe Einfach geschlossen wurde ohne das ich meine Antwort verfassen konnte
@Patschi:
@Patschi:
Nun habe ich ts3bot erneut Gestartet so heisst auch die Datei ts3bot
Dort ist eine Sinusbot datei mit drin wenn ich allerdings mache ./sinusbot oder diesen command verwende
xinit /opt/ts3soundboard/sinusbot-RunningAsRootIsEvilAndIKnowThat -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -ac
Bekomme ich diese ausgabe
/opt/ts3soundboard/sinusbot: 1: /opt/ts3soundboard/sinusbot: cannot open ▒A@▒]▒@8: No such file
/opt/ts3soundboard/sinusbot: 1: /opt/ts3soundboard/sinusbot:ELF: not found
/opt/ts3soundboard/sinusbot: 2: /opt/ts3soundboard/sinusbot: Syntax error: ")" unexpected
root@vs001:/opt/ts3soundboard#
Patschi
Wenn dein Hoster lediglich Debian Wheezy 7 anbietet, würde ich aus Gründen der Sicherheit und Vermeidung vor anwaltlichen Briefen aufgrund eines Serverhacks, den Anbieter direkt wechseln. Und wie auch schon im vorherigen Thread erwähnt: Die uralte Sinusbot 0.9.8er Version und Debian Wheezy 7 sind nicht unterstützt. Aktualisiere daher das OS und den Bot vorher, bevor wir hier mit dem weiteren Troubleshooting beginnen.
Lies die verlinkten Anleitungen. Und starte nur die Sinusbot Binary. Bzw versuche eine saubere Installation ^^
Bin mir ziemlich sicher das es an Debian 7 liegt. Debian 7 ist nun mal offiziell von uns auch nicht mehr Supported.
Ich weis ja nicht wie oft ich das noch sagen soll
@Patchi:
@Huxe:
@Diesmon:
Das Update kann ich nicht Installieren da dort immer kommt Libary Fail
Und dann
ts3bot@vs001:/opt/ts3soundboard$ xinit /opt/ts3soundboard/ts3bot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 -- /usr/bin/Xvfb :1 -screen 0 800x600x16 -ac
xinit: Unable to run program "/opt/ts3soundboard/ts3bot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64": Not a directory
Specify a program on the command line or make sure that /usr/bin
is in your path.
DAS UPDATE IST ABER INSTALLIERT
Patschi
GameNetwork, ich wäre dir sehr verbunden, wenn wir dein 1 Problem bitte ebenfalls auf 1 Thread beschränken könnten. Ansonsten wird das hier nur ein großes Durcheinander...
Den TS3Client direkt zu starten ist weder notwendig, noch möglich, noch dafür gedacht. Abgesehen davon, dass das absolut nichts bringen würde, hast du vermutlich keine grafische Oberfläche drauf, was für den Start des TS3Clients notwendig wäre.
Was sollte an dem Update, indem man ein Archiv runterlädt und entpackt, nicht funktionieren? Du musst ausschließlich Dateien ersetzen. Wenn das nicht geht, ist dein Betriebssystem im Eimer. Und nochmals, Debian 7 ist out-of-date - das wird nicht mehr lange mit Updates seitens der Hersteller unterstützt. Daher gibts auch seitens Sinusbot dafür keine Unterstützung mehr - ist nicht mehr zeitgemäß und in wenigen Monaten eher ein Sicherheitsmangel.
@Game-Network.tk Wie gesagt, du hältst dich an eine Anleitung (mit dem Download link darin) die über 2 Jahre alt ist. Die aktuelle Sinusbot version ist 0.9.18 nicht 0.9.8 (0.9.8 ist ~ 2 Jahre alt). Verstehe echt nicht wieso du nicht die Anleitung des wiki's auf dieser website hier nutzen willst, wenn du den Bot unbedingt per hand installieren willst/musst.
Die wiki Anleitung ist soweit immer aktuell und ausführlich genug beschrieben damit jederman es verstehen sollte.
Ich würde an deiner Stelle die komplette verkorkste Installation die du hast scrappen und nochmal von vorne mit der wiki Anleitung anfangen. Dann sollte eig™ nichts mehr schief gehen.
