I need help with multiple problems/questions.
FreezeMc
Version: 9.15
Operating system: Windows 10
Specs short: i5 processor, 32 RAM (I know...), GTX 980 Ti
Browser: Google Chrome
DataDir = "C:\\SinusBot\\data\\"
YoutubeDLPath = "C:\\SinusBot\\youtube-dl.exe"
LicenseKey = "i/qzFJfCz7HNGacZS9IgfkOn3C3/5/5ICfptq2lrCl0="
AvatarMaxWidth = 300
AvatarMaxHeight = 300
UserAgent = "SinusBot (0.9.13-3609644)"
Hello people,
Been using Sinusbot for a while now and like many others people enjoy the music but like the title betrays I got problems. I am myself not a real programmar, I learn from what I read, get told and try out (learnfast) but getting to the point....
I want to let my musicbot change its own name to the title song, not the channel nor discription. I downloaded a script that lets you do that ''Advanced display playback'' but I can find a way to make it work? Oke, since I couldn't get that to work I just used the build in option to annouce tracks but it will only say it once when started up and not even tell what song it is, like example ''Now playing: (blank)''. I even tried the script ''Now playing''
Another thing is that when I enable the option ''API Showcase'' it start to spam everyone with ''Stop recording!'' and it spams the people with server administrator when the remove/add people's server groups.
I tried using the TTS setting too but I can't seem how to make it work, I used the link found on the forum: http://translate.google.com/translate_tts?tl=__LOCALE&q=__TEXT&ie=UTF-8&total=1&idx=0&client=t and changed the code to EN and without. I tried many other links with no succes and I watched youtube vids how to do it.
The only thing I gotten to work is Youtube-DL and with working commands ( !yt, !ytdl, like that stuff ).
Few things before I end this, my musicbot is NOT a admin on the server, is has premmions to type and play music and such. I was able to set up a server group that can use the !yt commands and my TS account has full premission.
If I need to give any other info I will supply it.
Greetz,
FreezeMc
FreezeMc
I forgot to mention, the script !come and !goaway doesn't seem to work, it just stays where it is. In the logs the bot does recgonize the command but doesn't do anything with it.
I want to let my musicbot change its own name to the title song, not the channel nor discription. I downloaded a script that lets you do that ''Advanced display playback'' but I can find a way to make it work? Oke, since I couldn't [...]
Did you enable and configure the script? If you did maybe ask for help in the discussion thread of the script.
As the name states this is only to showcase the script api to help people understand how to code their own scripts by looking at the code and learning. Of course you shouldn't let it enabled!
(But the recording thing is a known bug in the new version and will be fixed)
The Google TTS does not work. It's written in multiple places. There are many TTS links that do work (and no, I won't search for you but Voice RSS works). It's not a bug, just a typical case of PEBCAK.
congratulations.
