Karate_Creeper
Hi there,
At first I share all information needed as given by the "Read me before you post!"
General specs and stats:
config.ini:
Here's my problem:
I have a license to run 12 bots simultaneously. But as soon as I start the fifth bot, Sinusbot application freezes and crashes after some time. Sometimes the fifth bot also starts but isn't able to connect to the TeamSpeak server (I guess the bot itself starts but the Teamspeak Client crashes]. I used the installer script to set the bot up but I also tried a clean installation using the official tutorial. Here are the logs:
Service status sinusbot when running fine (4 bots):
I noticed that there's a task limit in the service status (165) which seems to be almost there when using 4 bots. But I honestly have no clue how to remove such a limit. I checked for limits in Linux system files but they are all set to some value like 60.000. So I highly doubt that's the reason.
Instance log of a instance crashing when trying to run more than 4 bots:
Bot log doesn't show anything besides "Loading instances" so I don't believe there's a reason to share the bot log.
I also ran the diagSinusbot Script, here's the output:
If there's any information missing feel free to contact me. I tried to put as much information as possible together.
Thank you in advance and kind regards,
Moritz!
Sinusbot version: 1.0.0-beta.1-06a54d7 (Latest!)
TeamSpeak Client Version: 3.2.5 Stable (Latest!)
TeamSpeak Server Version: 3.7.1 Stable (Latest!)
Ubuntu 18.04. 64 bit OS running Plesk
Intel(R) Xeon(R) CPU E5-2680 v2 @ 2.80GHz 8 Core Linux VPS
16GB Ram
config.ini:
ExternalFileBase = ""
InstanceActionLimit = 12
LogFile = "serverlog"
LicenseKey = "9pHa4g2L8YjJZtVJkF20wMIswbGPD29xpsZcw0djjCY="
DevMode = false
UserAgent = "SinusBot (1.0.0-beta.1-06a54d7)"
[TTS]
Enabled = false
Here's my problem:
Active: active (running) since Mon 2019-05-27 23:20:29 CEST; 23h ago
Main PID: 31057 (sinusbot)
Tasks: 154 (limit: 165)
CGroup: /system.slice/sinusbot.service
├─31057 /opt/sinusbot/sinusbot
├─31058 /opt/sinusbot/sinusbot
├─31083 /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64 -nosingleinstance ts3server://127.0.0.1?port=9987&nickname=Party-Bot%201&password=&chann
├─31109 /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64 -nosingleinstance ts3server://127.0.0.1?port=9987&nickname=Party-Bot%202&password=&chann
├─31150 /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64 -nosingleinstance ts3server://127.0.0.1?port=9987&nickname=Lappen-Bot%202&password=&cid=
└─31362 /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64 -nosingleinstance ts3server://127.0.0.1?port=9987&nickname=Kindergarten-Bot%201&password
Mai 27 23:20:34 [IP removed] pulseaudio[31204]: [pulseaudio] main.c: Start des Hintergrunddienstes fehlgeschlagen.
Mai 27 23:20:38 [IP removed] pulseaudio[31240]: [pulseaudio] module-udev-detect.c: Failed to scan for devices.
Mai 27 23:20:38 [IP removed] pulseaudio[31240]: [pulseaudio] module.c: Failed to load module "module-udev-detect" (argument: ""): initialization fai
Mai 27 23:20:38 [IP removed] pulseaudio[31240]: [pulseaudio] main.c: Module load failed.
Mai 27 23:20:38 [IP removed] pulseaudio[31240]: [pulseaudio] main.c: Hintergrunddienst konnte nicht initialisiert werden.
Mai 27 23:20:38 [IP removed] pulseaudio[31237]: [pulseaudio] main.c: Start des Hintergrunddienstes fehlgeschlagen.
Mai 27 23:30:40 [IP removed] pulseaudio[31381]: [pulseaudio] module-udev-detect.c: Failed to scan for devices.
Mai 27 23:30:40 [IP removed] pulseaudio[31381]: [pulseaudio] module.c: Failed to load module "module-udev-detect" (argument: ""): initialization fai
Mai 27 23:30:40 [IP removed] pulseaudio[31381]: [pulseaudio] main.c: Module load failed.
Mai 27 23:30:40 [IP removed] pulseaudio[31381]: [pulseaudio] main.c: Hintergrunddienst konnte nicht initialisiert werden.
2019-05-28T23:03:44+02:00 Closed.
2019-05-28T23:03:44+02:00 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-05-28T23:03:44+02:00 Error spawning instancefork/exec /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64: resource temporarily unavailable
2019-05-28T23:03:44+02:00 Starting instance ts3server://127.0.0.1?port=9987&nickname=Kindergarten-Bot%202&password=&cid=58&channelpassword=
2019-05-28T23:03:44+02:00 Could not insert into FileTransfer-Tableno such table: FileTransfer
2019-05-28T23:03:44+02:00 Could not delete from FileTransferno such table: FileTransfer
2019-05-28T23:03:44+02:00 Could not create Notifications-Tabletable Notifications already exists
2019-05-28T23:03:44+02:00 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019-05-28T23:03:44+02:00 Could not create Chat-Tabletable Chat already exists
2019-05-28T23:03:44+02:00 About to run.
2019-05-28T23:03:44+02:00 Prespawn.
2019-05-28T23:02:39+02:00 registered callback for event clientMove
2019-05-28T23:02:39+02:00 imported module: OKlib.js
2019-05-28T23:02:39+02:00 resolving module OKlib.js
2019-05-28T23:02:39+02:00 script come loaded
2019-05-28T23:02:39+02:00 registered callback for event chat
2019-05-28T23:02:39+02:00 script alonemode loaded
2019-05-28T23:02:39+02:00 Initialization complete
2019-05-28T23:02:39+02:00 script Default-Channel loaded
2019-05-28T23:02:39+02:00 registered callback for event load
2019-05-28T23:02:39+02:00 executing script come
2019-05-28T23:02:39+02:00 executing script alonemode
2019-05-28T23:02:39+02:00 script OKlib loaded
2019-05-28T23:02:39+02:00 module registered as OKlib
2019-05-28T23:02:39+02:00 registered callback for event connect
2019-05-28T23:02:39+02:00 executing script Default-Channel
2019-05-28T23:02:39+02:00 script command loaded
2019-05-28T23:02:39+02:00 module registered as command
2019-05-28T23:02:39+02:00 executing script OKlib
2019-05-28T23:02:39+02:00 executing script command
- Operating System: Ubuntu 18.04.2 LTS (OpenVZ)
- Kernel: Linux 4.15.0 x86_64
- Load Average: 2.01 1.88 1.83
- Uptime: 4 days, 13 hours, 32 minutes, 22 seconds
- OS APT Last Update: 28.05.2019 04:46:48 CEST +02:00:00
- SHELL LOCALE LANG: de_DE.utf8
CPU(s): 0
CPU MHz: 1999.853
Hypervisor-Anbieter: Parallels
- RAM: 4.59 GB/16.00 GB in use (28%)
- DISK: 36.05 GB/605.78 GB in use (5%)
+ libglib: 2.56.4-0ubuntu0.18.04.2
- Status: running (PIDs: 13825 13824, User: sinusbot)
- Binary Info: MD5 Hash: 6f301dac3e4dfd45ce149933c5dadd08, Perms: 755, User: sinusbot
- TS3Path = /opt/sinusbot/teamspeak3-client/ts3client_linux_amd64 (Version 3.2.5)
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2019.05.20)
- Installed scripts: advertising.js; alonemode.js; bookmark.js; Change_Channelcodec_And_Quality_Automaticly.js; come.js; command.js; Default-Channel.js; followme.js; norecording.js; OKlib.js; rememberChannel.js; welcome.js
- Time (local): 28.05.2019 23:22:13 CEST +02:00:00
- TeamSpeak 3 Version: 3.2.5
- youtube-dl Version: 2019.05.20
- DiagScript Version: 0.7.1
Moritz!
