not running bot !!!
Abdumalik
webinterface is working but bot is not entering when i start ./sinusbot it shows at the end
2015/09/16 11:44:10 X [MAIN] New connection
2015/09/16 11:44:10 X [MAIN] Disconnected: 10
$ ./sinusbot
is correct for the 0.9.9
You have to hit the power button in the top right corner oft the Interface to start the bot instance. However more informations are needed to identify the problem. Please read the this: https://forum.sinusbot.com/threads/read-me-before-you-post.115/
If you not have it already done, try the button.
Give us some more info, Hardware etc.
Try to Restart your Server or check for existing processes from the Sinusbot self or the TeamSpeak3 Client
And Also check for a copy of the Plugin in your TeamSpeak3 Client Folder under "plugins".
