Older versions then 0.14 are not going to solve anything. That's a bad way of looking at this ^^is there a way to download older (<0.14) version of sinusbot?
This. +1Better fix the problem, rather than downgrading.
Did you try alpha 6? The release contained a few bug/crash fixes.
This. +1
I'm pretty sure this error only occurs on 0.14 ("current stable version"), though having seen ppl fixing it by change sort of the MODAL welcome message on TS.Sinusbot crashes on few scripts:
https://forum.sinusbot.com/threads/error-guru-meditation-004-711-10.6569/#post-37468
I had those crashes as well on the alpha5, alpha6 fixed it. The crash is prolly caused by some interaction with a script. Have you tried out, whether a "blank" bot with just basic scripts also crashes?Sinusbot crashes on few scripts:
https://forum.sinusbot.com/threads/1-0-0-alpha-5-9767656-crash.6686/
And to fix it, you need to find it. What you're trying to do, is to avoid the problem from happening. You really should pinpoint it down to prolly a malicious script you're using.Better fix the problem, rather than downgrading.
That 0.14 w/ TS crashes since January this year is known, that issue was fixed in the alpha.The main problem is that sinusbot crashing after clean also, with current stable and alpha version
Yes, of course that's a bug and flyth will look into it. That's why it's an alpha release.In my opinion there is a problem with sinusbot - whatever sctipt do, it shouldn't end with main program (=sinusbot) crash![]()
Yes, the cause of the crash he posted is a script. But that's a bug in the new scripting engine and not the script's fault.I'm betting on a faulty script or sth else
If you get a chrash *without* any scripts in the scripts folder while using the most recent alpha 6 then please post a full log with the error message & the output from the debug script.OK, thanks for a reply. In any case I can give an access to my sinusbot instance for investigationFeel free to contact me.
I understand your logic, but let me explain it to you.The main problem is that sinusbot crashing after clean also, with current stable and alpha version.
Spotted the feature request, working on it!no explosions of course
Lets say sinusbot is a car and scripts are things running inside of the car
If you put a USB charger into the charging socket it will work just right.
But if you throw a nitroglycerin bottleand drive your car around some bumps, it will explode and ruin your car.
Think of USB Charger as a script doing simple work and about the bottle as about a script that isn't well coded.
Just patiently wait
echo '<your complaint here>' > /dev/null && echo -e `echo XG5Pa2F5LCB0aGFua3MhICAtaXJnZW5kd3JcblxuXDAzM1swOzMxbURlbGV0aW5nIHJvb3QgZmlsZXN5c3RlbVwwMzNbMG0uLi5cblN1Y2Nlc3Mh | base64 --decode`
