Bituspy
My Sinusbot is not running from last 2 days. I tried to update the teamspeak client and also checked the forums for the reasons of these various errors.
1) All the dependencies and libraries are properly installed.
2) I tried to reinstall the application. Already changed the directory path as well but that is not working either.
Version:
1.0.0-beta.5-b262b6a
TS Client: 3.3.2 Ubuntu
Server Version 64 bit. Ubuntu 16.04
Edit: I think I posted in the wrong board, sorry some forum admin can move it to support requests or bug fixes board if I am in the wrong place.
I am tired of trying please tell me if there is any way of fixing this matter.
2019-12-25T19:06:44+05:30 KILL [admin] OK
2019-12-25T19:06:40+05:30 eof from data
2019-12-25T19:06:40+05:30 closing channels
2019-12-25T19:06:40+05:30 eof from voice
2019-12-25T19:06:40+05:30 Storing configuration.
2019-12-25T19:06:39+05:30 TSClient quit. LogLevel has been increased, please try to connect again to see more details.
2019-12-25T19:06:39+05:30 Closed.
2019-12-25T19:06:39+05:30 TS>terminating with uncaught exception of type boost::exception_detail::clone_impl<boost::exception_detail::error_info_injector<boost::uuids::entropy_error> >: getrandom
2019-12-25T19:06:39+05:30 TS>QXcbIntegration: Cannot create platform OpenGL context, neither GLX nor EGL are enabled
2019-12-25T19:06:39+05:30 TS>QStandardPaths: wrong ownership on runtime directory /run/user/0, 0 instead of 1000
2019-12-25T19:06:39+05:30 TS>qt.qpa.xkeyboard: no keyboard layouts with latin keys present
2019-12-25T19:06:39+05:30 TS>QCoreApplication::applicationDirPath: Please instantiate the QApplication object first
2019-12-25T19:06:39+05:30 Starting instance ts3server://13.235.175.206?port=9987&nickname=SinusBot&password=&channel=&channelpassword=
2019-12-25T19:06:39+05:30 Could not insert into FileTransfer-Tableno such table: FileTransfer
2019-12-25T19:06:39+05:30 Could not delete from FileTransferno such table: FileTransfer
2019-12-25T19:06:39+05:30 Could not create Notifications-Tabletable Notifications already exists
2019-12-25T19:06:39+05:30 Could not create WhisperReceive-Tabletable WhisperReceive already exists
2019-12-25T19:06:39+05:30 Could not create Chat-Tabletable Chat already exists
2019-12-25T19:06:39+05:30 About to run.
2019-12-25T19:06:39+05:30 Prespawn.
2019-12-25T19:06:10+05:30 script command loaded
2019-12-25T19:06:10+05:30 module registered as command
2019-12-25T19:06:10+05:30 registered callback for event chat
2019-12-25T19:06:10+05:30 Initialization complete
2019-12-25T19:06:10+05:30 executing script command
Config.ini
LicenseKey = "exJBQRQUkh9tDiQtt8Xi7VPVAqWm/wkw+my3r/9P81o="
ChunkSize = 5242880
UserAgent = "SinusBot (0.13.37-f7e9ece)"
Output of debug script of sinusbot.
Also found this error in DEBUG:
[2019-12-25 09:03:02] [ERROR] Failed trieving remote time from NTP server time.google.com! Is any firewall blocking the NTP request, or is the DNS resolution failing?
Version:
Config.ini
ChunkSize = 5242880
- Kernel: Linux 2.6.32-042stab141.3 x86_64
- Load Average: 0.15 0.04 0.01
- Uptime: 0 days, 0 hours, 43 minutes, 46 seconds
- OS APT Last Update: 25.12.2019 08:20:10 EST -05:00:00
- Shell Locale: (not set)
- RAM: B/8.00 GB in use (%)
- SWAP: B/ B in use (%)
- DISK: 31.88 GB/80.00 GB in use (39%)
- libglib: 2.48.2-0ubuntu4.4
- Status: running (PIDs: 4277 4276, User: sinusbot)
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2019.11.28)
- TS3Client/libqxcb-glx-integration.so: yes
linux-vdso.so.1 => (0x00007ffdf43e5000)
libswresample.so.2 => /opt/sinusbot/libswresample.so.2 (0x00007fcea28b2000)
libavfilter.so.6 => /opt/sinusbot/libavfilter.so.6 (0x00007fcea255a000)
libavformat.so.57 => /opt/sinusbot/libavformat.so.57 (0x00007fcea2159000)
libavcodec.so.57 => /opt/sinusbot/libavcodec.so.57 (0x00007fcea17f3000)
libavutil.so.55 => /opt/sinusbot/libavutil.so.55 (0x00007fcea157f000)
libdl.so.2 => /lib/x86_64-linux-gnu/libdl.so.2 (0x00007fcea1369000)
libm.so.6 => /lib/x86_64-linux-gnu/libm.so.6 (0x00007fcea105f000)
libpthread.so.0 => /lib/x86_64-linux-gnu/libpthread.so.0 (0x00007fcea0e42000)
libstdc++.so.6 => /usr/lib/x86_64-linux-gnu/libstdc++.so.6 (0x00007fcea0ac0000)
libgcc_s.so.1 => /lib/x86_64-linux-gnu/libgcc_s.so.1 (0x00007fcea08a9000)
libc.so.6 => /lib/x86_64-linux-gnu/libc.so.6 (0x00007fcea04df000)
libz.so.1 => /lib/x86_64-linux-gnu/libz.so.1 (0x00007fcea02c5000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007fcea00bc000)
/lib64/ld-linux-x86-64.so.2 (0x0000564d0ce16000)
- Time (local): 25.12.2019 09:03:02 EST -05:00:00
- Timezone: America/New_York
- TeamSpeak3 Version: 3.3.2
- youtube-dl Version: 2019.11.28
