EN Rank channel and Channel description
FrxX100
Hello. I create a plugin for automatic channels, but I have a problem.
Everything works fine but I have no idea how to do that by creating a channel automatically create a description for the channel, and gave the status of "Channel Admin".
I tried the code from other plugins and does not work.
channelUpdate() also does not function when changing the description.
Please help.
Regards
channelCreate(params channelParams) bool
Creates a channel with params specified (see above)
Channel parameters
field value
id (int) id of the channel
name (string)
topic (string)
codec (int) the codecs' id (tbd)
quality (int) (tbd)
maxClients (int) (tbd)
order (int) order-value of the channel (lower = higher)
perm (bool) is permanent?
sperm (bool) is semi-permanent?
default (bool) is the servers' default channel?
enc (bool) is encrypted?
This information is from the Sinusbot webinterface --> help --> scripting
(Are you on the latest beta?)
FrxX100
I am using the latest version of the script.
Sorry, I looked also at this site and from what I can see it can not be automatically created as described in the documentation anywhere that is not found. Same with the broadcasting ranks CHANNEL only found the broadcasting ranks SERVER. :/
Sorry for my English.
