Bug Scripts: wrong data in 'clientMove'-event when clients leave
mtrex
I noticed, that the information of the 'clientMove'-event is wrong/random if a user leaves the server / the new channel is '0'.
The following code inside of a plugin...
sinusbot.on('clientMove', function(ev) {
   if(ev.oldChannel > 0 && ev.newChannel > 0) {
    sinusbot.log('User "' + ev.clientNick + '" switched from "' + ev.oldChannel + '" to "' + ev.newChannel + '"  - clientId=' + ev.clientUid);
  } else if(ev.oldChannel > 0 && ev.newChannel == 0) {
  sinusbot.log('User "' + ev.clientNick + '" left from "' + ev.oldChannel + '"  - clientId=' + ev.clientUid);
  } else if(ev.oldChannel == 0 && ev.newChannel > 0) {
    sinusbot.log('User "' + ev.clientNick + '" joined channel "' + ev.newChannel + '"  - clientId=' + ev.clientUid);
...gave me the following log-output, when I joined and left the server a few times:
ALL log-entries resulted from movements of the same client 'm-trex', but foreign names and clientIds appeared.
The wrong entries are highlighted in red.
This error also affects the plugin aloneMode.js, as the bot sometimes switches to alonemode, even if the single user in his channel is still present, but the bot thought he left.
Regard,
mtrex
- Operating System: Ubuntu 14.04.4 LTS (OpenVZ)
- Kernel: Linux 3.13.0-042stab113.11 x86_64
- Load Average: 0.09 0.14 0.10
- Uptime: 18 days, 19 hours, 54 minutes, 42 seconds
- OS APT Last Update: 02.04.2016 16:13:13 UTC +00:00:00
CPU(s): 64
CPU MHz: 559.863
Virtualization: VT-x
- RAM: 91.69 MB/8.00 GB in use (1%)
- SWAP: 0 B/0 B in use (%)
- DISK: B/ B in use (%)
- Report date: 02.04.2016 16:20:13 UTC +00:00:00 (timezone: Etc/UTC)
- Status: running
- Binary: /opt/sinusbot/sinusbot (Hash: 09876610d75f55d2a133013f5a06937d)
- Version: 0.9.11-ee30ef7
- Bot Plugin: 550012df1db6e7086abcf5af6afd0dda
- TS3 Client: 550012df1db6e7086abcf5af6afd0dda
- TS3Path = /opt/sinusbot/TeamSpeak3-Client-linux_amd64/ts3client_linux_amd64 (Version 3.0.18.2)
- YoutubeDLPath = not set
- Installed scripts: advertising.js; aloneMode.js; badchan.js; bookmark.js; covatar.js; dev.js; followme.js; idle.js; jail.js; keywordmessage.js; metadata.js; mm-oldchannels.js; mm-returntobase.js; norecording.js; reconnect.js; rememberChannel.js; showcase.js; sound.js; usets-adminbot.js; welcometext.js
- DiagScript version: v0.4.1
