Greetings to everyone who is reading my post.
I found out, that your newer beta-releases version 0.9.8+ are kinda broken and I'm not only one who has this problem.
There wasn't any problem, when I used version 0.9.8, but I wanted to upgrade from 0.9.8 to newer beta-release 0.9.15 because I was impressed with new features that came in with newer versions like scripts etc.
Now I'm using version 0.9.15 and many of things had happened. Since I've upgraded (I mean completely re-install and re-download sinusbot) everything went wrong. The bot is no longer able to launch client and connect to my server plus he can't start web administration commonly running on 127.0.0.1:8087.
Now I will paste here some information, that can help you solve this issue.
PC specs:
Operating system: Ubuntu 16.04
Kernel version: 4.4.0-47-generic
CPU: AMD FX-6300 (Vishera)
GPU: Sapphire HD 7770 Vapor-X OC
Network card: Realtek 8186
Browsers used: Firefox 49.0, Chrome 54.0.2840.100 (64-bit)
Output of ./sinusbot - log level 10:
Output of config.ini:
Output of bash diagSinusbot.sh:
I'll be grateful to everyone, who'll help me.
Thank You!
- Yame
PC specs:
Version: 0.9.15-b20cc30
2016/11/12 23:53:28 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin advertising.js
2016/11/12 23:53:28 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin aloneMode.js
2016/11/12 23:53:28 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin badchan.js
2016/11/12 23:53:28 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin bookmark.js
2016/11/12 23:53:28 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin covatar.js
2016/11/12 23:53:28 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin dev.js
2016/11/12 23:53:28 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin followme.js
2016/11/12 23:53:28 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin idle.js
2016/11/12 23:53:28 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin metadata.js
2016/11/12 23:53:28 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin norecording.js
2016/11/12 23:53:28 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin rememberChannel.js
2016/11/12 23:53:28 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin showcase.js
2016/11/12 23:53:28 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin sound.js
2016/11/12 23:53:28 [GENERAL/SCRIPTS] INFO Loading ScriptPlugin welcometext.js
2016/11/12 23:53:28 X [MAIN] Starting up fake x-server...
2016/11/12 23:53:28 b2866323 INFO Loading instances
2016/11/12 23:53:28 b2866323 INFO Loading instance://4da0d9b5-b7b2-47ac-84d4-4f0be7dc2719
2016/11/12 23:53:28 b2866323 4da0d9b5 INFO Initialization complete
2016/11/12 23:53:28 [GENERAL/FFMPEG ] INFO FFmpeg/avcodec v3741798; license: LGPL version 2.1 or later; 81 codecs
2016/11/12 23:53:28 [GENERAL/FFMPEG ] INFO FFmpeg/avformat v3742052; license: LGPL version 2.1 or later; 143 formats
2016/11/12 23:53:28 [GENERAL/YTDL ] INFO youtube-dl checking...
2016/11/12 23:53:28 [GENERAL/YTDL ] INFO youtube-dl version compatible, support enabled
2016/11/12 23:53:28 [GENERAL/!!!!!!!] NOTICE You may now configure and launch the bots from the webinterface. http://0.0.0.0:8087
2016/11/12 23:53:28 [GENERAL/RADIO ] INFO RadioStation data loaded
2016/11/12 23:53:29 [GENERAL/RADIO ] INFO Imported radio stations
LicenseKey = "fM0FVIi8ZBn9VMx25OMqs38nbf+JDSawYUrsjF4JCS0="
UserAgent = "SinusBot (0.9.15-b20cc30)"
- Operating System: Ubuntu 16.04.1 LTS
- Kernel: Linux 4.4.0-47-generic x86_64
- Load Average: 0.34 0.36 0.45
- Uptime: 0 days, 11 hours, 54 minutes, 0 seconds
- OS Updates: 6 (updates available!)
- OS APT Last Update: 12.11.2016 23:28:56 CET +01:00:00
CPU(s): 6
Socket(s): 1
Model name: AMD FX(tm)-6300 Six-Core Processor
CPU MHz: 2000.000
- RAM: 4.20 GB/15.69 GB in use (26%)
- SWAP: 0 B/11.17 GB in use (0%)
- DISK: 56.59 GB/45.96 GB in use (123%)
> libglib: 2.48.1-1~ubuntu16.04.12.48.1-1~ubuntu16.04.1
- Binary: /opt/sinusbot/sinusbot (MD5 Hash: ca497448f617fc17a5bb579980a8572e)
- Version: 0.9.15-b20cc30
- Bot Plugin: 0b71cb8de70ec252d6f339b26c3a0e82
- TS3 Client: 0b71cb8de70ec252d6f339b26c3a0e82
- YoutubeDLPath = /usr/local/bin/youtube-dl (does exist, version: 2016.11.08.1)
- Report date: 13.11.2016 00:13:24 CET +01:00:00 (timezone: Europe/Prague)
- youtube-dl Version: 2016.11.08.1
- DiagScript version: 0.4.6
Thank You!
- Yame
