Sinusbot error to upload script with PuTTy
-invisible-
Hello, I have a problem uploading some plugins with PuTTy uploading it from GitHub (Since I can't do it from WinSCP, because it doesn't let me enter the root user). I upload the github plugin to the 'scripts' folder when I reload the page, it doesn't appear in the scripts panel. I await your responses, thank you!
_maddiboy
hey,
that reads as if there were incorrect permissions settings.
Since my bots run on Portainer, I initially had the same problem. I solved by creating an extra user with the required rights for read/write/delete.
You best try this.
Otherwise it would be interesting to know how the Sinusbot is installed in your system.
MauriceR
Just reloading the page doesnt work. You need to set the right permissions to the file (via putty: chmod & chown) and also restart the bot. After that it should show on the website.
Some plugins might not show after restarting, but that might be because of an old, not compatible version
