Ike2117
error on line 758. http://prntscr.com/jb1n1m
Retry the installer, but remove the bot first.error on line 758. http://prntscr.com/jb1n1m
Chrony ist im neuen Installer drinKurze Zwischenfrage: Wozu benötige ich vnc auf einem Server ohne GUI?
//Edit: Konnte ich mir selbst beantworten, TeamSpeak selbst brauch ein paar X-Bibliotheken.
Und ntp wird auch installiert, Ubuntu 18.04 nutzt aber inzwischen chrony. Ich weiß, ist noch frisch, aber vielleicht gibts da ja noch eine kleine Anpassung![]()
Jup... Please send the whole error...
Write a PN to @flyth or a other staff member.Error on line 791. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script.
Command which failed was: "su -c "wget https://www.sinusbot.com/dl/sinusbot.current.tar.bz2" $SINUSBOTUSER". Please try to execute it manually and attach the output to the bug report in the forum thread.
root@vaua0047229:~# su -c "wget https://www.sinusbot.com/dl/sinusbot.current.tar.bz2" $SINUSBOTUSER
--2018-05-02 09:35:17-- https://www.sinusbot.com/dl/sinusbot.current.tar.bz2
Resolving www.sinusbot.com (www.sinusbot.com)... 104.18.40.220, 104.18.41.220
Connecting to www.sinusbot.com (www.sinusbot.com)|104.18.40.220|:443... connected.
HTTP request sent, awaiting response... 403 Forbidden
2018-05-02 09:35:17 ERROR 403: Forbidden.
Keine Ahnungjedesmal resettet sich das login passwort was da los?
Which OS? Retried the installer?Error on line 775. Report this to the author at https://forum.sinusbot.com/threa ds/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script.
Command which failed was: " cp -R ./TeamSpeak3-Client-linux_$ARCH/* ./". Please try to execute it manually and attach the output to the bug report in the forum thread.
Failed to restart ntp.service: Unit ntp.service is masked.
Error on line 677. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script.
Command which failed was: " service ntp restart". Please try to execute it manually and attach the output to the bug report in the forum thread.
Whats the output ofI use Ubuntu 18.04
Code:Failed to restart ntp.service: Unit ntp.service is masked. Error on line 677. Report this to the author at https://forum.sinusbot.com/threads/sinusbot-installer-script.1200/ only. Not a PN or a bad review, cause this is an error of your system not of the installer script. Command which failed was: " service ntp restart". Please try to execute it manually and attach the output to the bug report in the forum thread.
lsb_release -r 2>/dev/null | grep 'Release' | awk '{print $2}'
Whats the output of
?Code:lsb_release -r 2>/dev/null | grep 'Release' | awk '{print $2}'
root@root:/home# lsb_release -r 2>/dev/null | grep 'Release' | awk '{print $2}'
18.04
Starting the installer now!
Detected latest TS3-Client version as 3.1.9
Чтение списков пакетов… Готово
Построение дерева зависимостей
Чтение информации о состоянии… Готово
Уже установлен пакет chrony самой новой версии (3.2-4ubuntu4).
Обновлено 0 пакетов, установлено 0 новых пакетов, для удаления отмечено 0 пакетов, и 0 пакетов не обновлено.
Packages installed!
Command which failed was: "service ntp restart". Please try to execute it manually and attach the output to the bug report in the forum thread.
root@srv:~# service ntp restart
ntp: unrecognized service
root@srv:~# lsb_release -r 2>/dev/null | grep 'Release' | awk '{print $2}'
18.04
root@srv:~# uname -a
Linux srv 4.15.0-20-generic #21-Ubuntu SMP Tue Apr 24 06:16:15 UTC 2018 x86_64 x86_64 x86_64 GNU/Linux
root@srv:~# cat /etc/*release
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=18.04
DISTRIB_CODENAME=bionic
DISTRIB_DESCRIPTION="Ubuntu 18.04 LTS"
NAME="Ubuntu"
VERSION="18.04 LTS (Bionic Beaver)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 18.04 LTS"
VERSION_ID="18.04"
HOME_URL="https://www.ubuntu.com/"
SUPPORT_URL="https://help.ubuntu.com/"
BUG_REPORT_URL="https://bugs.launchpad.net/ubuntu/"
PRIVACY_POLICY_URL="https://www.ubuntu.com/legal/terms-and-policies/privacy-policy"
VERSION_CODENAME=bionic
UBUNTU_CODENAME=bionic
Scheint nicht zu funktionieren, hab das mit einem neuen droplet unter Ubuntu 18.04 getestet.Cause I added an 18.04 support and tried this on some VPS without problems.
I have the same Problem. I know the source of the problem: http://dl.4players.de/ts/releases/SinusBot isn't installed yet. Installer goes on.
1) No
2) Yes
#? 2
1) Yes
2) No
#? 1
1) Yes
2) No
#? 1
Here is a 3.2.0 Version without a .run file. Thats why he cant install latest ts3 client. I downloaded the 3.1.9 and uploaded to my webserver and replaced the links in the Installscript![]()
